My epson stylus SX405 doesnt like 250gsm card that I use to make greeting cards It wont feed unless I put weight on and even then it doesnt always take it in properly
  • eveycol Jan 16, 2009
    my epson sx 405 wont accept any type of card for making invitations on card. please help
  • 4809 Answers
SOURCE: My Epson Stylus SX515W won't feed 250gsm greetings
Epson recommends you use Epson media if a third-party heavy (card stock) media has feed problems.
The printer (depending on the model) should be able to take 255 g/m2 or 300 g/m2 genuine Epson media.
I wish that I could be of more helps.
Posted on May 14, 2010
Lost the cd to install my epson stylus sx405
Driver Epson stylus sx405, you can download here Epson Driver & Software (for Epson Stylus SX405)
Follow link, and select your operating system.
Sep 24, 2011 | Computers & Internet
My Epson Stylus SX515W won't feed 250gsm greetings cards, even if I help them a bit! My old Colour 680 worked fine.
May 14, 2010 | Epson Office Equipment & Supplies
Epson sx405 all in one won`t print!
Please re-install the drivers, and follow the instructions as given, you will forge ahead
Mar 17, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Epson R300
First of all turn the printer off & disconnect all of the cables. Turn it over and give it a shake, you'll be amazed at what gets inside the feed hopper. Next try a stiff piece of A4 card (the backing from an A4 notepad for instance), feed the card into the paper feed and push it through quite hard to overcome the spring resistence. Once it has started to go through open the lid and check if it has pushed anything through the rollers. Feed the card all the way through the mech and pull out of the front. Hopefully the card will have cleared the paper path of any objects and reseated the sensors.
Good luck.
Mar 12, 2009 | Epson Stylus Photo R300 InkJet Printer
Not printing on card
preciso do reset da r 220 por favor alguém me ajude um abraço
Aug 01, 2008 | Epson Stylus Photo R220 InkJet Printer
Won't feed paper
when you say ''heavy weight'' do you mean thin card etc.
Most printers dont like to use thicker paper. does it make a noise. like gears slipping or crunching when it is trying to feed. if this is the case, then the feed gears maybe worn.
Feb 04, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus DX6000
There might be some problem with the Roller. I think you have to locate and clean the roller.
Nov 24, 2007 | Office Equipment & Supplies
150 people viewed this question
k24674
