Question about Freezers
F14 fault on gram freezer
Fault f14 showing and not getting to correct temp. Any idears out there
SOURCE: aeg fault codes
i have this when the cooler at the top freezes completely you need to turn it off and defrost it.
Posted on Oct 27, 2008
  • 389 Answers
SOURCE: Bosch Fridge Freezer KGU3200GB/01 alarm beeping temp rising
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Posted on Apr 21, 2010
heatman101
  • 43501 Answers
SOURCE: Prestige PRT325FFCS fridge freezer. the fridge
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 28, 2010
  • 670 Answers
SOURCE: Hotpoint freezer, High temp light on & all food thawing
It's probably the defrost timer is getting stuck in the defrost mode. What it does it it periodically interrupts power to the compressor and sends power to the defrost coils to allow any frost on the cooling coils to melt to keep them clear of ice build up. This is typically a mechanical timer and sometimes the motor fails and it stop turning and if it fails in the defrost mode, the compressor never turns back on no matter how warm the freezer is.
You can confirm it is the timer, by tracing the wires from the compressor to a little 2 by 2 inch box which is the timer. On one side there should be a round hole with a plastic cam. You should be able to turn that cam with a flat screw driver or a coin. Just give it a slight turn until you hear a click. After you turned the cam, the compressor should start. If it does, then it is the timer.
Posted on Jul 01, 2010
baraquielnar
  • 247 Answers
SOURCE: Our LG American style fridge freezer not reaching
try to check refrigerant charge if in correct according to its labelled. try to relocate your unit maybe the location near to heating appliance or the circulation of air on condenser is not good try to clean condenser if dusty.
Posted on Feb 04, 2011
P-1 code is flashing on temperature display
P1 is almost always a fault on the sensing (control) probe. Check it's end is not wet or covered in thick ice, and check the connections at the controller. If you can, change the probe connections on the controller temporarily. If P2 then shows it proves the probe is faulty. If P1 still shows, it proves the controller is at fault.
Apr 20, 2012 | True 72 cu. ft. / 2039 liter Commercial...
Our LG American style fridge freezer not reaching required temp. Model no. GWB227YVQA - had engineer to look who could find no fault and thinks compressor has gone or system fault. It is only just 3 years...
Feb 04, 2011 | Freezers
MY FREEZER5 ALARM GOES OFF BUT THE FREEZER IS RUNN[NG AND THE TEMP IS 32 o
Fault in the controller board as it must be tripping off the alarm without the sensor giving the signal.
You will need to check the conttroller board for sorting out , other wise just disconnect the alarm as the freezer working and the thermostat is controlling the temperature correctly
Sep 06, 2010 | Maytag 15.6 cu. ft. Upright Freezer...
Got zanussi whirpool upright freezer afg8080/1x temperature gone to high is it worth getting repaired or buy a new one? freezer has been making a cliking noise and food is starting to defrost
if the freezer is over 5 years old,buy a new one under counter freezers not built in are fairly inexpensive and will cost less to run.fault sounds like temp sensor....
cheap part/labour intensive.....
Feb 13, 2010 | Zanussi 3.53 cu. ft. / 100 liter Upright...
Jan 26, 2010 | Freezers
Kenmore Freezer Temp. Alarm
You should get a thermometer to be sure the temp is what it should be. With out it is very hard to tell correct temp.
Aug 05, 2017 | Freezers
Aeg fault codes
aeg santo fridge/ freezer
The fridge part of my appliance is not getting cold please help
Apr 13, 2008 | AEG 10.35 cu. ft. / 293 liter Upright...
Indesit fridge freezer (2 years old) not getting cold
if compressor is running, then you are correct in saying no point in replacing stat. by sounds of it you have a faulty compressor fault or a syatem fault - impossible to dignose by remotely. this is not a diy job i'm afraid
Jul 14, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Freezers Logo
55 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
