FixYa.com
Tags:
Panasonic SA-HE7 5.1 Channels Receiver
Intermittent F70 Error (by 2 users)
posted by ginjag on Aug 21, 2006
Thanks in advance to anyone who can help me with my issue. As you may have guess (given the location of this post) I have a Panasonic SA-HE7 which has served me well for almost three years. However, now after about ten minutes of operation, the power will cut and F70 will display on the screen. The only way to remove this is to power off the unit and allow it to cool, after which I will get the same ten minutes of operation before the problem reoccurs.
Having searched the F70 issue online, it appears that it usually indicates a blown fuse. However, in this case, the user would not be able to use the unit at all which suggest this is not the case. Also, when I remove the case, of the three fuses inside, all appear to be intact.
Another thought I had was that the fan may not be kicking in, hence the apparent overheating, however this is not the case. The fan will start as normal once a certain level of volume is reached.
Any help/ideas/comments that anyone can provide would be greatly appreciated.
Thanks again
James
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Dec 12, 2007
I've got the same problem.
Best Solution
posted on Jul 05, 2007
Helpful (85)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Hi James.
I had just a SA-HE7 for repair.
It had a F70 error after 30 min.
The solution.:
On the DSP board the power on de collector of Q1702 fails.
That was because the busses through the board interupted.
I have connected a wire between R1702 and the collector of Q1702.
I have tested the set now for several days, and the F70 problem is resolved.
I hope that this is also the solution for your problem.
Regards Ron.
Radio TV Service Zeeland.
rtv-service@zeelandnet.nl
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Nov 09, 2007
Helpful (85)
yus_tms
Rating: 89%, 7 votes
F70 interrmintent problem caused by (Ic-current) interupted, supply for cpu, Q1702 (emitter point) high resistant to IC1701, suggestion- connect a wire between these component due to pcb track poor contact.
Can you Help with these Receivers problems?
Receivers
Which Alpine Sub Is better?
I have the old school alpine... Answer This...
Receivers
toshiba sd-v55ht- turned on...
toshiba sd-v55ht- turned on... Answer This...
Receivers
i have a jvc KD-PDR55
i have a jvc KD-PDR55 unit and... Answer This...
Receivers
Sony MHC-GNX60. The system on
Sony MHC-GNX60. The system on... Answer This...
overloading
the amplifier isnt connected to... Answer This...
Repair Service
Find Receiver Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
