Question about Sony Grand WEGA KDF55E2000 55" Projection HDTV
KDF55E2000 6 blinks
Which board do I need to replace for this fix?
    Top Expert:
  • Sony Master
  • 74,377 Answers
Hello
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206
http://www.dataentryjobs.us/67948.html
Posted on Feb 19, 2012
2 Suggested Answers
  • 160 Answers
SOURCE: after replacing my bulb my sony kdf55e2000 tv is
You did not install lamp door correctly. It does not push on safety switch. Take your time and redo lamp replacement.
Posted on Mar 10, 2010
How do I fix an lg42ld450 tv that has a blinking red light and a blank screen?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Mar 30, 2016 | Televison & Video
Steady blinking green light on Mitsubishi LCD model LT 55164
I also have a Mitsubishi LT 55164 with blinking green status light...does nothing else...reset does no good, also tried to reload software with no difference. Replaced power and inverter boards button stop the same. No obvious bad components on boards. Help! Anyone ever actually fix one of these?
Aug 29, 2015 | Mitsubishi LT55164 55 in LCD TV
My LCD Panasonic TC-L42U12 blinks 14 times does some one have the Error code list to see what I need to fix?
13 blinks means a communication error on the A board (main board). The part number for the main board is TXN/A10PYHS. I would recommend TSM for a replacement board. Good warranty and price.
www.tristatemodule.com
Nov 04, 2013 | Panasonic TC-L42U12 LCD TV
Tv Wont Come on 3 red blinks pauses 3 red blinks pauses 3 red blinks
A 3 blink error on this model is saying that your lamp cover is not on properly. Check your lamp cover and door. Make sure they are seated sucurly. If this doesn't fix your problem. Then the switch or little board buy the lamp cover is bad and needs replaced. This is called the T board.
Mar 15, 2013 | Sony Kds-r60xbr2 60" Xbr Rear Projection...
Power indicator light blinks-7 times. will a new power supply fix it
Physically disconnect the SU board and the SD board. (See precaution # 5)
Plug in the TV and turn it on.
Does the TV shut down and the power LED
blink 7 times?
Yes
No
Replace the Panel and the SU board.
(See precaution #3)
Reconnect the SD board only.
Yes
No
With the SU board and the SD board still disconnected, remove connectors SC2 and SC20 from the SC board (See precaution # 6)
Disconnect the SD board and reconnect the SU board. (See precaution # 5)
Yes
No
Replace the Panel, SD, and SU board.
(See precaution #3)
Replace the Panel and the SD board.
(See precaution #3)
Replace the SC board.
(See precaution #3)
No
Replace the D board.
(See precaution #3)
blink 7 times?
blink 7 times?
blink 7
There is a sequence that you have to check to figure out which board is bad,
Feb 16, 2011 | Panasonic TH-42PZ700U 42 in. Plasma...
Tv wont turn on but blinks 9 times again and again
9 blinks is a ZCD error code (zero crossing detection) which means it is a bad g board. I had the same problem with this tv and have yet to fix it cause you cant find the board you need anywhere and most suppliers have boards that they fix themselves which only work for a month or 2 and then die. but you need to replace Replace D6301 on "G" board and d6116, d6117 i use 1n4148 for the little smt diodes, d6301 nte116 should suffice
it will be those few diodes and 15-20 caps on the am board if you choose to fix it yourself. here is a manual that lays everything out for you if you choose to fix it yourself. click here for repair manual
if you need further assistance please let me know and i will be glad to assist you from there. thanks and good luck
Aug 26, 2010 | Sony KP-46WT520 46" Rear Projection...
My tv will not turn on
CK for Bad capacitors on your Deflection Board its the bottom board on left hand side cp150 cp114 cp120/ if (cp150)- 2200uf 16v is puffed up on top It is Bad replace all 3 capacitors 220uf 35v is the other 2.
Jan 02, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Panasonic TH42PA20 - No Picture
If you have the flashing red light of death you can use the chart below to see what the blinks indicate and call Panasonic and have the part replaced, at the bottom of this page is the meaning of terms.
BLINKS PROBLEM MALFUNCTIONING PART
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
Panel = Plasma Display Panel (Plasma Glass)
D Board = Format Converter / Plasma AL / Sub-Field Processor
DG Board = AC-DC Converter / Digital Signal Processor / Full HD
Microcumputer HDMI Interface / Peaks Lite 2
H Board = Speaker Out / Sound Processor
AV Terminal / AV Switch
P Board = Power Supply
PB Board = Fan Control
SC Board = Scan Drive
SD Board = Scan Out (Lower)
SS Board = Sustain Drive
SU Board = Scan Out (Upper)
Apr 13, 2009 | Panasonic (TH-50PZ700U) Television
6 red blinking lights
6 lights according to the service manual is: LOW B ERROR B_12v IS NOT SUPPLIED (GT BOARD)
Check the connections to the boards, and if nothing seems obvious, you may need a repair person to replace this board...
Jul 14, 2008 | Sony KDS-R50XBR1 50" HDTV
Sony Grand WEGA KDF55E2000 55" Projection HDTV Logo
275 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
