Question about Amana Dryers
How do I replace the motor in an Amana ned7200tw?
Ned7200tw
5 Suggested Answers
  • 2699 Answers
SOURCE: my amana ned7200tw electric dryer turns on but
all there is is a belt that turns the drum,the belt goes on the motor pulley around the pulley and around the drum, check the motor pulley to see if it unattached from motor shaft or check the belt to see if it flipped over somehow,there is a smooth side and a ribbed side on the belt and you said the pulley is fine
Posted on Nov 07, 2009
EllaWatson25
  • 725 Answers
SOURCE: I have an Amana NED7200TW Electric Dryer that was
You probably busted the element during the move and this not a serious problem. These parts are fragile and easy to repair. Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service and we will get the correct part out to you asap.Call us from 7 AM until 9 PM CST. We hope to help you repair your dryer. Thanks, Ella
Posted on Nov 17, 2009
kel1guy2002
  • 3740 Answers
SOURCE: My Amana NED7200TW dryer still shuts down with no
Hi and welcome to FixYa. The symptom you describe can be caused by several things.
If the belt is getting loose the belt switch can cause it to shut down completely with no power (Item 5) This link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5176187&diagram_id=1364250#d1364250
Also if your dryer has a thermistor vs a thermal fuse
(Item 27) of this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5176187&diagram_id=1363930#d1363930
it can also shut the dryer down when it gets too hot.
You should check all of your vent ducting from inside the dryer all the way through to the exit point on the outside wall (vent flapper) for obstructions / lint.
Also if you use dryer sheets (Fabric softener) you should clean your lint filter with white vinegar then soap and water / rinse. The particulate fromthe dryer sheets cakes onto the filter. It looks clean but willnot pass enough air.
This should give you something to go on to try and resolve the shutting down issue.
Thanks for using FixYa.
Kelly
Posted on Apr 12, 2010
heatman101
  • 43501 Answers
SOURCE: My Amana NED7200TW runs but will not heat up. I
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;
Posted on May 10, 2011
Amana dryer ned7200tw Thermo Fuse
Remove back to get to thermo fuse. Remove contacts. Remove screw and remove fuse. Install in reverse order.
Jan 23, 2018 | Amana Dryers
My amana dryer model #NED7200TW turns on and the motor runs nicely but the drum wont turn on its own. It will turn easily if i turn it with my hand. only about 3 years old.
if your saying theres a motor running but the drum wont turn . then id say either the idler pulley has come off or drive belt has broken , these do go bad especially on heavy load machines
Sep 14, 2016 | Amana NED7200TW Electric Dryer
I have the part to replace broken heat element on Amana 6100; where are the screws holding it in place?
Replace Amana NED7200TW Heating Element Heater Coil ...
? 10:43
https://www.youtube.com/watch?v=5469BpQpJZQ
Dec 14, 2014 - Uploaded by Mike Griswold
How to replace the heating element on your Amana NED7200TW Dryer. ... Pulled apart my dryer and ...
Oct 31, 2015 | Amana Kitchen Ranges
I keep getting an error code that looks like 2 C's. The dryer is still drying but it will finish and shut off and then turn back on. What does this mean?
Amana NED7200TW Technical Information - ManualsLib
www.manualslib.com > Brands > Amana Manuals > Dryer > NED7200TW
View and Download Amana NED7200TW technical information online. 27" Domestic. NED7200TW Dryer pdf manual download.
Aug 05, 2015 | Amana NED7200TW Electric Dryer
I have an Amana NED7200TW suddenly stopped working. Power is on, panel lights up. replaced the thermistor still will not start. no error codes come up. What else should I look at?
How about the fuse right beside the thermister? Did you maybe remove a wire from it by accident while replacing thermister?
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 18, 2013 | Amana NED7200TW Electric Dryer
Stop button doesn't work on Amana NED7200TW Electric Dryer.
Check the door switch to see if it "clicks" when you push and release it. If it clicks, then the control board will need to be replaced. Here is the part you will need to order.
Nov 01, 2012 | Dryers
Dryer will not start get an error code that looks like a t5.
It is actually error code "tS" which stands for thermistor shorted. The control interprets it as an extremely low resistance which is a result of a the dryer overheating. Locate the thermistor on the blower housing and replace it. Click on the link below and refer to the parts diagram then look for item number 27(thermistor).
Amana NED7200TW Electric Dryer Bulkhead Parts
Click on the link below if the error code still appears after replacing the thermistor.
Persistent Error Code "tS" on Amana NED7200TW Electric Dryer
Aug 21, 2011 | Amana NED7200TW Electric Dryer
I have an Amana dryer model # NED7200TW that will not power on
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Can't find new heater for NED7200TW Amana dryer.
Here is the part...
http://www.partselect.com/MultiModels.aspx?ModelNum=ned7200tw&searchTerm=&RefineSearch=0&Page=2
Hereis a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Sep 22, 2010 | Amana NED7200TW Electric Dryer
My amana ned7200tw electric dryer turns on but doesn't tumble/run... the pulley is ok checked that any other ideas
Nov 07, 2009 | Amana NED7200TW Electric Dryer
Dryers Logo
98 people viewed this question
Top Amana Dryers Experts
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
