Hi: sc1 or 5c1 is the error code that i have got on my sharp ar- 203 copier
It does not print anyway
  • 61 Answers
SOURCE: error code
Hi, H4 is a heater error. Try resetting it by the following; Enter #, interupt, Clear, interupt, display goes dead, enter 14 then print. That will clear the error code, however if you have a problem with the heater it will return. It is probably the thermal fuse has tripped, which is resetable by removing the fuser unit
Regards
Andy
Posted on Jan 22, 2008
Benimur
  • 6966 Answers
SOURCE: printer all in one sharp ar-m155
Hi again,
Sorry but not the wire, I was referring to where the wire is attached, both ends. This would either be a clip-on or sandwiched between 2 small plates held together by a screw. It is not uncommon for this clips or plates to be tarnished or have burns. They have to be cleaned, if not current will not flow freely to the corona wire. The purpose of the wire is to draw the toner from the drum onto the paper, it uses static electricity to coat both the photoreceptive drum and the paper with a layer of positively charged ions. If the corona wire is not getting full charge or no charge at all, this is the primary reason the warming up is taking too long.
Additionally, try to enter service mode; try #, *, CA, #.
To reset the developer counter press 24, Start, 5, Start.
To exit press reset 3 to 4 times or turn main power off/on.
Would appreciate further updates.
Posted on May 03, 2008
SOURCE: Sharp AR-C172M photo copier. Error
Replace black drum.
Posted on Aug 15, 2008
  • 990 Answers
SOURCE: how to fix a sharp ar-m455n error code u2-81
Dear sir; This error code means "scannor memory" problem, don't worry, we can reset it, the procedure as follow;
1, make sure you are in copy mode , then press "p", "*", "clear", "*".
2, enter 16 press start.
3, press "CA" to end simulation.
that's easy, if you need more help, just let me know, good luck.
HAVE A HAPPY HOLIDAY !!!
Posted on Dec 20, 2008
  • 190 Answers
SOURCE: error code Sharp AR-M 257
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
Posted on Jan 27, 2009
Installer of sharp AR-203E copier, scanner, printer
You can download driver software for your sharp AR-203 from here http://sharp-ar-203e-series-mfp-driver.software.informer.com/download/ Hope this helps,
Please rate if this solution was helpful, thanks!
Jul 19, 2011 | Computers & Internet
SHARP AR-203 copier unusable after refill
Change the unit chip or reset him.
Sep 01, 2009 | Sharp AL 1631 Copier
Sharp ar c260m error code f9.00 print function out of service
F9-00 is "AR-NB3 communication trouble"
that is the NETWORK PRINTING / SCANNING
EXPANSION KIT. that is the box that hands on the back of the machine.
Aug 12, 2009 | Sharp AR-207 Copier
H2 Error Message on AR M205 Sharp Copier
hi..there is a problem in the thermistor,thats why you
get the error code as H2.
check this out..
thank u..
kindly rate my response..
Jun 23, 2009 | Sharp AR-M205 Copier
AR-5132 Error code E7 13
CCD calibration error. Make sure the optics are clean in the machine in the scanner and free of dust.
Nov 03, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR 5320 error h200
H4 indicates there is a fuser error.
Try resetting it by the pressing the following buttons on the display in sequence,
#, interrupt, Clear, interrupt,
display should go dead,
enter 14,
then press print, This will clear the error code
press CA to get out and return to normal.
However if there is still a problem with the fuser, the code will return. Then you may need to have a tech look at what is the problem.
Hope that helps...
Lbcoaster
Aug 05, 2008 | Sharp AR-5320 Black and White Copier
Error code
Regards
Andy
Jan 22, 2008 | Sharp AR-5320 Black and White Copier
50 people viewed this question
jasbo
jasbo
