Question about Kenwood KAC-5201 Car Audio Amplifier
Iwont turn on
I got a 315 or 715 depends on which way you look at number got power to it wont turn on was working has a blaukpukt moldulator it hss power to it is there a fuse in back of radio i dont have a owners manuel how does face plate come off it also has a power antenna
  • 56 Answers
It sounds like the amp is shot but there is a few things you can try.You can check the ground it has to be metal to metal make sure there is no paint,plastic,washers ect in between the wire and the metal if you cannot find a paint free surface get some sand paper and sand the paint off.If your current ground hook up still dosen't work then try to ground it in a different area before drilling any new holes for the ground check and make sure you won't be drilling into the gas tank otherwise is will cause gas fumes in the vehicle.If this isn't the problem check your inline fuse on your amp battary cable to make sure it's not blown if it is replace with a higher amp fuse.If it still don't work after that check the remote wire this is the wire running from the power antenna on the stereo and it runs to the remote on the amp this turns the amp on when you turn the stereo on.If u need more help with this problem get back to me i will be glade to help.
Posted on Oct 27, 2008
My car keep blowing igntion fuse the 10 amp under the hood change to 12 amp ran fine thn just shut off and will not start it just turn over
Whatever was causing the problem may now have simple burned out the next weakest wire. That is why fuses are thinner than the wires they protect.
I will give you a site for free wiring diagrams and fusebox details. Go to Autozone.com and register your vehicle; then you can get the wiring and fusebox layouts free.
I would put in the standard fuse. Then find the Ignition relay and remove it. If the part number on the Horn relay is the same # Relay printed on the case, remove the horn relay and plug it into the Ignition relay position. Try and operate vehicle.
If this does not work, you will need to test the power into and out of the ECM and backtrack from the coil until you find power. The dead gap will be your burned out part. Remember that some stuff needs to have power with the switch on.
Now Dealers have wiring Pigtails. They substitute for your built-in wiring system. They can tell if a connector or length of wire is dead. Instead of a Mechanic testing pin by pin the whole connector is plugged into a tester and the tester does an all-inclusive job.
Please rate my info.
Nov 14, 2012 | 1994 Ford Taurus
Free code for motorola RAZR v3
Hi free code are un trust able many time .i guide you to visit simpleunlocking.com to unlock your Motorola razr v3 mobile from fido network .here they ask you the imei number of your mobile .finally they send you code to unlock your mobile.
Aug 25, 2012 | Motorola Mobility MOTORAZR V3 Cell Phone
My toshiba 32inch tv wont turn on
A lot here would depend on the model number as there are a lot of different ones with different issues.
Got a model number?
Mar 28, 2012 | Televison & Video
Hi,my Acer Aspire 3683 NWXCi is unable to detect wireless network and some drivers are not working,is there any free recovery disc to overcome this problems.
the problem is most likely located not in your computer but in your wireless router or connection source itself. Disconnect the modem, mor router from any power source for at least ten minuets and then make sure EVERY connection is firmly in place.
Jan 06, 2010 | Acer Aspire 5630 Notebook
Iwont ti know 0166107120this numbers ISD cod.How
You can use http://mobilenumbertrackr.com/STD-Codes-In-India.aspx to track STD and IST codes
Dec 28, 2009 | Nokia 2600
The icemaker is not producing ice. can u advise? the water is freezing but the cubes will not flip out.
sounds like you have a faulty imkr the heater on the mold is bad or the thermostat (cliped on the side is white with black bottom make sure its in the clip first) but also look at the front of the icemaker remove the white plastic cover once off you'll see a larger white wheel if you see at the center of it one side of the retainer clip broken replace the motor moldule but its almost as costly as the complete icemaker they run appx 150.00 complete sears sell the motor moldule 9400 then you have shipping chgs best if possible to buy local save shipping
Sep 06, 2009 | Maytag Refrigerators
The ice maker on my Kenmore is making a grinding noise and the ice wont dump.
bad news the imkr needs help if has a light brown plastic assy under the white cover you can replace the motor moldule if metal buy an new icemaker
Aug 19, 2009 | Refrigerators
Bearing change iwont bearing number
the rear bearing is 6002 if my mind serve me right...
there should be a code somewhere on the seal or on the bearing shell itself...
last resort,bring the bearing to the shop,the seller should know...
Jul 05, 2009 | Makita 1/4" Drill - 6501
Flashing green light
You don't even have to replace the whole board. The problem is 4 capacitors (# depends on the model of the TV). Can be fixed for under $10, and a couple of hours of labor.
Aug 01, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Kenwood KAC-5201 Car Audio Amplifier Logo
49 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Pablo Gonzalez
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
