Question about Sony Cyber-shot DSC-S600 Digital Camera
Turn on- Its clicks- HELP!!
Hello, whenever I turn on my camera, it clicks (sounds like a card in a bicycle spoke)for about 5 seconds, then works fine. When the LCD panel lights up it has an E:61:20 flashing on it. I am not sure what is wrong. HELP!! Thanks.
    Sergeant:
    Champion:
  • 326 Answers
Hello 4uwendy, there is a problem with lens, actually with zoom and focus initalization. Please contact your nearest Sony Service. Best regards, Arpi
Posted on Feb 26, 2007
Lenovo Ideapad z500 produces annoying clicking sound every 1 second, sometimes this happens and stops, then starts again, i have no clue what's causing it.The sound comes from the far left side of the...
Sounds like debris in your cooling fan. Try vacuuming the open grills and see if the click goes away. This is usually caused by something sucked into the fan and clicking, like clothespinning playing cards to your bicycle spokes to make a motor sound as a kid. Since the fan is the only moving part in a laptop this is with 99% certainty the problem and the only way to fix it is to remove the offending debris.
Nov 15, 2013 | Lenovo IdeaPad Z500 Laptop Computer -...
When i put my sd card in my camera wont turn on
The PDR-3300 works with MMC and SD cards. Your new 8GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work in the camera. You need to use SD cards, 2GB and smaller.
May 13, 2012 | Toshiba PDR-3300 Digital Camera
I have a marin quake 7.3 xlt and am running the 150mm maxle dropouts. when stationary if i push sideways on the rear wheel there is a clicking noise , this noise also happens when i turn corners hard and...
A few possible guesses.
1) the hub is loose and needs to be adjusted
2) the Freehub is loose and needs to be adjusted
3) the wheel is not securely in the frame
4) all these things
5) something inside the hub or hub assembly is broken
Solution: for all these take the bike into your local shop and have them take a look.
There is one other possibility, your spokes are not at full tension and the spokes are clicking against each other when you put enough lateral force on them. Again you want the shop to retension the wheel.
Depending on the wheels you have you will either need special tools to fix, parts, or special knowledge or all these. So better to pass on to a shop that has some experience working with this type of bicycle and get it done right once.
Mar 20, 2011 | Marin Quake 7.8
Will not spin and gives a grinding sound.
could be a problem with the basket drive tube or drive block
Feb 27, 2010 | Kenmore Washing Machines
My sandisk memory stick pro duo wont work anymore
I have a Sony Cybershot DSC T70 and it keeps saying "Reinsert memory stick" whenever I turn on the camera or slide down the camera lid. Also, whenever I try to view the pictures on my laptop it shows "Please reinsert the memory stick" something along those lines. As I have been researching for the solution, I would have to format the memory card. However, I wouldn't want to lose the pictures as I just took many as from the holiday last week. The only problem is the memory card, I tried using another memory card and it works fine with the camera. There is nothing wrong with the camera.\r\nCan someone please help me how to solve the memory stick problem? It would be great. Ty.
Sep 11, 2009 | Sony Cyber-Shot DSC-P92 Digital Camera
Fan In TV
the bearings in the fan are on there way out replace the fan depending on the size go to a computer hardware store to replace
Dec 01, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Clicking noise, 2004 Toyota 5-speed
Check your CV joints - usually you'll hear them clicking the most when you turn a corner while pressing on the gas, but they can make noise like that while you're driving straight. Given that it's most prominent above 35mph, I'm not sure that this is going to be the issue, but it's worth checking - if it is a CV joint, and it breaks, your car will coast to a stop and you won't be going anywhere except on the back of a flatbed.
Aug 26, 2008 | 2004 Toyota Corolla
Camera shows an error E30 message
Hi Chittu, This error usually happens when there's problem reading and writing from the Flash memory card (CF). Did you try to pull the memory card before the camera finished writing data? Here's what you should do - try using another memory card. If it works, it means that the original one is damaged. Let me know if this helped. Please rank this post.
Mar 05, 2007 | Canon PowerShot A75 Digital Camera
Sony Cyber-shot DSC-S600 Digital Camera Logo
206 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
 Russ Hill
Russ Hill
Are you a Sony Camera Expert? Answer questions, earn points and help others
