Question about Winter Sports
Headlight problem the headlight keep burning out bulbs and wont stay on
Sounds like you have a shortage....just pull into any old repair shop and tell them...
Posted on Feb 18, 2012
Headlights kick off and on seems to jiggle on and sometimes stays off. Hi beam and left blinker dash lights stay on but are very dim and left side blinkers stay on when headlights are not working
Hi, Byson if your headlight is not working, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
1. Faulty ground or power supply wire to headlight bulb socket.
2. Worn down solder contacts or loose fit of the bulb base in the socket due to vibration.
3. Worn, chaffed, or broken wires in the light circuit.
4. Corroded, broken, or loose pins/sockets in wire connectors.
5. Faulty hi/lo beam switch.
6. Faulty ignition switch.
7. Fuse is good but no continuity on both sides.
8. Faulty wiring between battery positive and headlight bulb socket.
9. Weak charging alternator/generator.
10. Faulty voltage regulator/rectifier ground or overcharging.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have nice a day.
http://katriders.com/vb/showthread.php?t=52550
My headlights quit working Any ideas Suzuki GSX Motorcycle Forums Gixxer...
Suzuki GSX600F Service Manual
OEM parts for Suzuki
Aug 04, 2016 | 2005 Suzuki GSX 600 F (Katana)
Same low beam headlight keeps burning out ive replaced 3 now same side headlight in 7 years???
check that you have a good ground, if you do not it will cause it to do that
Mar 19, 2014 | 2007 Dodge Dakota Cab SLT
Honda accord keep burning low beam headlights
Sounds to me like you need to reset the headlight housings... maybe they are vibrating very badly. ... OR, easy fix, get NEW headlight housings on EBay and install.
Nov 28, 2011 | 2004 Honda Accord
Headlights wont come on when i turn the switch on
Hi, Tom if your headlight is not working, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
http://www.r6messagenet.com/forums/r6-maintenance-technical/102278-headlight-wont-turn-electrical-problem.html
Weird Headlight Problem
2004 2005 Yamaha YZF R1 Service Manual R1 Moto Data Project
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Oct 16, 2010 | 2004 Yamaha YZF-R1
1998 olds intrigue drivers side signal light keeps burning
It happened to my 98 Intrigue. It stopped as soon as I changed the sockets. It is very simple to do this, just pull it out the the plug from the connector about 4 inches from the socket. I got used ones at the junk yard, 2 bucks a piece. Been working fine for almost 2 years.
Feb 01, 2010 | 1998 Oldsmobile Intrigue
Car headlight bulb keeps burning out!
Must have a bad seal or broken/chipped lens allowing moisture to build up inside headlight.
Jan 16, 2010 | 2004 Hyundai Elantra
HEADLIGHT BULB KEEP BURNING OUT ON MY BENZ..2002 C CLASS
Try to put a relay on every bulb to prevent burning, and also check the bulb socket make sure it is not loose.
Jun 09, 2009 | 2001 Mercedes-Benz C-Class
Headlight keep burning out
you might be using a higher wattage of hallogen bulb. higher wattage bulb must have a relay so it'l stop from burning. and you save money.
Apr 15, 2009 | 2005 Kia Sorento
Left blinker light stays on solid when headlights are on
I have had this happen and it is rare, but I have had a filiment burn out in a two filment buld and short to the other filiment. It does happen and I think this might be your problem, the only way to find it is a visual inspection of each bulb. I am sure many people will think this is crazy, but I have had the exact same problem, I had the schematics, tested the circuits,etc. and them by accident found a stop/blinker 1157 bulb that had done this exact thing. I hope this helps you, check the bulbs in your headlights also.
Dec 27, 2008 | 1999 Chrysler LHS
Left signal light stays on when i turn the headlights on.
240 Drifter says, check for a burned out bulb as when turn signals stay on constant sometimes means one bulb is burned out
Nov 18, 2008 | 1990 Nissan 240SX
Winter Sports Logo
64 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
vtrktrmn
Are you a Winter Sport Expert? Answer questions, earn points and help others
