Question about Frigidaire AEQ6000ES Electric Dryer
Why will my dryer will run but not heat up - Frigidaire AEQ6000ES Electric Dryer
  • Mark Hickey Apr 19, 2012
    You may have the same problem I did, with the heating element. My solution is posted below. You really should download the manual from the link below and run through the diagnostic flowchart, however. You could have a bad fuse (thermal limiter or high limit thermostat), or a bad heating element, and each is more or less work and expense to replace. Here is what worked for me.
    Fixed this myself. - it was the heating element.
    Downloaded the service manual from this linkhttps://docs.google.com/file/d/0B5If-wTg...
    It has the error codes, but more importantly, it has wiring diagrams, instructions for taking the dryer apart, and troubleshooting flowcharts. I followed the flowchart for "dryer does not heat, but motor runs". The whole process probably took one hour. Dis-assembly, repair, and re-assembly probably took another 1-2 hours, but some of that was due to an initial bad re-stringing job (see below).
    To follow the flowcharts, you will need a multimeter or an ohmmeter and a voltmeter, You will need a medium philips head screwdriver to get the dryer apart. Note that when you are testing voltage drop (google testing voltage drop if you don't know what this is) across the terminals of the high-limit thermostat on the heating element housing, you need to be careful not to touch the terminal block where the power cord enters the Dryer at the same time you are physically touching the cabinet or you may get a strong shock (trust me!). By the way - you should check the chamber in the dorr below the lint trap before reassembly...mine had a huge wad of lint in it.
    When I completed the flowchart the result was"bad heating element", and when I took out the drum and tested continuity through the heating element, there was none. When I touched the element,, it was brittle and broke.
    You can buy a replacement unit with the heat shield (metal pan that it sits in) and coil for about $60-$70, or just the coil for about $25. You may have to call around to find a parts place with either item in stock. When I saw how the coil was attached (very simple). I opted for the coil only (called a "restring") as it was cheaper and less work to replace. Got it locally for $25. Took about 10 minutes to put it in and then about 20 minutes to put the dyer back together (not counting my fumbling with the bad restringing job.. Follow the directions int the package with the coil for how to string the coil on the insulating clips. I did not realize there *were* instructions, and just tossed it on. When I put the drum back in and tested it, I had an awful screeching friction noise. I eventually realized that the gap between the drum and the coil is pretty small, and I had a bulge in one section of the coil; following the instructions probably would have avoided this. I just redistributed the coil over the insulating clips and twisted a few sections in tthe direction of the coiling (clockwise?) until everything appeared flat. Then the noise went Away and I dried my first load of laundry in 2 days. Good luck!
    Problem Solver:
  • 10 Answers
Downloaded the service manual from this linkhttps://docs.google.com/file/d/0B5If-wTgYWH5ZmRhODliYjktYjZmZC00OTdkLTk1MDQtZDA1YWQ1ZjFjMTI3/edit?hl=en&pli=1
Posted on Apr 19, 2012
Electric dryer runs but no heat. all thermal and motor and heater element have continuity.
Dryer Diagnostic - Not Heating up - Repair ... - YouTube
? 11:16
https://www.youtube.com/watch?v=3Vns05qIjGs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your trusty Maytag Electric Dryer suffering from some of the ... However, in REGULAR mode, it runs normal too, but theheat stops ...
Maytag Dryer Not Heating - How to Test the Heater and ...
? 4:12
https://www.youtube.com/watch?v=_zjiZ0sbCgI
Oct 12, 2013 - Uploaded by Bill Newberry
How to test the heating element on a Maytag Dryer. If you Maytagdryer is running but not heating these are what you need to check. ... The dryer runs but does not heat. .... Not heating Maytag electric dryer - Duration: 19:38.
Not heating Maytag electric dryer - YouTube
Jan 13, 2016 | Maytag Dryers
Dryer does not heat up checked all thermostats and replaced heating element still no luck
hum... I ve seen where the motor was only getting 120 and not 240 and with most dryers they use 2 speeds or modes on the windings , 1 direction for drying with heat and the other to run minus heat thus if u only get 120 volts u have enough to run the dryer but not enough to run the heat to that dryer?
Aug 22, 2014 | Whirlpool EED4400WQ 29" Electric Dryer...
Kenmore dryer dont heat
In most cases it's not a bad heating element there are a few checks you need to make before buying a new heating element, you can follow this guide to make the repairs:
Electric Dryer Runs But Dont Heat
Feb 11, 2014 | Kenmore 63942 Dryer
My GE dryer has no heat but runs. Also when you put the setting on more dry or less dry the dryer will run for hours, but will run the correct time on the timed dry setting. Either way the dryer will not...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 07, 2010 | GE DBXR463EDWW Electric Dryer
Dryer runs but no heat
lean the exhaust vent tubes thoroughly and try again to heat up
a sensor in your dryer will shut down the heat if lint build up is present
Jun 07, 2010 | Amana NDE2330AY Electric Dryer
My dryer runs, but doesn't heat up...
heatman101
May 19, 2010 | Whirlpool LER4634J Electric Dryer
Roper dryer runs but has no heat
my roper dryer does not heat up i checked thermostat, thremo fuse and heating element they show working could it be my timer when dryer is running timer does nt advance it stays in the same position.
Jan 11, 2010 | Dryers
Dryer running but not heating. How do I check heating element?
Check the following to address this non heating issue
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jun 02, 2009 | Whirlpool Dryers
I am currently having a problem with my Kenmore Dryer. It is running but it is not heating up to dry the clothes. Someone told me to take the back off and check the heating element but I can't find the...
I would check your vent if I were you disconnect the vent and run the dryer to see if it works better. also clear the vent line. good luck
Jan 10, 2009 | Dryers
My roper dryer is not heating
YOUR HEATING ELEMENT IS BAD OR YOUR HEATER BOX FUSE IS BAD,IF YOU HAVE A METER YOU CAN CHECK THEM BOTH-LET ME KNOW-MIKE
Dec 06, 2008 | Roper REX4634KQ Electric Dryer
Dryers Logo
150 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
