Question about Maytag Dryers
My Maytag Epic Z Dryer is showing a code of F-22. It will not work. What does this mean?
    New Friend:
  • 12 Answers
If U R comfortable doing so, I suggest that U go to the Breaker Panel, and find the Dryer Breaker, turn it off for a min. then turn it back on.. By doing this, it Might re-set the Dryer... Once U turn it back on, and the Dryer comes on, I would watch it, to see if it flash's anymore Codes. If this doesn't Help, I suggest calling your Certified Maytag Repairman.. Hope this Helps U...
Posted on Oct 26, 2008
What does error f 1 mean?
Type Maytag Epic Z error into YouTube and see if the video comes up, thanks
Jun 21, 2015 | Maytag Epic z Front Load Electric Dryer
Maytag epic error code f01
Maytag Epic Gas Dryer
This error code below would be indicated when attempting to start a drying cycle, or after activating the diagnostic test mode.
E1 - flashes if the thermistor is open.
The machine control electronics monitors the exhaust temperture using the thermistor, and cycles the heater relay on and off to maintain desired temperature.
Begin with an empty dryer and a clean lint screen.
  1. Plug in dryer or reconnect power.
  2. Set the following configuration:
Door - must be firmly closed Press CONTROL ON Press CYCLE END SIGNAL (Loud) Press HOLD TO START
If after 60 seconds, E1 or E2 flashes in the display and the dryer shuts off, the thermistor or wire harness is either shorted or open.
  • Unplug dryer or disconnect power
  • Check wire connection at the machine control electronics and thermistor.
  • If wire connections are good, remove the two wires from the thermistor and replace the thermistor.
  • Plug in dryer or reconnect power
NOTE: All thermistor resistance measurements must be made while dryer is unplugged or disconnected from power.
Thermistor resistance: 10 Celsius ----- 19-22 kOhm
16 C ------------ 15-17 kOhm
21 C ------------- 11.5-13.5 kOhm
27 C ------------- 8.5-10.5 kOhm
32 C ------------- 6.8-8.8 kOhm
38 C ------------- 5-7 kOhm
If E1 or E2 doesn't flash in the display, the connections to the thermistor are good. Therefore, check exhaust temperature value at any or all of the temperature levels.
Hold a glass bulb thermometer capable of reading from 32 to 82 Celsius (90-180 F) in the center of the exhaust outlet.
Table below shows correct exhaust temperatures:
24385279-wycorcio5u0xxoh2plbhrodj-5-0.jpg 24385279-wycorcio5u0xxoh2plbhrodj-5-2.jpg Dado
May 10, 2014 | AEG Dryers
Maytag error codes
what does a f 14 code mean on a maytag epic z
Jan 01, 2014 | Washing Machines
F01 means the main control board or "micro computer" has detected an internal short. Unfortunately, the only way to correct this issue is to replace the control board itself. It's under the top panel in the front right corner.
Dec 05, 2013 | Dryers
Electric dryer not get heat
Inspect the front door lock if "F22" is displayed. Press the "Pause/Cancel" button two times. Close the washer door firmly to latch the door. Remove clothing preventing the door from closing and latching. Press the "Power" button, followed by the "Start" button.
May 12, 2012 | Maytag Epic 7.0 Cu. Ft. SuperSize Capacity...
My maytag epic z is showing me f21 code what does it mean.
Give this a shot:
Feb 06, 2011 | Maytag EPIC MFW9700S Front Load Washer
My Maytag Epic Z Electric Dryer has an OE service code, quit working after the interior drum light burnt out. What does that code mean?
Refer to your service manual it will tell you what the code means. I would recommend to remove the bulb from the housing inside the dryer which is located next to the drum. That should fix the problem.
Aug 09, 2010 | Dryers
"Maytag Epic z washer flashes f 24 error code"
I have a maytag epic z dryer and it wont turn on. it worked fine the last load, now nothing? help.
Apr 25, 2009 | Maytag EPICz Electric Dryer
Maytag Epic dryer won't start
hi there,
if it beeps it means that the keypad is sending a signal to the control board to start it but it doesn't. since the control board sends a signal to the motor to start the dryer to spin. does the dryer hum?
Dec 17, 2008 | Maytag EPICz 6.7 Cu. Ft. 8-Cycle King-Size...
Error code
I could not find error f01 for maytag, but for for whirlpool, it means CCM(central control unit) unplug washer for 2 minutes then try it.
Jul 12, 2008 | Maytag EPICz Electric Dryer
Dryers Logo
246 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
