Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
I have purchased a new straight replacement bubble tube for my one mor time 1015,any idea how to fit it,seems rather difficult without removing the rotating light,does it come out?
    Champion:
  • Wurlitzer Expert
  • 211 Answers
I presume you have solved this by now. You go in from the front. Remove the three metal bands by screws in the back of the door. The front plastic comes out like a tyre, sits in a groove each side. Squeeze and pull.
Posted on Aug 31, 2012
2 Suggested Answers
  • 98 Answers
SOURCE: I broke one of the glass bubble tubes. How can I
I have bubble tubes in stock. You just need to tell me which one you need. I can tell you the replacement procedure also. Please email tech@wurlitzer-ohio.com.
Posted on Feb 07, 2010
I need a manual...can you help?
Manuals are here. Real PDF's no charge as in FREE!
1987: One More Time (OMT) Introduction of the reproduction of the 1946-47 1015, but with a "Modern" 100 selection
45RPM record mechanism. (download PDF manual for OMT-45 - 2MB in size) ( OMT-45 Parts Manual ) (PDF of schematic for animated lights for very first OMTs - no bubble tubes!)
1989?: OMT-CD The new CD bubbler introduced! (download late 1990s PDF manual #22 - does not cover early OMT nor the New Orleans or New York, NY models) (OMT-CD Parts Manual #14 - !!errata!! - Pg 12 has the curved bubble tubes miss-numbered), (revised colour cylinders after serial #4003XXXX)
1995?: Elvis model OMT-CD
ALL THESES LINKS AND MUCH MUCH MOIRE INFO AND TROUBLESHOOTING CAN BE FOUND HERE - https://www.flippers.com/wurlitzr.html
You may have to poke around as I have found some manual links are incorrectly labeled.
Aug 05, 2015 | Wurlitzer Jukebox 1015 One More Time...
How do i take a broken bubble tube from front left side, out and put a new one in,
Undo the 3 'metal' bands by unscrewing from the back. Then squeeze the top of the plastic and pull. It fits like a tyre in a slot on each side. Then you can get to the bubble tube.
May 13, 2011 | Wurlitzer Jukebox 1015 One More Time...
How to replace a master brake cylinder on a 1989 oldsmobile 88 delta
First thing you need to do is bench bleed the new master cylinder.new master should have come with 2 plastic tubes and fittings.screw fittings into new master,fix tubes to fittings other end in to top of master where fluid goes.fill with fluid make sure the tubes are submergered in brake fluid for entire process.take a screwdriver and press plunger in rear of master.use short slow strokes to start you will see air bubbles in resovoir.slowly increase length of stoke watchin resovoir till no mome bubbles.now ready to install.Remove failed master,(loosen lines befofe removing mounting bolts)remove lines last.reinstall new master then remove bleeding tubes last install and tighten lines.Fill fluid replace lid,have a helper sit in car,loosen lines about half a turn.Have helper depress brake pedal slowly and hold down pedal untill lines tightened.when tight release pedal and repeat 5/6 times.fluid should come out of lines without any air when bled propperly.if failed master did not run out of fluid uyou should be finished.if pedal still soft/mushy will have to bleed a wheels also.use same proceedure but openening bleed screws not lines.may take many times to get rid of all air,you can see and hear the air exiting bleeders.keep an eye on fluid level while bleeding if u run out you are starting again
Jan 24, 2011 | Oldsmobile 88 Cars & Trucks
I am thinking about purchasing a friend's jukebox. It is a 1015, one more time model. It just has a cd player and an am/fm receiver. It does appear to have all the wires to connect the original...
A One More Time 1015 jukebox does not have a radio.
If it was a One More Time I'd check the fuses in the small circuit board in the middle inside of the door.
Aug 01, 2010 | Wurlitzer Jukebox 1015 One More Time...
I broke one of the glass bubble tubes. How can I get an replacment tube for my 1015 One More Time Black Onyx juke bos
Feb 04, 2010 | Wurlitzer Jukebox 1015 One More Time...
The fluid leaked out of one of the tubes that bubbles
I can sell you a replacement bubble tube. They are fairly easy to replace. I just need to know which one you need, straight, small curved or large curved. Rod Stebelton, tech@wurlitzer-ohio.com.
Dec 18, 2009 | Wurlitzer Jukebox 1015 One More Time...
Going to move my Wurlitzer 1015 300 miles. What do I have to do to stabalize the unit on the inside? Ron
If this is the original 1015 jukebox from 1945/46, plays either 24 X 45RPM or 78RPM records, then you need to remove all the records and their trays, secure the tone arm with some tape to its post, make sure the amplifier is locked in place, and then I would put an old sleeping bag or similar (pillow) into the space to the right of the record stack to prevent the turntable platter from banging up when you lay the machine on its back for transportation. Put a bit of tape on the straight bubble tubes to stop them from sliding out of their heaters - do this at the top of the tube and just leave the tape in place permanently.
When you arrive, first make sure that all the bubble tubes are in place, seated in their heaters, then check for loose parts, check the amp's tubes are seated, remove pillow, remove tape from tone arm, load records, cross your fingers and turn it back on.
Oct 15, 2009 | Wurlitzer Jukebox CD Player
1998 S-10 Manual Tranny problems
yes it sure sound like you have an air bubble in the slave cyl.
you must have seen my oil can bleeder
ive also made a new one out of a garden sprayer and adapted down to fit the bleeder screw.66253ce.jpgand this is even faster and makes bleeding simple good luck
Nov 13, 2008 | 1998 Chevrolet S-10 Pickup
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
149 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
