Question about Hannspree 19" Widescreen LCD Flat Panel Monitor
Audio hookup cable, what does it look like??
What does the audio cable look like that comes with the monitor??
  • harleyjax70 Oct 26, 2008
    The problem I'm having is that I don't think this particular cable is like the one that came with the monitor. I moved when I hooked up the monitor didn't hook up the audio and now I'm not sure what it looks like among my stuff I packed.
  • 68 Answers
Harley,
audio cables usually have a 3.5mm stereo jack on each end, sometimes you will have a green plug one end and a pink or other colour the other.
It will not matter which end you plug into the computer or monitor but you should plug it inot the green, line out socket on your motherboard/sound car.
Hope this helps
ElApe
Posted on Oct 26, 2008
New 50" hisense tv .. unable to use hdmi for cable box .. tried different cables and all 3 hdmi outlets on tv ????
There might be a setting on your cable box for audio output. Use the cable remote and look in the audio section of the settings menu and select HDMI output. Mine is under Audio Digital Output in the Audio/Video menu.
Feb 21, 2015 | Hisense 50 Class 1080p LED Smart HDTV -...
Toshiba laptop screen out, what cable is used to hookup to external monitor
You can use a VGA cable to connect the VGA out port of your laptop to externel monitor.
If your Laptop and Monitor has HDMI port, you may use that.
Dec 15, 2013 | Toshiba SATELLITE L755-S5214 15.6"...
HOW TO HOOK UP THE PANASONIC AG-7750 TO FLAT SCREEN TV
Look for Panasonic AG-7750 Video Monitor Out at the back panel , then
• connect the BNC connector with cable
• and the other end to your appopriate vacant Flat TV Analog video Input.
For the audio, is just the same .
• Panasonic audio Out to your Flat TV Analog audio In.
Jul 31, 2012 | Televison & Video
How to connect laptop to Panasonic TV LCD TX-L42U2B
Laptop to TV hookup all depends on what the laptop has for output to a monitor and what the TV has for input. Your laptop should have a monitor output, a 15 pin female jack. You need a cable (male to male) with these 15 pin connectors at each end to hookup to a TV with a PC input jack. For the audio, use a 3.5mm stereo audio cable. Hookup from earphone out on the laptop to the TVs PC audio input jack. If the TV has no PC input jacks, there are other ways to connect. See this link:
http://columbiaisa.50webs.com/laptop_to_tv.htm
May 18, 2011 | Televison & Video
How do i connect my pc to my LG 32LF77SO I CAN GET SOUND AND VISION
Most HDTVs today have a 15-pin VGA input so to hookup a PC, just connect a VGA monitor cable from the PC monitor output to the HDTV VGA input port. This gives you video. For audio, you can connect a stereo audio cable (3.5mm) from the PC soundcard speaker jack (usually green) to the HDTVs audio input port next to the VGA port. Next you need to adjust the settings for video resolution and refresh rate on the PC so that the HDTV is compatible. Look in the HDTVs owner's manual for a chart showing the acceptable video screen resolutions (1024 X 768) and refresh rates and adjust the PC accordingly. You should now have video and audio on the TV. For a laptop, it depends on what outputs it has, VGA, HDMI or S-Video but this can be done as well.
Mar 26, 2011 | LG Televison & Video
How do I connect my hdtv cable box to the tv/monitor. There is no hdmi input on the tv.
Your setup has a TV/Monitor and a audio/video box. The A/V box is connected to the TV and other source inputs connect to the A/V box. Hookup your cable box to the A/V box either using component video (green, blue, red) RCA cables from cable box outputs to the A/V box inputs OR the A/V box also has a DVI/HDMI input jack which may work using a HDMI cable.
Select the proper source.
Aug 26, 2010 | Initial DTV372 37 in. HD-Ready LCD TV/DVD...
Digital audio doesn't seem to be detected. I've got directTv hp, and two dvd players hooked up. The input mode is Auto. When DP or analog, no sound comes out. when Auto, I get background noises, but no...
Optical cable from DVR or DVD to receiver. TV to monitor out. Digital audio is only through optical hookup. Then hook your mic up and run the YPAO and set to auto to run the sound basic set up then when done, go back a fiddle with the manual set up and turn up speaker volume, set sound modes, etc
Jul 27, 2010 | Yamaha HTR-5790 Receiver
Coaxial cable
Most newr TV's do not come with a coaxial hookup anymore, you either need to use RCA cables for Audio and Video, Component Video, S-Video Jack, Digital Audio Jack or HDMI Input.
Jun 16, 2010 | Protron PLTV-32 Television
DVI CABLE AND AUDIO CABLE. NO EXPLAINATION OF HOOKUP OR USE
Plug the audio cable into the LIME GREEN port on the computer.
You can onlly use a DVI cable if your Video Card has that kind of connector.
Trust me, you don't need one. Use the D-shaped 15 pin connector.
Feb 09, 2009 | Soyo DYLM24D6 LCD Monitor
No audio after hooking up RX-V363 to TV monitor (from cable box )
The HDMI on the RX-v363 does not pass the audio.  You need to either connect an optical or digital cable from your audio source.  If it is a cable box or DVD player there should be audio outputs in addition to HDMI
Dec 24, 2008 | Yamaha RX-V463 Receiver
Hannspree 19" Widescreen LCD Flat Panel Monitor Logo
1,633 people viewed this question
Top Hannspree Computers & Internet Experts
tomar33
 Chuck N
Chuck N
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
