Question about GE Profile PSC25PSWSS Stainless Steel Side by Side Refrigerator
Ice cube tray melts and refreezes
I had a problem with water dripping from the ice maker area. I shut off the ice maker and emptied it out. I started adding ice manually to the ice storage container instead of using the maker. I noticed a few days after adding the ice cubes in the storage bin, that a large icicle about 4 inches in diameter was created inside the freezer. I broke the ice storage out and noticed the ice was melted and refrozen. I removed the ice and have no ice in the storage bin. The ice maker was still in the off position and did not have any water in it. So the only source of the water was the ice storage bin melting and refreezing. I actually thought the problem was the ice maker and now I don't think so. Please help
4 Suggested Answers
SOURCE: Ice cubes melting then refreezing in clumps
check the flap door to see if it is slightly open letting warm air in
Posted on Aug 10, 2008
tech master
  • 120 Answers
SOURCE: My GE Profile makes ice but then the ice cubes melt!
repl main board and make sure your out let is properly wired and grounded those main boards are sensitive when not grounded
Posted on Oct 31, 2008
SOURCE: Symptoms: Ice cubes melt, drip then refreeze causing
are you having any cooling problems? take a look at your ice cream, if you have any. does it look like it has melted and refrozen? if so, you have a cooling problem, and that is causing ice to melt, then refreeze. if you have no cooling problems, then you may have a faulty water valve solenoid, or even a faulty icemaker.
Posted on Feb 15, 2010
Sometimes ice melts in ice maker. Water drips down and refreezes.
There is a heater built into the ice maker bottom to help release ice cubes from the machine. Under normal conditions the heater only come on when the ice maker starts to run and then jambs against the frozen cubes. When it stalls and jambs against the frozen ice cubes, the heater comes on to melt the cubes enough. I think you have a defective ice maker and the heater is coming on to much or at the wrong time, Since your temps go back to normal with the ice maker turned off, I am almost sure thats your problem.
Mar 16, 2015 | GE Profile PSC25MSWSS Stainless Steel...
Ice maker quit working but water dispenser still works,the reservoir to make cubes also empty.can you advise?
If the ice maker tray is empty you may have a water valve failure. usually this unit have a dual valve 1 for the dispenser the other one for the ice maker some time a side fail and the entire solenoid have to be replace. the ice maker can also be bad. an easy way for you to test if ice maker is good is by putting water manually inside the ice maker tray depending on how cold is your frig wait about 2 hrs or less if the ice maker cycles and drop ice then water solenoid is the problem if not then replace ice maker.
Dec 20, 2014 | KitchenAid Refrigerators
Frozen solid cube tray
Unplug the frig. Take a hair dryer and melt the ice tray. Then get a paper towel and soak up the left over water. hope this helped
Mar 30, 2010 | Refrigerators
Feb 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice freezes into one solid block and won't dump out of the tray
remove cube tray from ice maker. clean with limeaway adn rinse. Spray with a light coating of PAM cooking spray. wipe dry and reinstall. be careful not to damage the sensor ( in center of tray)
Aug 26, 2009 | Samsung RS2578BB Side by Side Refrigerator
I have the exact same problem, curious if you have any answer...
If the ice melts in the ice maker I think something strange is going on with the heating element below the ice maker. It comes on only for a few seconds before the ice drops. And is used to loosen the ice. But if water continues to flow from the water control valve while the ice maker is full it has no where to go but into the freezer and refreeze. Sometimes the water control valves have trash buildup inside the valve and will not shut and allows the water to continue to flow. About the only way to solve that is replace the water control valve and place a pre-filter in the line before the water reaches the valve. Thanks, Sea Breeze
Aug 18, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ge Profile ice maker not working
you either have a bad water valve, which it is sticking open or B. the ice maker is not shutting the valve off.
Apr 12, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice Maker Stopped Making Ice & Cubes are Melting (rest of freezer is cold)
can you pull the cover off the ice maker to see if the gears are bad?let me know more-mike
Oct 12, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker freezes up and drips water
I am assuming you have the ice maker that the tray twists to release the ice. There is a new tray out with a wall to prevent the water spilling over. The part number is
3390JA1150A
Sgt 48
Mar 09, 2008 | LG LRSC26980 Refrigerator
Clumps of ice cubes in back of ice bucket
sounds like your just might not be using enough ice and they are defrosting and clumping together.figure your pulling ice from front of bucket the the backs hardly get used espescially in winter your not using as much ice. or ice maker is slightly over flilling water and dripping over rear of unit
Jan 20, 2008 | Amana ARB1905C Bottom Freezer Refrigerator
GE Profile  PSC25PSWSS Stainless Steel Side by Side Refrigerator Logo
67 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
