Is tthere a recall on lythium battery SONY DVP fx 930 WITH np fx110 BATTERY
Battery NP FX 110
5 Suggested Answers
joey64
  • 209 Answers
SOURCE: Sony DVP-FX810
go to the web site www.dvdunlockcode.com
Posted on Dec 26, 2007
SOURCE: Sony DVP FX 720
I have not got a problem with the screen, it works fine, I just want to make it multi regional, so need the codes for it please?, and the player type is SONY DVP FX 720
Posted on Jun 24, 2008
SOURCE: Multi Region hack for Sony DVP FX 820
Buy the Philips PET1030 instead.
Posted on Aug 30, 2008
  • 252 Answers
SOURCE: SONY DVP FX-930 unit 8 months old, tried DVD's,
Your pick up or lenz needs cleaning then your dvd player will be able to read your DVD. Please buy a good DVD cleaner.
Posted on Aug 13, 2010
I have used my Sony Handycam DCR-SR40 and the battery went dead. I then charged the battery several times and still won't turn on. I even attach the camcorder to the Sony base and connect it to the...
This is usually caused by a failed component in the power circuit within the camera and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Sep 06, 2010 | Sony Handycam DCR-SR40 Camcorder
Tip
Sony np-f330 battery...
Laptop batteries, like all rechargeable battery packs, lose their charging capacity over time. Because new Laptop batteries are expensive, replacing the individual cells inside the battery casing can save a lot of money. However, rebuilding a battery sometimes does not work as expected, so it’s important to be willing to purchase a new laptop battery if the procedure fails.
90-04208-003_original-hp-pavilion-dv8000z.jpg?w=250
HP Pavilion DV1100 Battery 12 cells
1、Allow the laptop battery to run down completely. Turn off your laptop, then remove the battery. Write down the model number located on your battery to help identify the type of Li-ion replacement cells you need to purchase.
2、Split open a small section of the laptop battery pack (at the seam) with a screwdriver or craft knife. Continue to pry the plastic case loose moving around the outer edge until the entire top is free. This may take a bit of force.
3、Note the number of cells inside the case (usually four to eight). Write down the part number and voltage information printed on the cell casings. Draw a diagram showing the arrangement of the cells and how they are connected, or take a few photos to help with reassembly.
4、Purchase the correct number and type replacement batteries from online shop such as udtek.com, based on your battery model and cell specifications. Six Li-ion cells typically cost around $30 to $40.
5、Carefully remove each cell using a craft knife and wire cutters as necessary. Each battery pack is different, but the cells are usually wrapped in a plastic casing with metal contacts attached to one end. Lay the metal contacts, wires and casing material aside.
6、Use double-sided tape or a solder gun (only if necessary) to attach the metal contacts to the cells and circuit board. When finished, the old cells should be completely stripped (naked) and the new cells should look like the old ones as much as possible.
7、Place the new cells inside the case, referring to your diagram or photos if necessary. Glue the battery(Compaq DV6000 Battery) pack top back on. Charge the new battery for at least 24 hours before using it.
Tips & Warnings
Keep an eye on the new battery while it charges for the first time. If the contacts are not connected properly, the battery could overheat and cause damage to the laptop.
on Oct 19, 2010 | Computers & Internet
Tip
Sony NP-BG1 battery|Cheap NP-BG1 digital camera batteries
New,1100mAh, 3.60V, Li-ion, Sony Battery Pack
  • Chemistry : Li-ion
  • Voltage : 3.60V
  • Capacity : 1100mAh
  • Dimension : 41.90 x 35.40 x 8.10 mm
  • Color : Black
  • Brand : Sony Digital Camcera Battery
Replacement SONY NP-BG1 Digital Camera Batteries, Li-ion SONY NP-BG1 Battery Pack
on Jul 20, 2010 | Cameras
SONY DVP FX-930 unit 8 months old, tried DVD's, CD's insert disc and no matter what disc I install the unit displays "NO DISC".
Aug 13, 2010 | Sony DVP-FX930 Portable DVD Player
My handycam works fine with a np-f550 3 hour battery. With the np-750 6 hr battery it starts out okay but then 5 minutes later the charge drops to zero... is he battery bad? It charges up fine.
dear
np-750 ur mentioning ....n other you r using is np-f 550
ther is allot of difference in both of the model npf stands for info lithium battery ....
make sure 1 st that other one is also NPF
if yes, then your battery is faulty cells in battery has become week.
Jun 25, 2009 | Sony Handycam CCD-TRV57 Camcorder
Battery NP-FM30
If you want to buy locally , here a list of the biggest Sony authorized resellers near Harrisburg,
In Harrisburg try:
Camera Repair Japan Co-
(770) 849-0555
View
One of the biggest ones is the one below in Lancaster.
Perfect Image Service Center Inc. 1862 Lincoln Hwy East, Lancaster - (717) 397-3019 Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you want to buy online try one of the following sellers:
Sony InfoLithium M Battery NP-FM30, NP-FM50 ... $25.99 –
SONY Camcorder Battery NP-FM30 NP-FM50 NP-FM51$23.00
Feb 28, 2009 | Sony Handycam DCR-TRV250E Digital...
BATTERY
When it comes to this matter,If it isn't the snoy battery problem,then it must be the problem of sony camera charger.
For the NP-BG1 problem,you can refer to this website for help information.
Sony NP-BG1 , Sony NP-FG1 ,np-bg1 digital camera battery charger
Jan 06, 2009 | Sony Cyber-Shot DSC-W7 Digital Camera
Aug 29, 2008 | Televison & Video
Sony DVP FX 720
Jun 23, 2008 | Sony DVP-FX700 Portable DVD Player
Televison & Video Logo
194 people viewed this question
Top Televison & Video Experts
Electro Med Services...
