Question about Polaroid FLM-2011 Television
When I push the power button, the blue light comes on but tv doesn't
IThe red stand-by light is on. when you push the power button on remote or tv the light turns blue but it won't come on. And you can't turn it off. The only way to get the blue light off is to unplug it and plug it back in.
It is the capacitor. It is really easy to fix, and it will cost you about $4. The capacitor is on the power board and it looks like a small battery. The bad capacitor will have a small bulge on the top, the good ones will be flat on top. You can buy them at Radio Shack. Just look on the side of the capacitor to see which one you will need. If you need any further info I would by glad to help. I have a 40in polaroid that this happened to and it works like a dream now.
Posted on Nov 02, 2008
The tv do not on blue come on and go back to red fm-2011
Posted on Jan 14, 2009
What is stand by button for
It is for put the set to standby. If you press it, the set will stop working, but it will be still alive. When you press Power button on the remote control, the set will come alive. OK?
Apr 19, 2015 | Televison & Video
What would make a crosley 42" lcd tv not turn on
check the psu, if you can manually switch the power the power then its going to ease your work
May 27, 2014 | Crosley C42hdgb
The power stand by light is on when i push the power button it stays red, the after a while of pushing the button it turnes green but all i get is a blue screen
YOU NEED TO CHANGE THE INPUT OF YOUR TELEVISION SET TO THE CORRECT SOURCE. FOR EXAMPLE: HDMI1, AUDIO VIDEO IN, YPBR INPUT ETC, YOU CAN DO THIS BY THE USE OF YOUR TV REMOTE.
Aug 14, 2013 | Apex Digital DT502
Wont power on
some tv's always have standby light on, even iff you turn off by tv button. solution 1: with light on, press a number on remote. solution 2: with light on press stand-by button on remote. solution 3: with light on push the 'on' button on the tv set. solution 4: unplug tv set, wait a few seconds then plug back in, if no light then turn on tv using button on the set, and then channel number.
Jun 25, 2012 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
I have a hitachi 50 "plasma that was given to me
First do you see a light indicating that the TV has power? There are two power buttons on the TV (the main power and the regular power button). The red standby light will light up when the main power switch is on. This indicator is just to the left of the remote I/R sensor. You can find the main switch on the bottom front of the tv (it is under the tv forward of the stand). Turn on the Main power if it is not on. Then try the power button on the control panel of the TV again.
Does the standby light change color or blink? (Red is standby, orange is power savings (no signal), blue is on.) If the main switch is on and the standby light doesn't come on, the TV has a problem at the power supply. Try unplugging the unit for a bit (at least 30 seconds) and then plugging it back in. This will reset the internal circuitry. If you see a blinking light, then the TV is reporting a self-test failure. I do not know the codes for this model Hitachi Plasma TV.
The manual for the Hitachi P50H401 TV is available from Retrevo: http://www.retrevo.com/support/Hitachi-P50H401-TVs-manual/id/1233ci869/t/2/ . You will need to enter a code to access the pdf.
I'm assuming you don't have one of the special versions that were intended for large audiences that were only controlled by remote (no control keys on the front of the TV). Remotes.com has the original remote or a substitute remote if you need it. See http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=13104063628240&smodel=P50H401&brand_pn=HITACHI_P50H401 .
I hope this helps.
Jul 11, 2011 | Hitachi P50H401 50 in. Plasma HDTV
When I plug it in the red remote stand-by light comes on when I push the power button on the remote the red light blinks then goes off but there is no picture or sound?
flashing power light:
projection TV`s have many protective circuits in them, they protect your CRT`s from damage, over voltage called x-ray, and many others, you need to have it checked before the damage is more costly, your TV is not happy and needs to be checked
Jan 31, 2010 | SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready...
Tv2 light does not come on
hi hammonhph! I will be more than glad to assist you in this concern. Lets program the remote for tv2, lets make sure that the battery's are brand new, please go to the front panel of the receiver, make sure that u have the remote2 with, turn on the the tv1, you got picture, on the front panel of the receiver, you got 1 green and the blue light is off.. push the power button on the front panel of the receiver once to turn off the green light, once its off the tv will show a black, blue or snowy screen, push the up button on the fron panel of the receiver until it shows the system information screen, look for the primary and secondary remote address, primary and secondary remote address should show a number on the white box ex.. 1 and 1 on the green box, secondary is ex 2 on the white box and 2 on the blue box, how to reporgram the remote to the receiver.. press and hold the sat button and wait until all lights lit up, once it all lit up, release it and press any number from (1 to 15) but for this ex is press 9, then press the pound button (#) that is under number 9, once you press the pound button the sat button will flash 3 times and then press the record button once, record button is under the cancel button or view tv button, once you are done check the secondary remote address, it should be 9 on the white box and 2 on the blue box, save the settings by using the remote 1, selct done on the screen and it will go back again to black, blue or snowy screen, press the sat button once on the remote 2 and the big red power button, the blue light should turn on, just in case the blue light dont turn on, press the power button on the front panel of the receiver for 10sec to reset the receiver, it will acquire the sat signal and go to a progress, and it will download the programming guide, check if blue light is not on, press the big red power button on the remote2 to turn on the blue light and it should work. if just incase the blue light dont turn on, the remote is bad and you need to call 1-800-333-3474 for the replacement of the remote..please feel free to get in touch if you have any query..
Jul 06, 2009 | DISH Network 322 DTV Receiver
First time to operate indicater light comes on reacts to remote but no picture or sound 42 philips flat tv
First red light normal
Now select channel or other source from remote with full batteries or pushing buttons left down side of TV. Red light is only stand-by
Apr 28, 2009 | Philips 42 in. Plasma TV
Polaroid FLM-2011 Television Logo
659 people viewed this question
Top Polaroid Televison & Video Experts
Dave Naylor
Dave Naylor
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
