Question about Coleman Heating & Cooling
Need coleman mach 8333C871 manual
2986 camp trailer ac
SOURCE: Coleman Mach roof top ac
Under the drain pan on each side should be a small plastic drain plug they might be clogged up with debris.
Posted on Jun 19, 2008
SOURCE: coleman tsr mach 3 RV Air Conditioner
the fan motor bearings need lub....the shaft has a tiny access hole to put some oil into. because the fan shaft is slowing down, it is putting more strain on the voltage current, and eventually the internal breaker shuts down the ac........plus your condenser is not getting enough air accross it, compressor heats up, and it too will shut the unit down......older units have to be oiled every year, and eventually it too will fail, and a new blower motor assembly is needed or replace the ac unit.....blower motor units are around $130....now you install it or pay to have it done at around another $150 labor,,,,,try yourself, if it fails then call the tech........let me know ..ray..yyzazz@ao.com
Posted on Dec 31, 2008
  • 588 Answers
SOURCE: coleman mach wire schematics?
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO
www.rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Posted on May 11, 2009
  • 127 Answers
SOURCE: Coleman Mach 15 AC just quit. no compressor sound, no fan
If this is a ducted unit, check the thermostat. It has a fuse for protection that may have blown. If the fuse is fine and you have power to the upper units control box, check for 120V incoming power at the control box and also check for incoming 12V on the Yellow and GH wires when tstat is set to high cool.
Hope this helps.
Posted on Jul 04, 2009
  • 92 Answers
SOURCE: AC unit wong start unless I spin the blower
you have 2 windings that are in you motor,One winding is the start winding It give the motor its initial boost that gets the fan spinning.The other winding is the run winding and it takes over and keeps the fan running.So it sounds like the motor is bad because the start winding is not giving the boost it needs to start. good luck--Nate
Posted on Jul 15, 2009
We have Forrest River Wildcat 295RSX 2017. When connect to Dodge Ram 2500 fuse that regulates L Rear brake light and blinker. Ram says it's the trailer. Camping World says it's the truck. Frustrated
Seems simple enough to check. If you're at Camping World, connect your 2500 to another trailer and see which one works. If you're not at Camping World, and it a ways away, go to any UHaul place and see if they will let you check with one of their rentals.
Apr 04, 2017 | Dodge Cars & Trucks
What kind of generator for a 1978 Wilderness trailer
1978 Wilderness Prices, Values and Specs Building travel trailers as well as fifth wheel trailers for the first time in the 1970s, recreational vehicle brand Wilderness designed as basic family vacationing and camping. Wilderness would also produce park model vacation units from 1994 to 2002 measuring up to 40 feet in length. A division of Fleetwood, Wilderness was discontinued after the 2009 model year.
Mar 27, 2017 | Televison & Video
How to wire truck battery to trailer battery
There is a kit available that ensures the engine battery will not run down with the trailer battery. They are available at camping stores and on line. Here's one of many;
http://www.ebay.co.uk/itm/Trailer-Electric-Brake-battery-break-away-w-CHARGER-switch-Camper-/291156206807?pt=Motors_RV_Trailer_Camper_Parts_Accessories&hash=item43ca4324d7
Aug 02, 2014 | Ford F-150 Cars & Trucks
We have electricity in the trailer. But the ac will not come on. We replaced the fuse. Could it be the converter went out. How can I get an owners manuel to the Ameri-camp trailer also.
Its not the Converter. its a Low Voltage condition that is very common in RV Parks. 30 amp service but to many units running to cool things down for your other guests. it will came on later tonight MAYBE. You can check the plug and you will find it warm wiht out a doubt.. sorry but thats the case in most that I have come across and i have a 38 footer with 2 ac .
Aug 08, 2011 | Heating & Cooling
I have a coleman model 8333A8664 a/c unit on a fleetwood camp trailer and was wondering what watt generator would be needed to run it properly?
Because it won't be powering just your AC, I would recommend 5000W. It's that big amp draw when compressor kicks in that will pull it way down, if not strong enough. Take for example the fact that a dedicated 20 amp breaker and cable are the norm for RV's to use for AC now. Double check also that the generator your purchasing will take a momentary surge draw of up to 20+ amps without tripping breaker on generator. I say 20+ because once RV is plugged in or wired to generator, it will be powering any other hydro operated appliances, lights, converter etc that the trailer has on board. I bought a cheapie rated at 4000W, and 3000 running watts, but it kicks out the breaker just trying to start my portable air compressor, rated at 15 amps.
Jun 10, 2010 | Heating & Cooling
Jul 15, 2009 | Coleman Mach III Air Conditioner
Hooked my 2007 Sprinter camping trailer to the factory lights/brakes hook-up located below bumper of my 2005 Silverado 4x4 extended cab truck. Everything works fine except for the right trailer turn...
Is this a 4 way or 6 way connection system? If your truck is wrong, then all factory equipped trailer package harnesses would be wrong, tell your trailer guy...I don't think so.
Is this the first trailer you have hauled?
Let me know, and we will go from there.
REgards,
Mar 10, 2009 | 2005 Chevrolet Silverado
Used 1981 Jayco pop-up travel trailer
Are these the bunk supports. I have a jayco of my own and I know there are lots of slots to put thinhs in so it can be difficult but each model is slightly different and if one support isn't in right than this can damage the frame. I would go to the jayco site and search for the nearest dealer and they are always helpful. But the nearest dealer might be a little ways away as alot of them are going out of business or merging with other dealers. The website is : http://www.jayco.com/php/products/camping.trailers/camping.trailers.php
Sep 24, 2008 | Sport & Outdoor - Others
Heating & Cooling Logo
180 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
