Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My Chamberlin remote garage door opener stopped working.
As stated above, my remote opener stopped working. I replaced the battery and it still does not work. I tried reprogramming it, still no good. I bought a new remote opener and tried programming it and that does not work either. My Chamberlin opener unit has a blue "learn" button and no external dip switches. The original opener does not have accessible dip switches but the new one does. These are accessible through the cover for the battery. The opener is less than a year old. The opener unit does work from the manual pushbutton mounted inside my garage.
  • Anonymous Mar 14, 2014
    remote wont work
    have to reset
Posted on Feb 16, 2009
I can't get my older garage door remotes to program with the new unit.Do I have to buy new remotes?
SORRY TO SAY.THE ANSWER IS YES.
THE NEW OPENERS ARE NOT ON THE SAME FREQUENCY.
YOU CAN PURCHASE REMOTES THAT WILL WORK WITH BOTH OLD AND NEW OPENERS (DUAL FREQUENCY).
BUT, OLD REMOTES WILL NOT WORK WITH THE NEW OPENERS.
Dec 29, 2014 | Craftsman Sears Liftmaster Garage Door...
How do i reprogram the remote transmitters i have along with the new transmitter that come with the opener? Chamberlin Security+ type
If you are trying to program remotes that are older than April 2005 they will not work with your new opener.
Feb 13, 2011 | Sears Craftsman LiftMaster Chamberlain...
My garage opener remote on my 2003 santa fe just stopped working. How can I fix it?
There is a battery in the remote.If the battery gets old the remote will stop working.Replace the battery and check.Also if your battery is new but still the problem is there then,try to open the garage door by keeping less distance between remote as well as the garage door.Also there is a sensor in the garage door.If that sensor is not functioning then this can be one issue.In some cases the internal remote circuit gets short,in that case the remote needs replacement.But does the garage door sensor light shows any sign of getting connection from remote when you press the remote button.Open the door and try to close the door with remote and check.As per the problem,in most cases its weak battery related problem,and replacing the battery solves the problem.You can try all the possibilities and see which one helps.Thanks.Helpmech.
Nov 12, 2010 | 2003 Hyundai Santa Fe
I have 1half h\p chamberlin garage door opener
Unplug the opener and remove the bulbs. Use a small screwdriver to pull out on the center contact in the socket. Make sure you are using standard bulbs.
May 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Unplug the unit and remove the bulbs. Using a small screwdriver pull out on the center connection in the socket.
Apr 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
Keypad for chamberlin garage door opener stopped working
You need to reprogram the keypad. Press and release the learn button on the back of the motor. Within 20 seconds, press your four digit code into the keypad and press and hold the enter button until the lightbulb on the motor blinks once. You are finished.
Feb 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Door Remote Not Working Consistently
Replacing 315 with 390 OR 390 with 315? I had same problem which went away on its own. Did you buy any new electrical or electronic products just before problem started? I had this with a customer who had electrical interference from within house or a neighbor's satelite dish. You can try turning off breakers one at a time to isolate circuit causing problem .
Feb 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote/homelink and touchpad problem
Your keypad is not the same "generation" as your remotes. You operator will work with your security plus remotes or your old keypad but not both. Yor cheapest solution is to replace your keypad.
Feb 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
2 different openers stopped working by remote at the same time
Both the older genie and a newer chamberlain (3-4 yrs old) both run on 390Mhz frequency. sounds like you will have to change your receivers on both operators (365LM 315Mhz) then get 3 button remote so you can program both doors on one remote.
Jan 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
2,682 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
