Question about Brother MFC 8500 All-In-One Laser Printer
Consistent paper jams
Whenever I try to print I get a paper jam. I have carefylly removed the jam but it is still hapening every time I try to print.As you face the machine the paper is jamming on the left hand side. The machine seems to take hold of the paper on the left only.I looked into the machine after removing the the drum to determine if I could see any pieces of paper that would cause the problem and found nothing. I used a flash light when doing this.
  • 64 Answers
If it's not a majore mechanicla problem then it might be a simple dirt problem. Make sure all ruber clips and rollers are clean, U can use some aerosol to clean them Good Luck
Posted on Aug 23, 2006
I own a canon MP210 printer. Recently a paper got jammed but I was able to get it out. Now, every time I try to print, it will only grab the paper but wont feed while printing and says "Paper Jam".
Some times when paper jams a printer it damages the sensors that continue the printing process. I suggest you revisit the area where the paper jam occurred and check for the tiniest particle still lingering between the rollers. Remove what rollers you can by hand and inspect the surfaces and alignment. Put them back in the order you removed them and try again to print.
Feb 19, 2018 | Canon Office Equipment & Supplies
When printing documents no matter how few or how many pages, paper gets stuck in the middle of printing.
Try using regular paper on unit as specified by Samsung. If that does not resolve the issue then the hassle lies with the paper feed mechanism. Often a good cleaning of all the rollers in the path can take care of the issue.
Aug 24, 2015 | Samsung ML 2525 BW laser Printer
2-side Paper Jam
Make sure you use 80gm plain paper.
Feb 21, 2014 | Brother International Brother HL-3170CDW
We have a Ricoh Aficio CL3500N and every time we print the paper jams and we get the "Remove Misfeed A: Internal Path". I remove the jam and when it tries to print again we get the same thing,...
There may be an obstruction inside the printer. Try this....remove the paper from the paper tray and put paper in the handfeed tray (front of the machine) If it feeds from that tray it means that the feed rollers in the bottom cassette are worn.
Dec 17, 2010 | Ricoh Aficio CL3500N Laser Printer
My Canon Pixma MP160 won't work :( It says there's paper jammed in the printer and it needs to be removed but there isn't anything there. . . HELP!!
Previously when you had tried to printing any paper the printer has adopted paper jammed error but at this time you have not turned off the system.The printer has configured paper jammed whenever you are trying to print.
It represents that it want to restart the system.
Unplug the printer and reconnect to your system.
Oct 16, 2010 | Canon PIXMA MP160 All-In-One InkJet...
HP LJ P3005 13.31.00 ERROR
As i can understand whenever you try to print with rear door closed printed page should come on top from top output roller however paper gets jammed.
Solution:
Try to print a page using rear door open and it should come out from the rear drop down tray it printed page comes out successfully with rear flap open than paper gets jammed at top due to faulty top output roller.
However if the paper gets jammed at fuser with rear door closed than it is issue with fuser in that case you need to get fuser replaced at the same time replace 20 tooth gear next to fuser.
Thanks and Regards
Neeraj Sharma
Apr 11, 2009 | HP LaserJet P3005n Printer
Paper Jam
try a test page..and see if that flows..
Aug 20, 2008 | HP LaserJet 2100 Printer
Paper jam
try another photopaper of less weight. It could be that the rubber of the paperfeeder is stained with paper dust.
What you also can try is:
take paper tray out.
use a sponge with a rough side (to clean very dirty pans) to scratch
along the grey rubber and to give the rubber more grip.
Mar 22, 2008 | Brother DCP 115C All-In-One InkJet Printer
Paper jam, when there's not a paper jam?
there is a small micro switch , when paper is loaded that switch
is activated, bent switch, paper shreds jamed in switch, will cause paper feed problem.
Jan 13, 2008 | Lexmark P4350 All-In-One InkJet Printer
Brother MFC 8500 All-In-One Laser Printer Logo
87 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
