I am using toshiba washing machine AW9770UBB and its giving error E7-1. Need help urgently
5 Suggested Answers
  • 6277 Answers
SOURCE: I have a Samsung Automatic
As it's only 2 days old I suspect it has not been installed 'balanced'. If what follows does not cure it CONTACT YOUR VENDOR. Anything else could invalidate whatever warantee/guarantee you have!
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Aug 14, 2011
  • 6277 Answers
SOURCE: my toshiba aw9000s washing machine, give error
(no promises but it's worth carrying this out anyway!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
John C
  • 6277 Answers
SOURCE: my washing machine toshiba aw9000s,
(2nd time!) Hi from retired Englishman in SW France,
John C
misnin
SOURCE: ERROR E7 TOSHIBA WASHER AW8960S
check the water level switching or door sensor
Posted on Nov 01, 2011
I have a HP 44" Z3100 and after switching and saying "Initializing, please wait" it gives error 79-04 " Help needed urgently please!!!
Firmware issue:
1. Cancel all pending/que jobs
2. Disable nesting option
3. Dis connect data cable, restart the machine.. check...
4. Up load latest firmware.( read carefully read me file before up loading the firmware)
Jan 18, 2013 | HP DesignJet 1050c InkJet Printer
Samsung washing machine error E1
Not filling in allocated time
This is essentially a fill timeout error which will normally mean that either the water isn't on or that an inlet valve has failed.
Nov 04, 2012 | Samsung SW62ASP Top Load Washer
Toshiba washing machine AW-1160SM error E7-1
my washing maction have a priblem E7 err
Jan 11, 2012 | Washing Machines
My AW-1170S toshiba washing machine was showing error code E9-5...what does it mean?
my AW-1170S toshiba washing machine was showing error code E7 -4...what does it mean?
Nov 13, 2010 | Washing Machines
Please help us our washing machine is Toshiba AW8800S and theirs a error E5 what is that error means? please send to my email aflordeliza@hotmail.com
Please help us our washing machine is Toshiba AW8800S and theirs a error E7 what is that error means? please send to my email oceana.2000@yahoo.com
Oct 20, 2010 | Washing Machines
Toshiba rd-xs32
i've attached the hd to my pc but when i put it back again on my dvd toshiba i got 7034 error and it stop i cannot access no more in my dvd recorder and i didnt see my recording movies on my pc too.please help me very urgent thnx.
Oct 19, 2008 | Toshiba RD-XS32 DVD Recorder
URGENT CALL: Critical Error that keeps restarting System?
hi ,
this is problem with your windows , you used winxp it is need to protect with antivirus .
when u get revers counting on screen just go to "Run"& type shutdown -a
  • once u need to remove virus from u r laptop
  • if problems get same u need to reinstall win xp
Jun 11, 2008 | Toshiba Satellite A135-S4527 Notebook
E70 error code repeatedly comes up when attempting to start a load and you have to cancel and restart 4-6 times before the load washes; again at the end of a load it will come up with the E70 error and to...
Means you are not getting cold water into unit..Either cold water hose is connected to the wrong hose or cold water faucet is not turned on..You can solve this by connecting hose to cold water faucet and cold water inlet on washer..
Nov 06, 2007 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
431 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
