Question about Canon i9900 InkJet Photo Printer
PAPER WON'T FEED ON I9900 CANON - Canon i9900 InkJet Photo Printer
  • 390 Answers
SOURCE: Canon i9900 blinking three orange / jam
uninstall it and reinstall it, hopefully it will reset itself then.
Posted on Sep 09, 2007
SOURCE: settings for printing a borderless 8x10 on a canon i9900
Downloaded following program for Vista and was able to print borderless pictures on Canoni9900
Easy-PhotoPrint EX Ver.2.0.3 (Windows Vista/Vista64/XP/2000)
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=232&modelid=9870#DownloadDetailAct
Posted on May 25, 2009
SOURCE: canon ip 2600 printer. Paper does not feed
Hey I had the same problem. Called the company; we couldn't fix it. Well I turned it upside down and a 2" flower stem fell out from when I cut some flowers next to my desk. It still didn't work. I was examining the feed area while it was running and I found another little piece of stem that was lodged way in there. I had to get it out with tweasers and it turned out to be 1" long. Couldn't really see it at all. Works fine now.
Posted on Nov 10, 2009
  • 739 Answers
SOURCE: The printer won't feed the
Hi Trevo
First, check the the paper guide in the feed tray is up against the edge of the paper. If it is not snug then the paper will skew.
If it is OK then check with a torch both sides of the paper path - where it goes in and where it comes out.
I've found bits in the path before now that are not seen at first.
This printer may have a removeable panel at the back where you can check a bit more easily.
Posted on May 25, 2011
Geekman
  • 32281 Answers
SOURCE: my canon pixma mx320
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Posted on Jul 26, 2011
Canon I9900. Why isn't it picking up paper?
check to see if nothing has fallen inside via the paper input from the top.you may have to open it.you might find an office pin or pen or its cock or any other thing that has fallen inside...a printer tech like me can solve this problem.
Jun 14, 2015 | Canon i9900 InkJet Photo Printer
My canon pixma mx320 won't feed paper properly it seems to grab one side of paper and feeds it crooked then stops
Jul 26, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
The machine won't print. It won't feed paper, The
Your machine needs to be serviced.
replace the cartridge with the original one.
it can not print if one cartridge is missing or not original.
Jul 12, 2011 | Canon Office Equipment & Supplies
Green light for paper feed isn't on and paper won't feed
paper start sensor is not functioning properly. clean it or replace it.
Jun 16, 2011 | Canon imageRUNNER 2200
Taking a canon i9900 printer apart to get jammed paper out
If you want online customer service, then connect with us at Canon Printer Tech Support Phone Number#1877-778-8@9@6@9 anytime as you like. For further information Click:https://goo.gl/ZYjDqq
Jul 28, 2010 | Canon i9900 InkJet Photo Printer
My canon i9900 says thatthere is a paper jam but i have opened it up, looked everywhere and there was nothing in it. i uplugged it, took out the battery and re-set. what else can it do?
Just a suggestion- you might have to disassemble it to the point where you can see the individual gears that run the paper roller. Sometimes when a paper jam occurs, the motor and gears are still trying to feed the paper, and a gear tooth will break or jam. In this case, the "brain" of the machine still thinks the paper is jammed, since it isn't feeding, and displays the paper jam message. If it's a broken tooth on a gear, you will have to find a replacement gear for it. I had this problem once, and found another discarded printer a friend had, and got the gear out of it. You might be able to get a replacement gear from an Authorized Canon Repair Facility- if you google that, you will have some places to try. Good luck, this is a common problem with the plastic gears they use.
Apr 17, 2010 | Canon i9900 InkJet Photo Printer
The printer prints fine on plain paper, but on
I'm not clear on your problem but you can try this<a href="http://www.richardsnotes.org/archives/2006/05/17/canon-i9900-printer-problem-and-solution/" >Link for simular problems.</a> You may find the solution there.
Nov 27, 2009 | Canon i9900 InkJet Photo Printer
Settings for printing a borderless 8x10 on a canon i9900
Mar 02, 2009 | Canon i9900 InkJet Photo Printer
I had the same problem with my i9900 - 3 orange flashes on the the error light (Paper Jam) and yet I could slip a sheet of paper in and it would feed through OK. My problem is that the SPRING on the PAPER SENSOR had come off, leaving the sensor in the where it would be if there was a paper jam.
You have to REMOVE the main cover of the printer to find and fix this problem You have to find all of the release points (look for triangles on the plastic covers) where you insert a small tool/screwdriver to (1) press 1 release each side & remove the 2 silver end panels, (2) press 1 release to remove the control switch & carefully disconnect the two connectors inside. Start with the triangle rlease on the lower front left of the main cover, then 1 on the left side, 3 on the back, 1 on the right side, and finally 1 on the lower front right side and gently lift the whole cover off.
You can then look inside with a flashlight from the top rear just behind the left side paper feed roller and see a small switch which pivots when paper is fed through the printer. Feed a sheet of paper and see if the spring is returning it to the normal (no jam) position. I used a long pair of tweezers to reach inside and slip the spring back into its normal position which is behind the small slot on the far right side of the switch. No pictures, but it should be intuitive where the spring should go. Once reinstalled, the switch will move back to the normal position and your paper jam should be fixed.
This SAME MECHANISM is also used in a number of other Canon i & ip series printers so this general approach to fixing this in other models could be the same - (1) remove the cover, (2) locate the switch, and (3) put the spring back into the correct positiion.
Aug 31, 2007 | Canon i9900 InkJet Photo Printer
Canon i9900 InkJet Photo Printer Logo
163 people viewed this question
old marine
old marine
