Question about HP PSC 2355v All-In-One InkJet Printer
Heavyweight paper trying to use heavyweight paper and have tried to make adjustment to no avail.
  • HP Master
  • 19,396 Answers
First tell me the paper weight , so that we can check if it is supported.
Posted on Oct 26, 2008
  • Ginko
    Ginko Oct 26, 2008
    This printer had been designed to work with thick photo paper, and will load heavy paper automatically, with no need to additional set up, and has problems only with thin papers that can cause paper jams quite easily.
    Check the manual at pages 32 to 38 here HP PSC 2350 series all-in-one.
    If you have problems loading the heavy weight paper, then let me know the kind of paper, and give me details on the specific problem, so that I can provide more help.
    Thanks
Type of paper Xerox DocuColour 1632 can print on
DocuColor 1632 can print on:
Plain paper (A4/210 x 297mm LEF):
? Black and white: 32 ppm; colour: 16 ppm
Transparency:
? Black and white: 13 ppm; colour: 7 ppm
Heavyweight 1 (106 to 169gsm):
? Black and white: 13 ppm; colour: 8 ppm
Heavyweight 2 (170 to 220gsm):
? Black and white: 8 ppm; colour: 8 ppm
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jun 01, 2011 | Office Equipment & Supplies
On a Xerox doc 250. How do i set tray 4 for Heavyweight paper?
Use the tray 1 for Heavyweight paper. It's recomended so by standard specifications
Aug 28, 2009 | Xerox Office Equipment & Supplies
Paper jam in Lexmark printer
First turn the printer off then back on:
1 Make sure:
• You use paper designed for inkjet printers.
• If you are using photo, glossy, or heavyweight matte paper, you load it with the glossy or printable side facing
you. (If you are not sure which side is the printable side, see the instructions that came with the paper.)
• The paper is not used or damaged.
• If you are using specialty paper, you follow the instructions that came with it.
• You do not force paper into the printer.
2 Before loading paper, slide the paper guides out toward the edges of the paper support.
3 Load the paper vertically in the center of the paper support, and adjust the paper guides to rest against the edges
of the paper.
Note: To avoid paper jams, make sure the paper does not buckle when you adjust the paper guides.
Apr 12, 2009 | Lexmark X4650 InkJet Printer
Printing heavy weight invitation stock on Epson R200
The card is probably too thick. Try cleaning the feed roller in the Sheet feeder to improve its grip. Check the GSM of the paper is within the spec of the printer.
Nov 03, 2008 | Epson Stylus Photo R220 InkJet Printer
FOULT CODE 22-511.00 MEDIA REQIURED FOR JOB NOT AVAILABLE FOR XEROX C-45 PHOTOCOPIER
What that is saying is that somewhere, most likely in a print job, either the paper tray settings or the settings on the driver are incorrect.
What you need to do is look at the machine paper tray settings and see if they all say the proper size and paper type, and that they match the driver settings.
An example. See that the letter tray settings are 8 1/2 x11 plain paper on the machine and driver. Be for example that the driver doesnt say plain paper and the machine bond, or recycled, or heavyweight. They MUST match or you will receive that message.
The paper SIZE snd TYPE must match.
Aug 15, 2008 | Xerox Office Equipment & Supplies
Printing
Dear jamin4volks;
As per this excerpt from the Oki B4350 User manual:
"FACE UP AND FACE DOWN PRINTING
For face down printing, make sure the rear paper exit tray is closed (the paper exits from the top of the printer). The paper exit bin on the top of the printer stacks printed pages face down, capacity 150 sheets of 20 lb. paper. Pages printed in reading order (page 1 first) will be sorted in reading order (last page on top, facing down).
For face up printing, make sure the face up rear paper exit tray is open and the paper guide is extended if required. In this condition, paper will exit via this path, regardless of driver settings. Paper is stacked in reverse order, capacity 50 sheets of 20 lb. paper.
Always use this tray and the manual feed tray for heavyweight stocks to reduce the possibility of paper jams."
This manual is available at http://my.okidata.com/mandown.nsf/(MOC-B4350)/BE70FCAF93D577E285256E89005052F9?OpenDocument
Hope this helps;
Frank
Apr 18, 2008 | OKI B4350 Laser Printer
Won't feed paper
when you say ''heavy weight'' do you mean thin card etc.
Most printers dont like to use thicker paper. does it make a noise. like gears slipping or crunching when it is trying to feed. if this is the case, then the feed gears maybe worn.
Feb 04, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Paper jam in 1120 hp printer
Hi there, Try printing again using heavier paper. Board types will likely push the torn papers out. Hope this solves your problem.
Sep 17, 2007 | HP DeskJet 1120cse InkJet Printer
HP PSC 2355v All-In-One InkJet Printer Logo
Ben Johnson
