Question about Toro Garden
How much will cost a calbulator for a mower model lev120
    Sergeant:
  • 316 Answers
Hello, you can get a set of calbulators at harbor fraight really cheep,what are you calbulatoring on a lev 120? hope this helps,
Posted on Feb 19, 2012
Where does the gov rod and throttle rod hook on a 6.5 hp lev120 on a toro recycler 22 lawn mower
gov. rod goes to the hole in the carb. spring goes to the metal tab on front of engine
Aug 10, 2016 | Toro Garden
Tecumseh lev120 - Toro lawn 6.5 GTS - Clean bolt, new gas, new oil, new pull cord - Cord pulls back on you - I read that it is the flywheel key - I pull the cover off and the key looks in place - any
You really need to remove the flywheel to check the key, the only other reason for it to kick on the starter rope is if the blade bolt is not tight enough.
May 23, 2013 | Garden
Need carb linkage diagram for tecumseh LEV120 engine
yes or a bad safty switch check the seat the brake and the clucth
May 07, 2013 | Garden
TORO RECYCLER LAWN MOWER MODEL 20017 2006 EDITION
to far away for me to look at it i'm on the east coast
Sep 01, 2012 | Toro Garden
How much will cost a valvular or lev120
hello, a valve lapor about $15.00,
Feb 18, 2012 | Toro Garden
Model LEV120 spark gap? points? starts, stops, lopes
clean your carb, and fresh gas.... this will fix your problem
Jun 08, 2011 | Toro Garden
I have a Toro super recycler model 20017 with a tecumseh motor, model LEV120, spec 361541B has spark and is getting fuel but will not start any suggestions? Have already replaced coil cause previously had...
Make sure that the doggone brass bolt that holds the carb bowl on was cleaned as well. It is the main jet and has tiny holes that get clogged from evaporated fuel/varnish and debris (if no inline fuel filter is used). It has holes on the bottom and the smooth part of the sides...it needs to be clean and shiny! If all is well and the motor is an OHV, then maybe the valves need adjusting.
Sep 14, 2010 | Toro Super Recycler Super Bagger Lawn...
Need replacement engine or short block for Tecumseh LEV120-361541B
Tecumseh has gone bankrupt so finding parts and engines has been difficult. i would see if i could find a B&S engine with the same bolt pattern to mount on the deck.
Sep 30, 2009 | Toro Lawn Mower With Toro Power Tools
BROKEN BRAKE PAD UNDER FLYWHEEL ON TORO LAWN MOWER THE ENGINE IS A TECUMSEH MODEL lev120 SPEC 361541b 195cc
If you had replaced the flywheel key & did not engage the saftey bail it would brake the brake. Make sure the bail is engaged befor installing the flywheel.
Sep 23, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
63 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
