Question about Frigidaire FDL50R1 Dehumidifier
Shut off? Fdl70s1 Frigidaire FDL50R1 Dehumidifier
Is this unit supposed to completely shut off when it reaches the set humidity level? Or is the fan supposed to run constantly?
  • Jim Garry Feb 20, 2012
    Thanks Chris. My main concern was the noise issue. I prefer for it to turn on and off so that the fan isn't constantly running. Appreciate your comments.
  • Electrolux
    Electrolux Feb 21, 2012
    Let me know if you have any other concerns, or if the noise or operation changes. You should be ok though!
SOURCE: Dehumidifier switching on and off, a lot
Check this page:
http://forum.doityourself.com/archive/index.php/t-308629.html
Posted on Jul 11, 2009
heatman101
  • 43501 Answers
SOURCE: dehumidifier shuts off
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on Apr 30, 2010
heatman101
  • 43501 Answers
SOURCE: I have a FDL70S1 dehumidifier
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on May 10, 2011
heinzhvac
  • 229 Answers
SOURCE: I have a FDL70S1 Dehumidifier.
Dont spend to much time trying to repair dehumidifier they are very cheap to replace. Most dehumidifiers have lots of problems because they are made so cheap. Just replace the dehumidifier you will tank me in the end.
Posted on May 17, 2011
heatman101
  • 43501 Answers
SOURCE: Recently bought a Frigidaire Dehumidifier four
heatman101
Posted on May 27, 2011
I have a fdl70s1 and will only work in continuous mode.. Collects water fine but turns off when I adjust humidity setting
I appreciate your post, Lee Silvey!
I understand that your Frigidaire dehumidifier, FDL70S1, will only work in continuous mode. Sounds like you could have a possible issue with the sensor or control panel. Are you under warranty? I would advise you to speak with your manufacturer to see if any further resolution can be provided. -Matt
Oct 15, 2014 | Frigidaire 70-Pint Dehumidifier -...
How to measure humidity in a room
Good Afternoon Friend,
I understand that you want to know how to measure the humidity in a room with your Frigidaire dehumidifier, model# FDL50R1. Typically, your appliance will not measure the humidity and tell you exactly what the level is. I suggest placing your dehumidifier in the room you want it in, and turning it on to the continuous mode. The display will show "CO". Leave it at this setting for the first 3-4 days. Once the 3-4 days has passed, I suggest setting it to the 50%, 60%, or 70% setting and change it to your liking. If it is more humid in the room than you would like, put the setting lower. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 23, 2014 | Frigidaire FDL50R1 Dehumidifier
Is there any way to run automatically. . . where when it reaches humid per cent it shuts off? Can you rig to run for x hrs. per day and then shut off and restart the next day?
Norman, once the unit reaches the extraction level you have it set for, the unit will turn OFF automatically. However, depending on the humidity level in your home, it may take several cycles of running and emptying the bucket until it reached. After that, it should turn OFF, once the level is reached. Then when the humidity level rises above the setting it's on, it will start up again.
Since your unit is a Manually Controlled unit, there's no safe way to "rig' it to run on with a timer. The plug in wall timers are not rated high enough to handle the load of the dehumidifiers operation. Trying to use one, would fry the timer and possibly the dehumidifier.
If you want all the features you mentioned, you will need to purchase a new electronically controlled dehumidifier.
Jul 05, 2011 | Amana D545M Dehumidifier
Does the fan on a Kenmore dehumidifier run continuously, or does it shut off when the set point is reached? I returned a Frigidaire unit because the fan is designed to run continuously.
That depends on the manufacturer and in what mode you are operating it. If it's Continuous Mode. Yes, the fan will continue to run, as it's recirculating the air, in an effort to determine if and when the humidity level rises. Then the compressor will turn ON to extract the humidity.
Also, most units will do this if they are running thru the Defrost Cycle. This happens when the cooling coils frost over. It to, is a normal cycle.
So, if you are operating the dehumidifier in Continuous Mode, it's acceptable.
Hope this helped you. Please let me know. Thanks.
Jun 18, 2011 | Kenmore 54501 Dehumidifier
Just purchased a Danby dehumidifier (model # DDR6O11R). I was wondering when the dehumidifier reaches the programmed level of humidity (example: 40%). Is the unit suppose to shut off completely? I believe...
Depending on which mode you have the unit set on, will determine if it shots OFF entirely or the fan continues to run. In the Constant or Continual mode, the compressor will turn OFF, once the humidity extraction level has been reached. But, the fan will continue to operate, in an effort to keep the air circulating, so that if the humidity level rises, the compressor will turn ON and start extracting again.
In Timed Mode (usually 2 hour or 4 hour) , when the compressor turns OFF the fan does too.
Jun 06, 2011 | Danby Dehumidifier
I have a FDL70S1 Dehumidifier. Unit runs for just a couple minutes and shuts off-blinking bucket full even though no water in bucket. Unit won't stay on
May 17, 2011 | Frigidaire FDL50R1 Dehumidifier
I have a 50 series w/ digital humidity level readout. Recently unit reads the room at 30% humidity so it shuts off unless preferred setting is set to continuous. Can the sensors go bad that measure the...
If the humidity level is at or lower than 30%, the unit won't turn ON, until the reaches 35 - 40%. It's rare for the sensors to go bad. Just keep in mind, the dehumidifier is reading the humidity near the floor, not up at say, chest level. Humidity levels change every season, so this really would not be that unusual. Make sure that your clean the air intake filter regularly. Cleaning and wiping down the coolant coils would be a good idea, too..
May 16, 2011 | Frigidaire FDF50S Dehumidifier
My dehumidifier compressor runs and then shuts off, then runs and shuts off, continuously. The fan continues to run. It seems to be pulling water, though it's hard to tell how much because I have a...
Part of the problem may be that you have the humidity level set to high. The fan runs constantly to move the air around. When the unit senses a humidity level higher than what you have it set for, the compressor turns ON. Once it's ON, if the humidity level is short lived, it turns OFF.
Try setting the humidity level to the lowest possible setting. Usually, that 45%. If the humidity level in you home is higher than that, the compressor should turn ON and run until either the bucket is full or the humidity level reaches 45%. If this doesn't solve the problem, turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet for 12-15 minutes. Plug the unit bakc in, turn the Master ON/OFF Switch to ON and set the humidity level at it's lowest setting. Allow the unit to run until it cuts OFF and check the bucket for water. Hopefully that 12-15 minute time out allowed the unit to reset itself.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
May 11, 2011 | Maytag M3DH30B2A Dehumidifier
I have a FDL70S1 dehumidifier that runs and runs but doesn't take out any moisture from the air. I have cleaned out the filter and front screens thoroughly but it still doesn't work. The unit...
heatman101
May 10, 2011 | Frigidaire FDL50R1 Dehumidifier
Our dehumidifier turns on for only a few seconds, then shuts off.
Wendy, it's probably because the humidity level on the unit is set higher than the humidity level in the house. Keep in mind, the humidity level you set the control to, is not the amount extracted from the air. It's the level you want it to maintain. The higher the percentage level, the more humidity stays in the house. The lower the percentage level, the more humidity it removes, until the lower humidity level is reached. Then the humidifier will automatically shut OFF and/or the unit shuts OFF, because the bucket is full. Once it's emptied and replaced, if the unit needs to continue to extract humidity, it will start running again.
Hope this helped you solve the problem. Please let me know. Thanks.
May 04, 2011 | Maytag M7DH45B2A Dehumidifier
Frigidaire FDL50R1 Dehumidifier Logo
156 people viewed this question
Top Frigidaire Dehumidifiers Experts
Charles T Nevin
Charles T Nevin
Oloyede Monsuru
richie46
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
