Question about Miele W864 Front Load Washer
Check inlet light flashing
We bought the machine second hand with no manual.The light is flashing, we've had the machne for 3 years, it has been amazing so far.
Thats easy peasy! Get a butter knife, open the little door at the bottom left...... now this is gonna make a mess so best you put loads of towels down or find someother way because my machine is on bricks.... so when you open the door, you unscrew the dial and then water will start trickling out, the more you open, the bigger the gush.... you can close it again and control how you mop up but basically you have to unscrew and remove the dial, and there will be debris clogging the outlet, clean it and then put it back, close the door and you are all fixed.xx
Posted on Feb 21, 2012
Camileo P10 charging problem
I had the same problem with the P10 not charging via USB, I purchased mine second hand so it came with no charger. I assumed it would charge by the USB cable but it did not, the red light flashes but doesn't charge. Luckily I have an external battery charger for a different camera i got some years ago that takes a similar battery , the P10 battery didn't fit properly so I had to place it at a 45 degree angle into the charger making sure the outer contacts were lined up properly and taped it into place. After an hour it was fully charged and the camera is working fine. The charger is a 4.2 volt charger. New external chargers can be picked up on ebay cheaply
Jul 04, 2012 | Toshiba Camileo P10 Flash Media Camcorder
I've got a Kelvinator dishwasher KD12MM bought second hand, the machine goes on but does not pump water. Please help
Possible that the pump has clogged or is jammed with dirt. you will need to remove the pump and clean the pump assembly for a good spray pressure. If this wont work then the pump is faulty and needs to be replaced.Check this link for tips:
http://www.espares.co.uk/advice/dishwashers/a/3
Mar 12, 2012 | Kelvinator Dishwashers
I've just bought one. Is it normal that the hand wheel is hard to turn. Does not that put stress on its motor?
hi, if you just bought this machine, my suggestion is to take it back & get another one.
the handwheel is not suppose to be hard to turn when it's brand new.. I've been sewing for over 30 years & I wouldn't keep the machine, I'd take it back & get another that works properly.
Sep 23, 2011 | Singer 8280 Mechanical Sewing Machine
My brother Se 400 which is only a few months old just started running really slow. When I disconnect the foot petal and do the manual botton "the arrow button" it still runs slow. I don't...
have you checked to make sure the power cord is pushed in correctly?
if the power cord isn't the problem then it may need to be checked by a service tech, because it's not suppose to be running slow just a few months after you bought it.
I would call the people you bought it from & tell them what it's doing & see if they'll give you another one, I've been sewing for 30+ years & I wouldn't keep the machine.
good luck
Sep 22, 2011 | Brother Sewing Machines
My 2001 Ford Crown Victoria has had the check engine light on for a while, and the code came up as something to do with the fuel pump circuit. Now I've been seeing some sluggish acceleration and a kind...
Take it to a repair shop & then use the
computer to study OBD2 Systems & get
a cheap code reader
Look at a fuse,they do not fix anything
& hardy ever blow.
When you say check light has been on for awhile
Are you not aware of why the dash light come on?
They have been on all vehicles for 31 years now
Any dash light is a System Malfunction,& you need to
check for codes within a couple of days or stop using
the car,each & every time,unless you understand the
current OBD2 Systems & have at least a code reader
Jul 02, 2011 | 2001 Ford Crown Victoria
Miele W1926 check inlet light flashes at he end of rinse fill
Hi Yugin.That indicates your machines water inlet valve is faulty.(Means it's taking less water then normal)Please check this steps & do it fast before water inlet is finishes:1-Turn your machine on & run empty with pre-wash cycle first.2-Please ajar the detergent drawer & check runing water on compartment one 3-Please press pre-wash button & compare the running water volume on compartment two.If the running water volume 1 is less then 2 or vs.water valve needs to be replace.That's causing problem.I hope that helps.Thanks.
Jul 26, 2010 | Miele W1926A Front Load Washer
Doesnt wash properly
Check the inlet screens on both sides of the pipes. (Plug off the wall first) Open your inlet full before wash. Check outlet filter to clean out, check to see if any debris in pump. Is this machine second hand? If so you can download a manual.......
Nov 30, 2007 | Whirlpool LHW0050PQ Front Load Washer
Miele W864 Front Load Washer Logo
148 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
