Question about Proform Exercise & Fitness
Proform 585 CSE Elliptical will not shut down: Have a proform 585 cse elliptical, unit will not shut off entirely when pedals are no longer moving. Motor buzzes quietly then louder with time. Will sap batteries eventually.
  • 103 Answers
SOURCE: Have proform 850 elliptical, unit jerks at bottom of travel
This is caused by a loose crank arm. The key assembly is loose. (#32 on your parts list) The covers will need to be removed to access this. Be sure the crank arms are realigned against the frame when completing the repair. Good luck, Tim
Posted on Nov 13, 2009
SOURCE: My Proform elliptical is not working
clarification: when I get on the stepper there is not resistance. I'll get to a point when my feet will bascially fall right around....like something is loose or broken
Posted on Feb 10, 2010
SOURCE: I have a ProForm 900 Elliptical machine. The back
proform resistance is slipping
Posted on Mar 07, 2010
maxtreadmill
  • 832 Answers
SOURCE: is there a user manual for crosstrainer 470
Go to iconservice.com click on manual input manufacturer then this model # PFEVEL27860
Posted on May 18, 2010
  • 10865 Answers
SOURCE: How do I get a manual for a Proform 6.0 ZE
hello dkb. go to this link, select your model and down load the manual
http://www.proform.com/webapp/wcs/stores/servlet/Help_-1_14201_16002
Joe
Posted on Apr 20, 2011
We folded the Proform 500 LE Elliptical and moved it. Now we are unable to unfold the elliptical with the latch button. Suggestions?
HOW TO FOLD AND UNFOLD THE ELLIPTICAL
When the elliptical is not in use, the frame can be folded out of the way. First, lift the latch under each pedal arm, and lift the pedal arms off the adjustment sleeves on the crank arms.
Next, raise the pedal arms until they touch the magnets on the upper body legs; the magnets will hold the pedal arms in place.
Then, hold the handle and lift the frame until it locks in a vertical position. To use the elliptical, first hold the handle, press the latch button, and lower the frame.
Next, pull the pedal arms off the magnets on the upper body legs.
Then, lift the latches under the pedal arms, and set the pedal arms on the adjustment sleeves on the crank arms.
Release the latches, and make sure that the pedal arms are securely connected to the adjustment sleeves.
Will be attaching a link to your manual also
http://www.sportsmith.net/images/product_support/ProForm/PFEVEL959101%20-%20PROFORM%20500%20ZLE%20ELLIPTICAL/PFEVEL95910.1-307585.pdf
May 25, 2015 | Proform Exercise & Fitness
Elliptical makes grinding noise every time right foot goes down
It can be a couple of things 1) the stair arm wheel has bad bearings. You can switch the right and left wheels to see if the problem follows the wheels. 2) make sure the ramp the wheels ride on is clean and it helps to use a clear silicone gel applied lightly on the ramps. 3) if the noise is from inside the front it is likely bearing related but can also be a belt with wear. What type of nose? Is it cyclic? Does speed and resistance change the sound? Does it get louder of quieter as the workout progresses?
Sep 06, 2014 | Proform 585 CSE Elliptical Trainer...
I have a 390 proform Elliptical and it's is locked up. When I get on it, the pedals are tight and I can not move them.
There may be a problem with the belt inside the machine.
It has to be taken apart to assess.
Jul 14, 2013 | Proform 395 E Elliptical
My 390 E is locked up and I can't move the pedals. I checked the belt, it's still on and it's tight.
follow this steps and fix it. God bless you
Electronics Problem You control the tension of the pedals using the buttons on the console. When you assemble the A.C.T. elliptical, you have to thread a group of wires from the console through the upright down to the electronics board. These wires communicate the resistance settings to the electronics board. If the wires twist, disconnect or break, the resistance will not work. You will need to reconnect or replace the wires.
Read more: http://www.livestrong.com/article/406522-tension-problems-with-the-nordictrack-a-c-t-elliptical/#ixzz2Z4kLeLBm
Jul 14, 2013 | Proform PFTL79807 - 850 W/ Gamefit...
I am getting very frustrated, i want a owners manual for a proform elliptical 6.0 ez
Go to website from Proform: www. proform. com
then go customer service , then go to part& manual give you model, serial number and download free you user or owner manual and Ready!
SINCERELY.
e.cuadra
managua, nicaragua. c.a.
Oct 16, 2011 | Proform PFTL79807 - 850 W/ Gamefit...
My proform 2605 elliptical the right foot pedal is making a loud noise like it's slipping.
Detachthe ends of the pedals from the crank axles. Spread a layer of machine greaseover the crank axles, then reattach the ends of the pedals.2
Removethe bolts connecting the pedals to the swing arms. Detach the pedals from thearms, then spread a layer of machine grease over the axles on the swing arms.On some models, the bolts may also serve as the axles. Reattach the pedals tothe arms.3
Removethe bolts connecting the swing arms to the elliptical's upright. Detach theswing arms from the upright, then spread a layer of machine grease over theaxles on the upright. Reattach the arms to the upright.
Oct 01, 2011 | Proform PFTL79807 - 850 W/ Gamefit...
How to use the Proform 515S EKG Elliptical?
To mount the elliptical trainer, firmly hold the handlebars or the T-handle and carefully step onto the pedal that is in the lowest position. Next, step onto the other pedal. Push the pedals until they begin to move with a continuous motion. Note: The pedal disks can turn in either direction. It is recommended that you turn the pedal disks in the direction shown below; however, to give variety to your exercise, you may choose to turn the pedal disks in the opposite direction.
To dismount the elliptical trainer, allow the pedals to come to a complete stop. CAUTION: The elliptical trainer does not have a free wheel; the pedals will continue to move until the flywheel stops. When the pedals are stationary, step off the highest pedal first. Then, step off the lowest pedal.
As you exercise, you can adjust the resistance of the pedals with the resistance knob on the console. To increase the resistance, turn the knob clockwise; to decrease the resistance, turn the knob counterclockwise.
Jun 02, 2010 | Proform Exercise & Fitness
After replacing batteries on Proform PF800 console stays lit
Pull the batteries out let it reset itself while its doing that check all cable to make the connection are seated firmly then reinstall the batteries, unless the function pad is sending a phantom signal engaging the display to be on continuously,or by pure chance the upper electronics went hay wire
Apr 09, 2010 | Proform PFTL79807 - 850 W/ Gamefit...
Nov 10, 2009 | Proform PFTL79807 - 850 W/ Gamefit...
Exercise & Fitness Logo
Top Proform Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Owen Barnes
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
