Question about Samsung HP-S5053 Television
Samsung Flat Screen TX-T3093WH TV picture fading in and out
Picture goes from bright to almost black...like a sensor is off. When the picture is bright, it stays that way, but when the background darkens, the picture goes extremely dark.
  • 34 Answers
SOURCE: Samsung LCD flat screen goes black. Turn tv off
Sounds like your power board is failing. contact samsung tech support and describe your problem. some parts on samsung have lifetime warranties and the service call is free.
Posted on Apr 09, 2009
SOURCE: No Picture - Samsung LN-S4692D 46in HDTV LCD
My TV (same model) had the same problem except the sound worked (no picture, but the back light works).
Samsung is replacing it with a new model due to a long delay getting a replacement panel.
The TV failed 2 days before the warranty expired.
The new TV has better specs & is now less then half the price of the original.
The repair guy said it's cheaper to replace LCD TVs now then to get them fixed - he said he wouldn't even call a shop unless it's under warranty because you'll just spend hundreds of dollars only to find out a better replacement is cheaper then repairing the old one.
Posted on Nov 22, 2007
  • 197 Answers
SOURCE: Samsung 46" LCD picture dark at one side of the screen
bad panel
Posted on Jun 07, 2009
SOURCE: dark picture at startup
Yes yes it is persistent problem and it gets worse.
Posted on Oct 04, 2009
tvtek
  • 1284 Answers
SOURCE: Samsung dlp hls6186w, picture has darkened.
The lamp is the only thing that will cause the picture to go darker. According to the model you have the lamp part number is BP96-01472A. The noise you hear could possibly be the color wheel itself. The way to tell is when you turn off the TV the lamp stays on for about 10 seconds longer. Once the lamp shuts off if that noise goes away then it is a bad color wheel. Any noises past that would be a fan. Please take a moment to rate my answer. Thanks...
Posted on Dec 02, 2009
Testimonial: "Thanks alot for the great info, that helped me out alot. Once again thanks to the Experts"
What is wrong with Sharp Aquos LC-40C32U Picture
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Search the site with the keyword "Line fault"
Jul 01, 2015 | Sharp Televison & Video
How to fix a Sharp Aquos LC-40C32U Picture
Replaced the 4 power capacitors now tv runs for 15min. then picture turns black and volume stays on
when the picture goes black, dim the light in the room and shine a bright flashlight on the screen. If you see a faint picture, you have a backlight problem. If this issue came about after you installed the capacitors, double check the installation of your caps. Ensure that you don't have cold solder joints or broken joints!
Oct 10, 2013 | Samsung LN46A750 45.9 in. HD-Ready LCD TV
Service menu help for Samsung TXT3093WH
Go to ur service menu.Picture go down to reset,changes all setting to factory setting.Will reset everythings.
Mar 28, 2010 | Samsung TX-T3093WH TV
Picture fades in and out
Some newer TV's are equipped with a ROOM SENSOR which will change the Contrast and Brightness according to the amount of light going into the Sensor. While watching DVD's or Movies the output of light from the TV screen changes sometimes affecting the Sensor. While Computers are pretty consistent with light output.  Go into your TV Menu and look for ROOM SENSOR or something similar and turn it off. If not then check in the TV Menu Video controls and see if there are any Contrast or Brightness functions set to AUTO. If so grab a DVD with THX and they have a TV Calibration that is very easy to set-up your TV too.
Apr 21, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
301 people viewed this question
Jerry Greenberg
Jerry Greenberg
