Question about Polaris Ranger RZR Ride on Toy
Back wheel locked up - Polaris Ranger RZR Ride on Toy
    Genius:
  • Polaris Master
  • 1,508 Answers
Bad gear box, let me know if you need a replacement
Posted on May 14, 2012
I charged scooter and it still won't move back wheels seem to be locked up
that's normal the wheels r locked if u moved the free wheel lever check to c if its back in lock position if it is and the scooter wont move it might b an electrical problem check to c if its got a reset button ....good luck
Jul 02, 2015 | Health & Beauty
Got a 2012 ltx 1045 the wheels are all locked p I tried to pull the back lever to get it to move but all 4 wheels are locked help
this is rather odd as none I have seen are 4 wheel drive. only rear wheels drive and if the clutch/brake pedal is down and locked it will not roll when you releases the back lever
Mar 20, 2015 | Garden
My 2004 Santa Fe will not start steering wheel will not lock I wonder if that's the problem just started yesterday.
The wheel (all theft and safety) locks are connected to other components. They are on shifter, brake, and steering wheel. Try putting vehicle in neutral and with foot on brake see if it will start like that. It may just be a little off for wheel, brake, and shifter to mesh and lock up. They all have a say in how it goes. If vehicle is on hill of any kind it can keep locks from going, if wheel is turned to odd spot, or lock from shifter is off, they can all keep system from locking up. Would guess that it is not starting because one of the neutral safety switches is not engaged and wheel lock is kind of a side affect of this also. If you can take key out of ignition but wheel is not locked there is clearly an issue with the lock up system. But the wheel lock points are not at every inch of wheel turn. Sometimes you turn vehicle off with wheel at a point a little off from one of the holes and you just turn wheel a bit and lock will engage. But try starting in neutral - try moving shifter all the way back and then into park (with brake pushed) and see if they will get back in sync. You may have to push / roll vehicle a little to get weight off shifter and wheel, but if shifter moves from park with no brake, or key comes out with no wheel lock (or with shifter not in park) something in the 3 way lock system has come out of sync.
Feb 16, 2015 | 2004 Hyundai Santa Fe
CC 989 quit pulling after replacing rear wheels
on my snow blower there was two positions to put the drive wheels back on, locked and unlocked. need to put the pin in the locked position thru the wheels and axles.
Aug 10, 2012 | Cub Cadet Garden
Rear left tyre is locked due to constant rain and wet crossings. Have taken wheel off and tapped but still not released. Any other suggestions. Have also locked and unlocked handbrake to no...
I think you will find that the brake shoes are locking the wheel due to the wheel cylinders not being able to return fully. On trucks that use hydrolic brakes you can find a small wheel type adjuster in the backing plate. Usually 1 per cylinder and theres often 2 cylinders per wheel. Try to de-adjust the wheel cylinders to free the wheel. This wil only allow the wheel to turn. After a brake aplication u might find the wheel is back to the original situation. So i suggest removing the brake drum and investigating further.
Jan 04, 2011 | Mitsubishi Lancer Cars & Trucks
Turned steering wheel after powering off cuz I am parked on a hill...it locked up and now the ignition is locked too...how can I start the car?
your steering wheel lock is connected to ignition in column, pull hard on steering wheel in direction wheels are turned at the same time turn key, this should free them both up.
May 18, 2010 | Subaru Impreza Cars & Trucks
How do i adjust the hand brake on a e46 bmw
1st loossen up cable adjusters then remove rear wheels, remember safety 1st support car and through wheel stud hole you can turn adjuster star wheel with a small screwdriver till wheel locks then back off 4-6 clicks till wheel runs free next re adjust hand brake cable back up, again till wheels lock and again back of till free!
Apr 25, 2010 | 2001 BMW 3 Series
1996 Chevy Corsica Steering Wheel Locked
You would have to remove the steering wheel assembly to access the lock plate to push the pin back.
Feb 26, 2010 | Chevrolet Corsica Cars & Trucks
I have an 86 4runner with the steering wheel locked
turn the steering wheel back and forth while turning the key @ the same time
Oct 03, 2009 | 1998 Toyota 4Runner
I think my wheel cylinders is locked up but i'm not for sure
pull the wheel remove the drum and check thats the only way to know for sure. Also check to see if your e-brake locked up. Chances are your riding on the shoes and it got damaged inside
Sep 11, 2009 | 2001 Dodge Neon
Polaris Ranger RZR Ride on Toy Logo
90 people viewed this question
Top Polaris Toys Experts
Adam Fjeld
Adam Fjeld
cwradio73
D. E. Hev
Are you a Polaris Toy Expert? Answer questions, earn points and help others
