Question about Eclipse Audio Players & Recorders
Connecting Klastor MP4 Player To Lap Top
HOW TO CONNECT TO LAPTOP
  • 32,281 Answers
The supplied USB cable is used to connect the player to the USB port on the laptop.
Posted on Feb 19, 2012
3 Suggested Answers
SOURCE: my mp4 player wont connect
Great Solution by  DCDW
Rank: Apprentice
Rating: 95%, 43 votes
I first found that when I plugged my player into my computer it registered it as a MTP (Media Transfer Protocol) device and in turn never showed up as a storage device on my computer. I fixed this by going into my Control Panel -> System Icon -> Hardware Tab -> Device Manager button.
Clicking on the "System Devices" tab should have "Walkman" or MTP device. Right click on it and go to properties, now before doing anything it should say "Location -- ------ Location 0 (Walkman)" if not try unplugging the walkman and see if the MTP device you're looking at is removed from the list, just to make sure it's the right device we're looking for.
If you've confirmed it's the Walkman, click on the "Driver tab" and click on "Update Driver...". Then click on the "Install from a list or a specific location (Advanced)" option and click "Next". Now select the "Don't search. I will choose the driver to install." and click next. It should now bring up 2 driver choices, one being "MTP Device" and the other "USB Mass Storage Device". Select the USB option and select next, it will then install your walkman as a USB storage device and after that's done. It should be a matter of unplugging and plugging the Walkman back in and it should show up on your storage options in "My Computer"
Posted on Jan 21, 2009
SOURCE: I bought my wife a Tevion mp4 player model 43183
Did you actually save the playlist in the Media Player? There is an icon for a disk above the navigation pane where you dragged your songs to make your playlist - click this and you are asked to name the selection.
Posted on May 02, 2011
How do i connect my keyboard and my laptop?
Download USB MIDI driver for yamaha from yamaha website,and install to laptop.
Next:
Make sure the POWER switch on the instrument is set to OFF,then use an AB type USB cable to connect the instrument to the laptop.
After making the connections, turn on the power of the instrument.
Laptop will immediately notify that new hardwares is connecting and automatically install the drivers. Wait until the process is finish.
Thats all. In Ableton,the setting MIDI input must be set to USB MIDI.
Aug 19, 2015 | Yamaha PSRE413 Keyboard
I have mitone mp4 player (MITMP26) 4 GB . I have a problem. USB device don't see my computer. Windows 7 64 bit. Please help me.
Hi, player not recognized by the computer
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see Sansa player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the Sansa player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are mitone mp4 player Connect and mitone mp4 player Express which only use MTP mode. MTP mode is the recommended and default method for mitone mp4 player Players when used with Windows OS.
The mitone mp4 player player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
SOLUTION 3 - Connect using MSC mode
Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC.
If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the mitone mp4 player firmware
NOTE: mitone mp4 player Express and mitone mp4 player Connect do not have MSC mode. For mitone mp4 player Connect you can try reinstalling the firmware using the Connect Recovery Mode.
Additional troubleshooting notes:
If you have replaced the mitone mp4 player Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting.
- Try connecting on another computer.
- Try using a different USB cable
- Try connecting to the back USB ports which may supply better power.
- If only MTP mode is not working, try reinstalling Windows Media Player
For Windows XP try also download and install the MTP Porting Kit.
Hope that helped And please don't forget to rate me..
Have a nice day....
Feb 19, 2011 | Audio Players & Recorders
Cannot connect to my laptop telefunken Mp3 mp4 player
Check whether USB cable is ok. Then make sure that you laptop can support USB2.0 interface. I think the mp3 mp4 player will connect your laptop.
Dec 26, 2009 | Samsung Yepp YP-T7JX MP3 Player
Downloading music to my mp4 player
first connect your mp4 to your laptop with a usb cable. once it shows up on the laptop copy or cut and paste your music to the root folder of your mp4 or the music folder. after that is done disconect your mp4 from your laptop.
restart you mp4 and your music should now show up. enjoy your music
Jun 06, 2009 | Digital Mind Corporation iQ Sound...
Cannot connect lap top or printer wireless and also connect to the internet via AT&T motorola modem
yes. Here is Linksys' page on how to:
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3687
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 12, 2009 | Linksys Wireless-G WRT54G Router
I cannot connect my lap top to my desk top
Dear,
Please explain the way you are connecting your Laptop to PC.
It will help to solve the problem.
Regards,
rakesh Kumar
Mar 30, 2009 | Computers & Internet
Trying to connect desk top computer and lap top computer
There is only two ways to possibly connect both the desktop and the laptop in the network. That is to purchase a router so you can connect them both or a route with a wireless and then the laptop (Which most new ones have a wireless capability installed) can connect wireless from anywhere in the home. If you already have a Cable or DSL Modem it may have a wireless capability. Otherwise you would have to get a wireless modem. Hope this helps. Bud
Dec 24, 2008 | Office Equipment & Supplies
I disconnected my son's lap top and we can not connect to the internet on his lap top It's saying on the lap top can not display this page Laura
Try connecting to http://209.235.250.53/
If it works, the laptop is using a bad DNS address. How you fix that depends on the operating system - XP or Vista.
Sep 10, 2008 | Computers & Internet
Connecting to my computer
the way you connect your mp4 player to your computer is first you download the disk to your computer that came with the mp4player..then the computer will reconize the mp4 player.
Jul 18, 2008 | Delstar DS 917 Digital Media Player
I have a hp deskjet f2180 all in one printer scanner copier we have tried to add to my lap top but the lap top does not recognise the hp deskjet f2180 and we dont know what else is compatable with
What operating system are you running on your laptop? This model only supports Windows 2000/XP/Vista and Mac OS/X. Make sure you have installed the printer USB drivers (included on the printer software CD) first. If you are connecting the printer directly to the laptop, all you should then need to do is connect the printer to the mains power, turn it on, and connect the USB cable between the printer and the laptop. If you are connecting to a printer that is connected to another computer, you mus make sure printer sharing is enabled on the computer the printer is physically connected to.
I may be able to provide a better solution if you can provide more information on your Laptop operating system and how the printer will be connected.
Jun 15, 2008 | HP Office Equipment & Supplies
Top Eclipse Audio Players & Recorders Experts
henrysmooth
Level 1 Expert
juanmireles1
Are you an Eclipse Audio Player and Recorder Expert? Answer questions, earn points and help others
