Question about Garden
Pressure washer runs for short period of time then shuts down
    Sergeant:
  • 316 Answers
Hello,After it stalls take the fuel cap off and put it back on and see if it starts,maybe the cap is bad or clogged and not letting air in to equalize the pressure of the fuel being used in other wards a cloged vent, ~~
Posted on Feb 18, 2012
Will not shut off have to run it out of gas
It won't shut down because the gizmo that shorts the spark plug is not working. If possible take an insulated screw driver and either pull the spark plug wire off the plug or try to touch the end of the plug and the engine at the same time. If the switch is in the gas lever there may be an adjustment on or in it that shorts the plug out.
Apr 13, 2015 | Craftsman 2700 PSI Briggs Stratton...
Kenmore series 90 washer runs for a short period and then stops
Sorry to be the bearer of bad news but what your describing is a classis sign of a bad motor. When the motor is bad it will run will its cool...when it heats up it shuts off and will restart for a short time when colled off till once again hot and shuts off again.
GENE
Oct 29, 2011 | Washing Machines
Compressor UP6 25 125, runs all the time but is only under load for a short time, should it shut down between loads?
This unit will shut down if unloaded for a set period of time. Usually 5 to 10 minutes. This time could be longer if some one has changed it from the factory setting. There is a timer in the control box that starts counting down when the unit unloads. If it stays unloaded long enough for the timer to count down the unit will stop until the air pressure drops to the low set point on the pressure switch. It will then start up. If the unit loads before the counter counts down the timer starts from the beginning when it unloads again. This cycle continues until you manually shut it down or you stop using air long enough for the timer to reach Zero and shut down.
Apr 22, 2011 | Ingersoll Rand UP6-25-125 120 Gallon...
Pressure pump keeps pulsating when trigger not pressed
There is orobably a minor water leak on the output side of the pump. The pump is sensing a pressure drop due to the leak so it will run for short periods to maintain the pressure i the output line.
Aug 20, 2010 | Karcher PSI Electric Pressure Washer
The air conditioner for my 2001 volvo v70 turbo will shut down periodically while running in hot weather or when running while the vehicle is stopped (traffic) for an extended period. Shutting the AC off,...
There may be a restriction in the plumbing of the air conditioning system that is making the high side pressure too high, thus shutting off the a/c for safety reasons.
Or, the refrigerant pressure on the low side is too low, caused by not enough r134a refrigerant in the system.
Aug 13, 2010 | 2001 Volvo V70
SHUTS DOWN AFTER A SHORT PERIOD OF TIME. GREEN
this is a technical problem.have someone professional come and take a look.
Jun 15, 2010 | Heating & Cooling
Engine runs short time, then low oil pressure,then shuts off.
try replacing the oil sending unit, it is located at the back of the intake. it is about two inches long. it is black. it ties into the fuel injection system.hope this helps.
Jun 07, 2010 | 2000 Oldsmobile Bravada
When motor is at idle speed it surges
Try a simple test. It is ok to run the pump without water for a short time. Check idle speed without water in system to see if enginet surges. If it does not surge, then most likely the unloader/ pressure valve is causing the engine to surge when in the unloaded state. Life of unloader /pressure valve is shortened by letting system bypass for long periods of time. Enjoy
Nov 22, 2008 | Garden
Garden Logo
64 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
