Question about Breville Food Mixers
Stopped working its not spinning - Breville Food Mixers
KitchenAid Mixer struggling to spin?
Check everything you have done for a mistake, the pin through the planetary, the pin through the fuse gear and the pin in the main shaft that drives the bevel gear. That's the gear that pinion gear on the fuse gear shaft mates with. After that you are left with a fuse gear fault. I am assuming that the motor is turning at normal speeds and not somehow binding up, no reason why it should as motor stays in one piece during gear changing procedure.
Apr 18, 2014 | KitchenAid Food Mixers
My bowl spins so fast that the ingredients flu out of the bowl
The bowl is not supposed to spin, it locks into the base of the pedestal. Engage the lugs and turn it one way to lock it up.
Mar 30, 2014 | KitchenAid Classic Stand Mixer
Mixmaster mx001
Refer this issue directly to Mixmaster.
Mar 04, 2014 | Food Mixers
Hi there, I was doing cake mixing and turn off
If you can hear the motor spinning and the beater does not spin, the worm gear has probably failed. These fail frequently, specially after using them beyond there designed limits. The motor heats up and the gear, which is a type of plastic or nylon, melts.
Feb 18, 2011 | KitchenAid KSM150PS Artisan Series Stand...
My handmixer suddenly stopped working while i was
sounds like the beater is not all the way in or it broke a gear
Mar 12, 2009 | Braun M880 MultiMix Hand Mixer
Food Processor stopped spinning
sounds like you may have stripped the gear that drives , or thrown teeth off the cog.
Jan 25, 2009 | Kenwood Food Mixers
Food Mixers Logo
Top Breville Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Breville Food Mixer Expert? Answer questions, earn points and help others
