Question about Canon PIXMA MP210 Photo All-In-One Printer
Front tray, paper jam
I can not take the paper out of the front tray
  • 435 Answers
Please visit below mentioned links to solve the problem of paper jam:
Paper Jam Problem
Thank You
Posted on Oct 26, 2008
I don't have the manual and the red light is on. Is that the toner needing replacing and how do I do it?
Here are the things that a steady red light may indicate (from the Owner's Manual):
led-erroron17.jpg A paper jam has occurred. To solve the problem, see "Clearing Jams in the Paper Tray". The front cover is open. Close the front cover. The top cover is open. Close the top cover. The paper tray is empty. Load paper in the tray. See "Loading Paper". A toner cartridge is not installed. Install a toner cartridge. See "Installing the Starter Toner Cartridge".
• A paper jam has occurred. Check the paper tray area.
• The front cover is open. Close the front cover.
• The top cover is open. Close the top cover.
• The paper tray is empty. Load paper in the tray.
• A toner cartridge is not installed. Install a toner cartridge.
Jul 26, 2011 | Dell 1110 Laser Printer
Paper jam printer 3524
Clear the jammed paper as follows.
If the jammed paper is removed completely by using the information in the following steps, you can install the paper tray first, and then close the front cover and the printer will resume printing automatically.
If the printer does not start printing automatically, press the Go button. If the printer still does not start printing, please check that all the remaining jammed paper has been removed from the printer. Then try printing again.
Pull the paper tray completely out of the printer.
Pull the jammed paper up and out of the printer.
Press the cover release button and then open the front cover.
Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared, go to Step 7.
Open the jam clear cover. Pull the jammed paper out of the fuser unit.
Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
Pull the Duplex Tray completly out of the printer.
Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
Put the drum unit assembly back in the printer.
Put the paper tray in the printer.
Dec 21, 2010 | Office Equipment & Supplies
I'm getting Jam at Reg Roll on my Phaser 6180, and I think there may be a bit of paper in the paper path, but i can't see it. The machine says Open Door A, which I've done a few times, but it isn't...
Had exactly the same problem... today actually.
Found the solution with another model's manual - I removed the paper from the top, but hadn't realised there was a jam in the paper tray. It was only when pulling it out completely that I found it as below...
Jam at Registration Roller
1. Remove Tray 2 completely.
2. Clear the jammed paper from the printer's
intake slot.
3. Re-insert Tray 2.
4. Open front door A.
5. Remove jammed paper if present.
6. Close front door A
Nov 23, 2010 | Xerox Phaser 6180N Laser Printer
My Brother HL 5250DN printer has started making a loud clicking sound when it tries to feed paper for printing. It then stops and the paper light starts flashing.
Observe Cautions signs in printer.
Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and prevents paper jams.
1. Press the cover release button and then open the front cover.
2. Slowly take out the drum unit and toner cartridge assembly. The jammed paper will be pulled out with the drum unit and toner cartridge assembly.
3. Pull the paper tray completely out of the printer.
4. Close the front cover.
5. Pull the jammed paper up and out of the printer.
6. Open the front cover again.
7. Open the back cover.
8. Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
9. Using both hands, gently pull the jammed paper out of the fuser unit.
10. Close the back cover.
11. Pull the duplex tray completely out of the printer.
12. Pull the the jammed paper out of the printer or the duplex tray. Put the duplex tray back in the printer.
13. Push down the blue lock lever and take the toner cartridge out of the drum unit. Clear the jammed paper if there is any inside the drum unit.
14. Put the toner cartridge back into the drum unit until you hear it lock into place. If you put the cartridge in properly, the blue lock lever will lift automatically.
15. Put the drum unit and toner cartridge assembly back in the printer.
16. Put the paper tray firmly back in the printer.
17. Close the front cover.
18. Make sure that the Paper LED is now off and the printer is ready.
After clearing paper jam if noise persist printer may need a Repair Tech and parts replacement for broken or wore parts.
Dec 04, 2009 | Brother Office Equipment & Supplies
While printing with OKI C5600 very often error message pops up about jammed paper though no REAL jam happened. To solve I just open and close paper tray and front door. JAM PAPER error is real pain if...
Have you tried cleaning the paper feed roller(s)? Either soap & water OR isopropyl alchohol with a cotton ball will do, just make sure the rollers are dry before trying to print again, otherwise damage to imaging unit (drum/toner unit) could occurr. If the printer doesn't feed in the first place, the printer thinks it has a jammed paper, thus opening paper tray and front cover resets misfeed/ jam condition. Let me know your progress....Tim
Oct 24, 2009 | OKI C5500n Printer
Got a paer jam and don't know how to open cover,
Turn of the printer, and do not close any of the tray or doors before all of the jams are cleared.
1). remove the paper from paper tray, removed the tray and remove the jams.
2).open the front cover and removed the toner cartidge assembly, remove any jams in this area, and behid the toner cartridge asembly.
3).left the flap at the front of the printer adn remove any jams heneath the lap.
4).Open the rear exit and remove any james.
close all covers and reinsert the paper tray and turn on the printer.
May 13, 2009 | Dell 1700 Laser Printer
Paper Jam
There is a small clear plastic sheet that is suppose to be in front of the black friction pad in the paper tray. if that sheet is under the pad instead of in front of it you will get this error.
Mar 24, 2009 | Ricoh Aficio SP C410DN Laser Printer
The paper feed jammed allowing some print/now says empty but not
Look at the paper path very carefully. There might be a piece of paper that got torn off and is either jammed up in the fuser or the registration assembly.
Jan 06, 2009 | Lexmark E232 Laser Printer
Lexmark t640: paper jam in the back door. I can see the edge of the paper. How do I release the tension on the rollers so I can slide it out? Now it is in there tight and to grab it just tears off a piece...
Hope this helps....
Explanation of the paper jam message
A 241.09 Paper Jam message indicates that the printer thinks a sheet of paper has jammed at the front of the printer. The jammed sheet of paper is most likely to be found in one of the paper trays or under the toner cartridge.
NOTE: If you select Show areas on the operator panel, you can view one or more images to help you locate and clear the jam.
Clearing the jam
To resolve the paper jam message, you must first clear the entire paper path. To access the jam area, you will need to open one or more of the paper trays. Follow the steps in the table below to help you locate and clear the jam.
Step Action Image 1 Open the printer paper tray (tray 1), and remove any jammed media you find there. pattlnk_10222007_1922-enus28872_24109paperjam1_t64x_en_us.gif 2 Open the front cover and remove the toner cartridge. Examine the area inside the printer and remove any jammed media you find there. pattlnk_10242007_159-enus28872_24109paperjam5_t64x_en_us.gif 3 If you have a duplex option installed, also remove the duplex access tray and remove any jammed media you find there. pattlnk_10302007_1559-enus28860_24x17paperjamduplex_t64x_en_us.gif 4 If you were printing from an optional paper tray, such as tray 2 or tray 3, open any optional trays, starting at the top, and remove any jammed media. Pull the print media either up or down. If it does not pull easily one way, try the other way pattlnk_10222007_1957-enus28872_24109paperjam3_t64x_en_us.gif 5 If you are printing from an optional 2000-sheet feeder, open the front door. Press the elevator button (A) to lower the tray. Remove any partially fed media from the feeder.
NOTE: Make sure the stack of print media is straight and pushed all of the way into the feeder. Incorrectly loaded paper is the most common cause of paper jams from a 2000-sheet feeder option.
For a larger image, click here. 6 Finally, reinstall all of the paper trays and press the pattlnk_10222007_2117-select_button.jpg button to try printing again.
NOTE: You may receive a different paper jam message informing you that another sheet of paper is jammed elsewhere in the printer. If this occurs, the error code will indicate the location. Click here for a diagram showing the error code locations. The paper path will vary, depending on the paper source and number of paper feed options installed.
Remove any jammed sheets of paper you find and try printing again.
Dec 12, 2008 | Lexmark T640 Laser Printer
Canon PIXMA MP210 Photo All-In-One Printer Logo
57 people viewed this question
old marine
old marine
