Question about Rex RX-518
My rx-518 does not not run when i push the peddle down
We have A RX-518 and the needle keeps "ticking"
I have some problem,i make mistake spending my money on this mashine.
I will by another mashine.
Oct 30, 2011 | Rex RX-518
Need a downloadable instruction manual for Rex RX-518 blindstitch hemmer sewing machine please!!
No luck findong your but Go to www.reliablecorporation.com. Under products check out the MSK555 blindhem machine. It is the same as the Rex 518. To the right of the page is a category to download the manual. It is very helpful.
Good luck
Thanks
Apr 11, 2011 | Rex RX-518
I need Foot Pedal for rex 518 with the wire
try these websites
sewingmachineplus.com
sewman.com
acesewvac.com
Dec 07, 2010 | Rex RX-518
Fabric stretching
I find that if I keep the bottom and top pulled taunt that it keep the stretching down and also keep the bottom from puckering
Jun 14, 2010 | Rex RX-518
RX 518 portable hemmer
If you are the one I replied to about a URL for your manual I was wrong this is the right one:
Try this URL:
www.sewingmanuals.net
Feb 27, 2009 | Rex RX-518
Feeding fabric
There is a knee lift.....that attaches and that makes the body of the suspended bed go down and forms a gap to insert your material into the machine....
Sharion n Indiana
Feb 23, 2009 | Rex RX-518
Singer 7426 will not start when peddle pushed - only beeps
No, dont go and buy another machine. This is a great value for money machine.
Your problem is most certainly with the buttonhole switch. Firstly: Look if the buttonhole lever, left back of machine, is push up in position. Pull it down and push it up to the top again. This should sove your problem right away.The beeping sound is a warning message. If the problem persist, do the following procedure:
Remove the light cover, left of the machine, loosen back screw and remove left hand screw completely. Check for a small black electric switch, follow the brown and green elecrtic wire, just back of the light. If you push the BH lever up and down the switch finger should also move up and down. If it stays down, the machine will not work and give a beeping sound. If the switch finger is stuck, push it up with the BH in top position. Hope this will help you
Nov 14, 2008 | Singer 7426 Mechanical Sewing Machine
Multiple troubs
Hi There, I am just new here and just got a new REX hemming machine. I am not too sure if your issue was resolved but just make sure the six little holes on the machine are oiled each time you use the machine.. make sure all screws are tightened and make sure the motor itself is not loose, this was an issue with my new machine and why it would not run, since REX has no support I had to troubleshoot myself.
Aug 17, 2008 | Rex RX-518
Rex RX-518 Logo
42 people viewed this question
Top Rex Sewing Machines Experts
Chance Miller
ray gallant
Are you a Rex Sewing Machine Expert? Answer questions, earn points and help others
