Question about Garden
Pressure washer problem
Pressure washer runs great for about 5 min. then motor drags down and feels seized as can't pull starter cord. After cooling down, it restarts and runs good again for about 5 min. then repeats cycle
    Sergeant:
  • 316 Answers
Hello,After it stalls take the fuel cap off and put it back on and see if it starts,maybe the cap is bad or clogged and not letting air in to equalize the pressure of the fuel being used in other wards a cloged vent, !!
Posted on Feb 18, 2012
  • pamabell Feb 18, 2012
    hello,After it stalls take the fuel cap off and put it back on and see if it starts,maybe the cap is bad or clogged and not letting air in to equalize the pressure of the fuel being used in other wards a cloged vent, ``
Why will the pull cord not pull on my honda pressure washer gcv160?
You need to disconnect the pump from the engine to see if the pump is seized.
Jul 29, 2014 | Garden
Pressurewasher runs fine then shuts down and cant pull
Same thing happened to me and I found out that water was getting into the carb filter media. Try taking the carb filter cover off and see if the foam filter is wet. If so, try starting without the filter and see if it works. THis issue used to drive me crazy on my unit, hope this helps.
Jan 20, 2013 | Garden
Crank pull cord doesn't pull out on honda pressure washer.. The machine is only 3 months old
if the fuel tap has been left on it may have fuel on top of the cylinder and would not able to pull cord.
if so take the spark plug out and turn over,fuel may come out of hole.replace spark plug and try to start. if it still won't turn over,you will need to take the face plate off the motor. remove and inspect if there is any foreign objects. try to turn motor over by hand., grab on to fly wheel & turn. if it moves freely it may be the pull start it-self. try pulling the cord out. if no problem assemble and try to start.
Dec 02, 2010 | Honda Pressure Washer PSI 3000
Pull cord getting stuck
Pull starter rope wheel is Jamming against casing usually some lube n check for ware will fix it
Mar 21, 2010 | Karcher 2500 PSI Pressure Washer
The pull cord is stuck, can't be pulled to start
This solution applies to the Sears model 358.797200, which also appears to the FL1500LE marketed under the Craftsman name, and may apply to other, similar, blowers. Go to the searspartsdirect.com site and enter the Sears model number. This blower may be prone to develop binding in the pull cord rewind spring compartment. (The binding may easily be misdiagnosed as a seized up engine.) The binding can be fixed by adding washers to increase the spacing. Open the rewind starter page on the sears site for an exploded view. I found that by placing 2 washers on each of the 5 screws (no. 7 on the diagram) which attach impeller housing (12) to the motor, I increased the spacing enough so the pull cord operated and retracted normally. The washers must go between the impeller housing and the motor. To complete the repair, you need to add a washer between the spacing flywheel (14) and the impeller(15) to keep the impeller from binding against the housing. The gasoline tank screws won't line up as well with the holes, but will fit. Install all 3 screws for the at first loosely, then tighten them down.
Oct 25, 2009 | Garden
Power Washer will not start - pull cord seems to be stuck
hi take out the bolts holding the compleat pull starter remove unit pull the cord if it wont move something is jamming it inside if it is ok then the fault is with the motor //seized or washer remove washer pump if engine turns over /pump seized the fault is 1 of the three you have now found out wich 1 starter, motor or pump it will take too long to go over all 3 get back when you have got this far merlinv12
Aug 22, 2009 | Honda Maxus Pressure Washer MX5222
Motor seems to be locked up!!!!!!!!
It may be your engine, but it may also be the water pressure. Try this: Hold the trigger down while pulling the recoil starter. This acts as an unloader for the pressure washer, and may allow the engine to turn over. There is also an oil level in the pump as well as the engine. Check both levels.
Just a thought, but I've been there. Best regards, W/D
Aug 16, 2009 | Devilbliss DeVILBISS Devap DVH2600...
Honda GC190 engine shuts down on my Karcher 3000 PSI PW
Well would you believe that I have the very same problem. I suspected that the pump was seizing up, so we tried the pump on another unit and it worked fine. On inspection of the motor we found the cam (which also operates the decompression mechanism) was worn out. It's made of hard plastic. It is only about 7 dollars too, so cheap enough to fix. I have mine ordered now and feel pretty confident that that should fix it.
Aug 13, 2009 | Karcher 2500 PSI Pressure Washer
The pull cord will not pull..I can't start the engine. What can I do?
Remove the spark plug and see if it will then turn over. If it does then the motor is not seized or has water or fluid it is trying to compress.
If the above lets it turn over freely the problem lies with the cord being trapped on the pully that is spring loaded.This task is better investigated by someone with experience to avoid losing parts and not beoing able to reassemble.
Jul 29, 2009 | Devilbliss DeVILBISS Devap DVH2600...
Garden Logo
110 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
