Question about Sony TC-WR565RM Single Cassette Deck
My Sony TC WR 535 wont open doors, one cassette in deck B,lights blinked in display panel then unit shut down, not been able to turn it on since
The unit was stored in a closet for 10 years, is free of dust, unplugged and removed top to look, no burn smell, nothing looking melted, both fuses ok
    Problem Solver:
  • 11 Answers
Remove the cover after unplugging AC. Look for a plastic stop that keeps the eject button from going in farther. Move the plastic stop peice downward and the buttom will then move in all the way and tape will eject. On mine the plastic piece is white and rotates down.
Posted on Dec 24, 2012
4 Suggested Answers
SOURCE: Sony dual cassette deck TC-WR535
Belts are striched and not turning pulleys. The belts need to be replaced ... is easy to replace....
Posted on Dec 02, 2007
SOURCE: Cassette Tape stuck
How does one take the cover off?
Posted on Feb 02, 2008
alpug
  • 1961 Answers
SOURCE: I have a Sony Stereo Cassette Deck
you need to open it manually.take out the cover of the player by removing the screw.after removing the cover you can now access the deck mechanism.manually push the pin that serves as lock that holds the cassette door gently push it down to free the door.because the decks do not move check the belts for the mechanism make sure the belt is not loosen or worn out and cut off.replace it with a new one if you found it deffective.
make sure also that there is power on the deck motor you can use a tester to measure the voltage on the circuit good luck!
Posted on Jan 11, 2011
I have a sony cassette deck tc fx44. If I try to insert a cassette am unable to close the door. The door closes just fine without a cassette
Sometimes the tape sensors or record sensor gets bent or out of place so the door wont shut. Look for something like that.
Mar 30, 2013 | Audio Players & Recorders
Sony TC-WR690 doors will not open to remove the cassette.
If you remove the cover after unplugging the AC, you will see that when you push the eject button that on the back side the putton is held back by a white plastic piece. Push down the white plastic piece as you press the eject button. The door will open and the tape will release. I jsut did this today on my Sony TC WR 670 dual tape player. Both sides were blocked. I noticed that both fuses on the board were also blown. New fuses didn't solve the problem. May be that the transformer is out?
Apr 21, 2012 | Sony CASSETTE DECK Single Dual Cassette...
A cassette has jammed close the A door of my Sony TC WE675. How do I clear the jam? The tape is probably keeping the door closed.
Please click HERE so that you will be directed to the site where you can troubleshoot the issue.
I hope that this will work for you.
Aug 08, 2011 | Sony TC-WE675 Single Cassette Deck
I have a TC-WE835S Sony cassette deck I have not use for many years. Today after I insert a cassette into Deck A, it is stuck. I cannot open that side to recuprate my cassette. Please help. Your assistance...
I have the same unit...when it is "ON" ,plug the power cord off and than try to open the cassette door..
the head mechanism keeps the cassette in,power off will release it..
let me know if it does not work out..
Take care and please Remember to rate/vote for us to
continue f
or Helping out the Community :)
Jul 08, 2011 | Sony Dual-Deck Cassette Player/Recorder...
I have a duel cassette player sony model # TC-WR 565. The doors will not open and both casettes cannot be removed even after prying the door open.
Mine did that - you will have to patiently keep pressing the clear / stop / pause / etc and even power cycle a few (or many) times and finally you will hear the mechanism release the cassette. Once you hear that - you will be able to eject the cassette. After that go replace the belts.
Dec 29, 2010 | Sony TC WE435 Stereo Dual Cassette Deck...
Sony TC WR565 dual tape deck. Both doors will not
you can not fix it without tearing it apart. if you do take it apart, try to get the front panel off. Hit the eject button and look for a lever that is stuck.
Jun 17, 2010 | Sony TC-WR565RM Single Cassette Deck
Sony TC-WR670 eject wont open deck
I had the same problem. You probably have to replace the rubber belts.
Dec 02, 2009 | Sony STR-DE405
Sony Stereo Cassette Deck TC-WR550Z
Drives belt has become too slack to drive mechanism properly or the drive motor is bad. Have unit serviced for new belt(s)
Apr 29, 2008 | Sony TC-WR565RM Single Cassette Deck
i had the same problem of not opening the cassette doors and not running with my sony tc wr535. After I repaced the belts myself with new ones it did run fine! :-) An original sony(!) rubber belt set for the two decks costed me 23 euroos incl pp.
Nov 29, 2007 | Sony CASSETTE DECK Single Dual Cassette...
Sony TC-WR565RM Single Cassette Deck Logo
137 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
