Question about Belling BE808 Compact Refrigerator
The door has dropped on my belling be808 fridge how do i adjust it
Is there any adjustment screws so i can raise the door so it shuts properly
How do I raise the level of my refrigerator door to be even with freezer door?
Thank you for your inquiry, Leland Dodd!
I see that you are having difficulty in raising the level on your Frigidaire refrigerator, FGHC2331PF. I have reviewed your manual and there are two types of adjustment for either front rollers or lower hinge. If you are having issues with adjusting the doors or leveling your refrigerator I would recommend having a professional technician out to properly level your refrigerator. Best of luck! -Matt
Dec 03, 2014 | Frigidaire FGHC2331PF Gallery 23 Cu. Ft....
Lido oven door doesn't shut properly
the door should have an area where you can adjust the door, either on the bottom or sides where the screws/hinges are. By tightening or loosening the screws in the hinge it should adjust the doors fit. If that doesn't help there is also insulation seal that sometimes is incorrectly installed. Your door lock(s) could be stuck. There are several different parts that come into play here and it's hard to know what exactly you're seeing wrong. Have you tried your care book, the trouble shooting tips in the back or you can contact the manufacturer by either email or phone and explain your situation. If they installed it they need to come and fix it. If you could send a photo that would help a great deal.
Sep 13, 2014 | Ovens
Stop alarm beeping
If you had a model number (on a sticker inside the fridge), there's probably a manual online that tells how to adjust the door.
Dec 28, 2013 | Kenmore Refrigerators
Freezer door does'nt shut all the way
If you notice one side of your Maytag side-by-side refrigerator is significantly higher than the other, you might want to raise or lower one of the doors. The refrigerator door is configured at the factory to be slightly higher than the freezer door. The weight of items on the door shelves sometimes cause the doors to sag slightly inward. Making a small adjustment to the freezer door leveling screws will correct minor amounts of sagging.
Things You'll Need3/8-inch hex head screwdriver 1
Position the refrigerator in the place you plan to keep it, and make sure the refrigerator is level front to back and side to side with a spirit level.
  • 2 Remove the base grille, located below the doors, by pulling from the sides. The leveling screws will be visible when the grille is removed.
  • Read more: How to Adjust the Maytag Freezer Door ' eHow.com http://www.ehow.com/how_12111048_adjust-maytag-freezer-door.html#ixzz1txsYiGQa
    Read more: How to Adjust the Maytag Freezer Door ' eHow.com http://www.ehow.com/how_12111048_adjust-maytag-freezer-door.html#ixzz1txrg7UOa
    May 04, 2012 | Maytag MFI2568AE Side by Side French Door...
    Need to raise door on side by side refrigerator so that doors are even and right side door stays shut. Where is the adjustment screw/area?
    You will have to loosen the screws at the top of both doors and move them to where they need to be and then retighten them.It helps if you have two people. Hope this helped and thank you for using Fix ya
    Jun 19, 2011 | Whirlpool ED5FHEXMQ Side by Side...
    Both the freezer and fridge doors hinge on the right, and the left hand side has sagged a little so neither neither door is sealing properly. How do I adjust the doors to raise the left side of the...
    The lower hinge on each door may have a door closing cam. It raises the door up ΒΌ inch when opening and this assist in closing the door. If it's wore out and doesn't work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
    Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
    Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
    May 04, 2011 | Refrigerators
    Bottom door drags on the bottom right corner. how to ajust to even the door out to shut properly?
    Loosen the screws on the top usually under a plastic cap that comes off to expose the hinge there will be 3 then move the door around and retighten them. If it needs to be adjusted up the easiest way is to remove the top hinge and then pick straight up on the door it will come off the bottom hinge look for plastic washers on top and bottom remember where they go you can add a couple metal washers on the bottom hinge then put the plastic one back on this will raise the door slightly. You can order plastic washers or even get brass ones from a hardware store they work fine. good luck
    Aug 10, 2010 | Frigidaire Refrigerators
    Whirlpool gold side by side..
    firstly,there is no spring.second,have you checked that the unit is sited on a flat surface (use a spirit level),lastly once all the above are done,you have 2 adjusters under the front of the unit to raise the front (slightly) so that when you open the door 90 degrees and let go it shuts itself........(dont forget to check door seals are tight all round after adjustment using your fingers to pull/push into shape. ...do not park unit touching the wall at the back,causes vibration....
    anything else ??? reply to me.
    Apr 14, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
    Fridge door will not stay shut
    Glenn,
    Easy... The door alignment adjustment is done at the top hinge. Pull up a step-stool, then remove the hinge cover. Under there you'll see three screws, I think they're 5/16". Loosen these (since your door has dropped, they're probably already loose), then lift up on the door handle to align it with the other door... while keeping the door aligned, tighten the hinge screws (and put alot of torque on 'em to keep 'em from loosening in the future). Now just replace the hinge cover and your done!
    SG
    May 26, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
    I have a Magic Chef refrigerator Model CTB1925GR and I need to adjust the freezer door(raise it on the right so that it seals properly
    On the top of the refrigerator is an adjustable hinge. You may have to pop of a cover plate to access the screws to loosen, make your adjustment and re-tighten.
    May 17, 2008 | Magic Chef Refrigerators
    Belling BE808 Compact Refrigerator Logo
    Top Belling Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    Andrew Taylor
    Andrew Taylor
    Nater13
    Are you a Belling Refrigerator Expert? Answer questions, earn points and help others
