Question about Samsung B2230HD LCD TV
B2230HD TV STAND REMOVAL - Samsung B2230HD LCD TV
    President:
  • 2,080 Answers
First of all, thank you very much for choosing FIXYA today for your online technical support needs.
See page 2-3 of the User's Manual for detailed instructions on how to remove the base stand on that monitor. But basically you just lay the monitor face down on a soft cloth so as not to damage the screen, and then just pull the base firmly straight out (downwards).
Here is a direct link to the ONLINE USER'S MANUAL for that model:
http://downloadcenter.samsung.com/content/UM/201008/20100820090207453/BN59-01091B-01Eng.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted section of text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Posted on Feb 18, 2012
Driver for Linux
Normally Linux doesn't need drivers because are already present on kernel. I doubt you will find one from a Samsung product.
What's exactly your problem with this monitor?
Sep 04, 2012 | Samsung SyncMaster B2230HD - LCD monitor -...
Cant get b512 universal remote control to work tv
not all remotes will program for all sets.
Jun 07, 2012 | Samsung B2230HD LCD TV
I cant connect my BD512 universal remote contol to work on my samsung B2230HD tv
It likely does not have the code built into it that is needed.
Jun 07, 2012 | Televison & Video
I can't hear anything when I plug in the headphones in the headphone output in the back, I can only hear something when I turn the volume up to 100, but still, what I can hear is very low... Please...
Check the impedance of your headphone, which should match with the specified impedance in the user manual. The impedance of your headphone is very high.
sonsunny
Jun 16, 2011 | Samsung B2230HD LCD TV
I can't remove the stand off the tv
Hi, i have instruction on removing your base stand.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat,
cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface.
Note: Extreme care should always be used when removing
the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose
the pedestal stand screws. The jack pack cover can be removed
without tools.
3) Remove the four screws shown in the diagram below. This will
allow removal of the pedestal stand.
4) Once you have removed all four screws holding the pedestal
stand in place, remove the pedestal stand from the TV by
sliding the pedestal stand away from the TV.
Feb 12, 2011 | Toshiba REGZA 52RV530U LCD TV
I just purchased a JVC 47'' LCD just need to know how to remove the stand. I have it hanging on a Unti do not need the stand.
1. remove the 4 screws on the back of the TV (these are located in the deep holes above the stand)
2. after the screws are removed, the TV will lift from the stand.
The stands sits inside the TV. after the screws are removed the TV will still sit on the stand. you (and someone else) will need to lift it from the stand.
Nov 10, 2009 | JVC LT-47X788 47 in. LCD HDTV
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
Samsung B2230HD LCD TV Logo
457 people viewed this question
Jerry Greenberg
Jerry Greenberg
