Question about Garden
Poulan chain saw factory spec for air gap ignition magento model 1175
    Sergeant:
  • 316 Answers
Hello,, the factory air gap is 0.008 to 0.010 depending on saw,,
Posted on Feb 18, 2012
Testimonial: "thanks for the info"
Hooking up wires on ignition coil on a mac-10-10-chainsaw
There are 2 items that you need to pay close attention to is the air gaps;
1. Air gap of the points, and
2. Air gap between the permanent magnet and the pick up coil.
Use the manual to determine the proper gap size.
Good Luck,
Rich Lilja
Jul 22, 2014 | McCulloch 1975 Pro 10-10 Automatic Chain...
How to change ignition
To change the ignition is a simple 2 bolt removal. Sand with a very fine emory cloth the mounting location.This insures a good ground contact between the ignition and cylinder. Then make sure you set the proper air gap between the ignition and flywheel.This is the most important part. You can get the air gap from you Service Manual. Tighten the bolts down to proper torque, hook up your lead wire and ground for switch and your good to go.
Jul 20, 2014 | Poulan Wild Thing 2375 18" Gas Chain Saw...
How do i adjust the module-ignition on poulan pro chain saw model #PP4218AVWhat's your problem?
are you talking about the magneto to the flywheel gap i just use a piece of paper between the two and tighten it
Apr 07, 2012 | Poulan Pro Chain Saw 46cc 20"
HOW TO TEST IGNITION COIL ON A POULAN CHAIN SAW MODEL 2000? ALSO WHAT IS THE AIR GAP ADJUSTMENT FOR THE SAME?
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You do not have to bend up the electrode.
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when the flywheel is rotated.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 12, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
What is the gap for the ignition module on a poulan wild thing chain saw?
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Apr 15, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Doesn't want to start. Replace carb and ran for few seconds, Make you think that it is not getting gas, but pouring gas into spark plug does not help and drying spark plug dose not help. Spark appears...
The spark should be blue and snappy. Try a new plug--any help? If not, it may need a new ignition module. Check the flywheel magnets--they should be quite strong. The module gap with the magnets underneath the poles should be about business card thickness. Check the air cleaner and muffler for plugging. Hope this gets it running!
Apr 07, 2010 | Poulan 1630 16" Chain Saw
What is distance from coil to stator 14 in. poulan chain saw
I think you are asking for gap between the fly wheel and the ignition module. A business or index card works great. 0.1 - 0.3 mm. GL
Lou
Oct 09, 2009 | Poulan Pro Chain Saw 46cc 20"
I need t find an air filter for poulan 306a chain saw
I got 1 hit for your filter, if you haven' already give them a try "Poulan air filter 530023046"
http://www.lawnmowerpros.com/Poulan-Parts-Search.asp
Lou
Sep 04, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan saw wont start has spark and fuel
Look for a pinched/bare stop-switch wire (I assume that you don't have spark now). Also, check the ignition coil core gap to the flywheel magnets (I use card stock to set the gap). Make sure the plug wire was not damaged again.
Aug 25, 2009 | Poulan Pro Chain Saw 46cc 20"
Garden Logo
255 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
