Question about Miele Washing Machines
Miele fault F51
W1714
2 Suggested Answers
richroth
  • 9472 Answers
SOURCE: 'washing machine miele w1714 lock on Message demo programme how i do unlock?
Demonstration Mode (Dealer Displays)
Initial requirements
- Switch off the machine.
- Close the door.
Note
Once you begin the access procedure, it must be completed within
10 seconds.
Accessing
1. Press and hold the Start Button while switching the unit on with
the On/Off Button.
2. As soon as the Start LED lights up, release the Start Button.
3. Immediately press and hold the Start Button, until the Start
LED turns off.
Deactivation
Repeat the accessing procedure.
Note
The Demonstration Mode is NOT deactivated when the power is
shut off with the On/Off Button, or by unplugging the appliance.
Posted on Nov 04, 2012
Miele washing machine W3725 is coming up with Technical fault F51 ?
F51: Pressure Sensor
Symptom
In the operating mode, the display indicates Technical fault.
The program is stopped, the water intake valve is closed, and the drain pump is
switched on for 120 seconds.
Cause
Electrical defect in analog pressure sensor (ADS). The values are out of range.
x
Note
The pressure sensor is integrated into the power/program electronic (ELP)
This will usually require a professional to repair.
Dec 10, 2016 | Miele Washing Machines
Tip
Miele W1613 Drain fault and code F51
My machine limped along for a few weeks with an intermittent drain fault and then threw in code F51 occasionally. The F51 code is a water inlet fault, suggesting that water isn't filling the drum to the correct level. Clearly the first thing you need to do with these faults is check the obvious.
Drain fault:
Is the drain hose and drain filter clear?
Does the pump sound like it's running?
Is water actually being emptied?
F51:
Is inlet water pressure ok?
Is the inlet water filter clear?
Is water actually filling the drum?
In my case there was no suggestion of an obvious fault. So what makes the machine think there's a problem with water entering AND leaving the drum? It's the water level pressure sensor. The sensor itself is at the top of the machine, but a pipe connects it (via a small plastic chamber) to the very bottom of the tub. Water entering the tub rises in the pipe, thereby altering the pressure of trapped air and telling the machine when to stop filling or draining.
After dismantling the machine and removing the big hose connecting the bottom of the tub to the pump the sensor pipe is visible through the hose hole, which is quite large. So this pipe is in a good spot for collecting gunge and if it gets blocked it's a problem. Clean it out with an old toothbrush or whatever, while trying not to push it further up the pipe.
You should get some compensation for this effort when you empty the coins out of the hose you removed!
So I said 'after dismantling the machine' like it was child's play. It is pretty easy actually.
Open the door. Disconnect power.
Start with the lid. Two screws at rear, one each side under screw covers. Grip lid at front and lift up. It can be a bit stuck so give it a tug.
Remove powder draw.
Lift control panel away from front panel and lay on top of machine. You don't need to disconnect anything. Now you'll see the top of the sensor pipe.
Remove drain filter to empty any water in the bottom hose.
Remove - two screws at the top of the front panel, two screws either side of the door lock, one screw just below the door.
Lift the front panel off of the retaining pegs and pull away as far as the door seal will allow. Pulling away the top of the sensor pipe gives a bit more movement.
Now you can either remove the door seal and take off the front panel, or do as I did, which is just move it slightly to the side, giving access to the screws of the left hand side panel. Remove all screws for the left panel and it's easy to get off.
Now you have good access to the pump and bottom hose. The bottom hose has two clips on the tub end, but only the top clip needs loosening to remove from the tub.
Remember to mop up any water from the bottom tray when finished or you'll get a flood fault.
on Oct 10, 2014 | Miele Washing Machines
Error code f51 flashing. What's wrong?
David: Try downloading this free user manual: http://laundry.manualsonline.com/manuals/mfg/miele/pw_6065.htmlk According to ApplianceHelponline.: " Heater pressure switch The program is interrupted and the drain pump is operated. The display shows Technical fault F51. Call Service Department. The buzzer is activated for 2 minutes.
Background information:
Start position: One second after the program start, heater relay K1/1 is activated. This enables a check as to whether the contacts on heater pressure switch B1/13 have closed on switching steps 21/22 or 11/12.
Cause:
Heater relay defective; contact open.
Remedy:
Replace the heater relay.
Cause:
Heater relay solenoid defective.
Remedy:
Cause:
Connection from heater relay to electronic module open-circuited.
Remedy:
1. Check plug connections.
2. Check the connection wires for continuity.
Cause:
Heater pressure switch open- or short-circuited.
Remedy:
Replace the heater pressure switch.
Cause:
Connection from heater pressure switch to electronic open-circuited.
Remedy:
Cause:
Foreign objects in heater pressure switch.
Remedy:
Replace the heater pressure switch."
May 14, 2015 | Miele Washing Machines
What is Technical Fault 51? It appeared a few moments ago on our machine, but when I switched it off and reset the machine it worked as normal again.
F51 Heater pressure switch The program is interrupted and the drain pump is operated. The display shows Technical fault F51. Call Service Department. The buzzer is activated for 2 minutes.
Cause:
Remedy:
Cause:
Remedy:
Cause:
Remedy:
Cause:
Remedy:
Cause:
Remedy:
Cause:
Remedy:
Apr 14, 2015 | Miele Washing Machines
- Close the door.
Note
10 seconds.
Accessing
the On/Off Button.
LED turns off.
Deactivation
Note
Nov 04, 2012 | Washing Machines
F11 blocked inlet/drain
f11 error code says in the manual
Drainage fault
Water present in appliance and is not being drained off. The display shows
Drain fault F11. The buzzer is activated for 2 minutes.
After each drain pump step, the circulation pump operates for 2 seconds and heater pressure switch B1/13 checks the water level. If it is too high (large quantity of residual water remaining in the cabinet), the drainage time is extended. If, after a further check, the water level is still too high, then the program is interrupted, the fault code is saved and the drain pump is activated. Fault code F11 is also registered if heater relay 1K1 is not activated after the fault code F51 register check; see Section 080-3.18. Drain hose kinked. Remedy: Check the drain hose for correct positioning. Cause: Drain blocked.
Remedy:
1. Clean the on-site drain.
2. Check the sump drain.
3. Check the filters.
4. Check the heater pressure switch and replace it if necessary.
Cause:
Ball in non-return valve in sump has not opened (e.g., jammed).
Remedy:
Clean the non-return valve in the sump or replace it if necessary. Cause: Foreign objects in the drain pump.
Remedy:
Clean the drain pump and its impeller.
Cause:
Drain pump defective.
Remedy:
1. Check the voltage supply to the drain pump.
2. If correct voltage is present, check the drain pump motor winding.
3. Replace the drain pump, if necessary.
Cause:
Remedy:
Check the heater pressure switch for blockages and correct switching point.
Cause:
Heater relay defective. Heater relay (coil or contacts) becomes defective during the drainage step (after fault code F51 register check).
Remedy:
this is usually caused by a blockage in the drain but can also occur from other circumstances as listed above you can also see this at this link as well http://appliancehelponline.com/miele.html
if you have any further questions message me back and please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future Thanks again Rick
Jun 07, 2011 | Miele Dishwashers
How do I fix a F53 fault ona Miele W1712 Washing Machine
A call with the Miele tech helpdesk got me an answer: The tacho unit (coil) should have about 500 Ohm resistance, so they told me. My unit only had about 78 Ohm's, so I ordered a new brush unit (which includes the tacho). The new unit actually measures 250 Ohm, but since it was a new one I did fit it. It works like a charm again. No F53 fault code anymore.
The part no. is 6799642 - Module BSTV Mrt40 RK473. It cost me about 70 euro's including shipping. My machine is a type W3821, but the motor and brush unit with tacho is used on a variaty of models.
Cheers!
May 01, 2011 | Miele W1926A Front Load Washer
Getting a F51 message
F51
Start position:
Cause:
Remedy:
Cause:
Remedy:
Cause:
Remedy:
Cause:
Remedy:
Cause:
Remedy:
Cause:
Remedy:
if you have any further questions message me back and please remember to rank this opinion it allows me to help people in similar situations in the future Thanks again Rick
Jan 23, 2011 | Miele Dishwashers
Miele Dishwasher does not start
hi,
F51 fault is more than likely the heater relay is faulty but it could be your circulation pump is jammed up. if you are confident you can easily replace the replace the relay if it is faulty. you would need to put a meter across the terminals. if it is ok then the pump is blocked. if you are not confident you would require a service call. Miele have there own deadicated service team if you live in a metro area
hope this helps.
Mar 30, 2010 | Miele G892SC SS Dishwasher
When dishwasher turned on 3 yellow bars light up and indicator shows f51
F51 Refers to Pressure Switch not Sensing Properly. First, you need to Power OFF the dishwasher. Wait for Few Minutes and then Turn it ON. If problem still persists, more often you need to replace Pressure Switch.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 31, 2009 | Miele Dishwashers
Washing Machines Logo
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
