Question about Teac AG-V3050 Receiver
EVERY TIME I TURN THE POWER ON IT POWERS ITSELF OFF ABOUT 10 SECONDS LATER HOW CAN I RESET THE RECIEVER?
I TURN THE RECIEVER ON AND IT GOES BACK OFF IT WONT STAY ON
Harmon/Kardon AVR 146 wont stay on when hit power
Probably was damage buy a power surge, Internal damage to (Reciever)
Nov 03, 2012 | Harmon Kardon Harman Kardon Avr 146 5.1...
When i turn power on it came on and says protect then turn off..please help
The reason why this is happening is because the reciever is going into protection mode due to a short circuit to the amplifier. It might be a speaker that is shorted out internally or there might be some speaker wires making contact with each other at the back of the reciever or at the speaker. The first thing I would do is disconnect all the speaker wires from the back of the reciever(make sure to label them before removing so you know how they go back). After removing the speaker wires turn on the reciever and see if it goes into protection mode. If it does then there is a good possibility that the internal amplifier might have a short. If it does not go into protection mode then that is good because there is more than likely a short on one of the speaker wires or speaker itself. Now connect one set of speaker wires at a time. After you connect each one try turning on the reciever until it goes into protection mode again. When it does you will have your culprit. Then try swapping speakers with that problem wire set and see if it still does it. If it does then it could just be the wires but also switch the wires to verify that the amplifier does not have a bad channel. If swapping both the wires and the speaker swapping produces the protection mode then that channel for the amplifier will be defective. I hope I have not confused you too much.
Aug 17, 2010 | Audio Players & Recorders
My denon avr1200 receiver once it is turned on goes into Protection mode. How do you reset or make work?
The reciever will go into protection mode when there is a short in the speaker wires or the amplifier was overloaded. What I would do first is verify that none of the speaker wire connections are loose at the back of the reciever or at each speaker. And verify that none of the wires are making contact with each other. Then label each speaker wire as you remove them from the reciever so you can re-install them correctly. After you have disconnected the speaker wires try unplugging the reciever for 10 to 15 minutes. Most recievers have a self-resetting overload protection switch and this should reset it back to normal. Now try plugging the reciever back in and turn it on without the speaker wires connected. It should be out of protection mode now. If it is still in protection mode verify that there is not a reset switch somewhere on the back of the reciever. If it is not in protection mode now then proceed to connect one speaker set at a time and turn on the reciever to see if it goes into protection mode. If it goes into that mode after connecting a speaker then that speaker is the cause of the problem. If it does not go into the mode after all speakers are connected then try turning the volume up. If it goes into protection mode then there could be an internal short on the amplifier or a incorrect OHM rated speakers connected to reciever. Verify that the speakers are rated the correct OHMS.
Feb 22, 2010 | Denon AVR-1200 Receiver
I have a KLH 700watt home theater reciever that wont stay on!!
Sounds like it is overheating. Try one or all of the following:
Remove anything that may be stored on top of it. Unblock the vents.
Connect speakers with a higher sensitivity rating.
Move it to an area where it has more airflow around it, ie; not in a closet or cabinet.
Disable any bass-boost and equalization, or tone controls.
Set any crossover settings for any subwoofer you may have connected, to a higher frequency.
Decrease your listening volume.
Dec 30, 2009 | KLH R7000 Receiver
Amp wont stay powered on as soon as bass hits in goes into pm
The amp is not geting enough current.You need to use some larger gauge cable and it would probably be best to add a small power capacitor.If your not familiar with a cap then stop by your local car audio store or google it and you will get a lot of imfo.
Sep 06, 2009 | Sony XM-2165GTX Car Audio Amplifier
Reciever wont stay powered on
I fear that there's no easy fix. Sounds like the power supply or the board which controls it is bad. If you're not an electronics repair person, it'll need to go to a repair shop.
May 02, 2009 | Audio Players & Recorders
Yamaha rx-v461 not working
you have a faulty circuit somewhere, whether its in speaker wiring, or power source, i dont know, but your reciever has an automatic circuit breaker in it for protection, and a faulty circuit will trip it, i would assume it is a power source problem since it wont turn back on, check wiring, plugs and look around, and smell for burnt, or hot components.
Jan 21, 2009 | Yamaha RX-V461 AV Receiver
Reciever won't stay on
Do you have too much of a load on the amplifier? Or as SallieJohns mentioned, is it getting adequate ventilation?
Apr 02, 2008 | JVC RX-6018V Receiver
37 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
