Question about GE Nautilus 24" Built-in Dishwasher
DISHES COME OUT WITH DIRT ON THEM
WE WASH THE DISHES AND THEY COME OUT WITH LOTS OF LITTLE PEICES OF DIRT DRYED TO THEM
  • stevekramek Nov 21, 2008
    I don't get the water hammer sound but the dishes usually have little particles of food dried on them after the cycle completes.
    Sergeant:
  • 276 Answers
If your dishwasher is cleaning poorly, check these: Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Step 1. Disconnect the dishwasher from its power source.
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Step 2. Turn off the water supply to the dishwasher. This is usually underneath the kitchen sink or in the basement or crawlspace near the location of the dishwasher. Pliers may be helpful here.
Note: If there are no shut-off valves, you must shut the water off at the main water supply valve for your home.
Step 3. Remove the lower panel(s) of the dishwasher. These are usually held by 2 to 4 screws at the upper and lower corners of the panel(s).
The inlet valve is usually near the front of the dishwasher. Attached to the valve you’ll see: 2 or 4 wires, the water supply line from the house and the water feed line that goes to the dishwasher.
Step 4. Remove the household water supply line from the valve. The line is usually secured with a brass compression nut. The water supply line is usually copper or braided stainless steel.
CAUTION: Water supply line may be hot.
Step 5. Remove the fitting from the valve the water supply line was attached to. This fitting may be very difficult to remove. It may help to put the valve into a vice in order to remove the fitting. If you cannot remove it, replace it. The fitting is not an appliance part but a plumbing part that is available at most hardware stores.
Step 6. Remove the screws holding the valve to the dishwasher frame.
Step 7. Label the wires to the valve so you’ll be sure to reattach them correctly.
Step 8. Remove the wires from the valve.
Step 9. Remove the clamp on the black rubber water discharge tube and pull the tube off of the valve.
Step 10. Reinstall the old fitting (or a replacement fitting if necessary) onto the new valve the water supply line was attached to. Use Teflon tape or pipe joint compound as a thread sealant. Make this fitting tight to prevent leaks. Make sure that the fitting points in the same direction as the old one so that the water supply line will meet up with it properly.
Step 11. Install the new valve in the reverse order of the removal instructions.
Note: The water supply line is under high pressure. Be sure to tighten the fittings properly.
Step 12. Turn on the water to the machine, and check for and correct any leaks.
Step 13. Reinstall the access panel(s). Restore the power to the dishwasher and test.
Note: You may have to let the dishwasher run a few minutes before it reaches the next water fill cycle.
Internal filters Every dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Water temperature To get the best cleaning results, the water entering your dishwasher needs to be hot enough. Try running the hot water in your kitchen sink for about 30 seconds before starting the dishwasher, to pre-heat it. Also, if your dishwasher lets you select a higher wash or rinse temperature, try that to see if it helps.
To check the temperature of the hot water that comes from your kitchen faucet use a waterproof thermometer. If the water isn't 120 degrees Fahrenheit, your dishwasher may have trouble getting your dishes clean. You could increase the temperature of the hot water to the whole house--and therefore the dishwasher--by adjusting the hot water heater thermostat.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Detergent cup Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
Posted on Nov 19, 2008
It doesn't wash the dishes well, leaves dirt and doesn't melt the detergent
Dishwasher Not Cleaning Dishes - The Family Handyman
www.familyhandyman.com > Skills > Appliance Repair
When your dishwasher doesn't clean well, fix it yourself following these simple steps and avoid the expensive professional service call. A simple cleaning often ...
Why Doesn't My Dishwasher Actually Clean My Dishes ...
dishwashers.reviewed.com/.../why-doesnt-my-dishwasher-actually-clean-...
Feb 26, 2015 - My dishwasher is supposed to wash dishes, right? So what are all these ... The good news is that filters are incredibly easy to clean. The little ...
What to Do When the Dishwasher Won't Clean - YouTube
? 8:27
https://www.youtube.com/watch?v=aZojUCnQifs
Sep 21, 2012 - Uploaded by doityourselfstan
Dishes aren't getting clean in your dishwasher? The problem ...Whirlpool, Maytag, Sears dishwasher Repair & diagnostic - Not cleaning well ...
Jan 01, 2016 | Dishwashers
My dishwasher is leaving a soap residue after the wash cycle. What do I need to do?
Many possible causes.
My list to trouble-shoot this would be:
  1. Rinse dishes less before loading--the dirt on the dishes is what the detergent acts upon. You only need to rinse off hard stuff like bones, seeds, toothpicks, and so on.
  2. Is your rinse-aid dispenser putting out enough?
  3. Use a little bit less detergent.
  4. Check the little nozzles in your spray arms. Maybe they have become blocked. (Sesame seeds are the sort of thing that cause headaches here.)
  5. Check drain lines and filters.
  6. Do you have hard water? Maybe your machine would work better with a water softener--whether built into the machine, or on the supply lines for the house.
Feb 20, 2011 | Bosch SHE45M06UC Built-in Dishwasher
Run full wash cycle and when finished dishes are not completely dryed so we need to air dry to complete - something is not right - any ideas. Thank you, Wade
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 06, 2010 | Bosch 24 in. SHU6802UC / SHU6806UC...
My dishwasher is leaving gritty, sandy particles in my glasses and on my dishes. How do I get rid of this
Dishwashers have a part usually called a separator or accumulator which traps the dirt from the water during the wash cycles while the water is continuously recycled to clean the dishes. At the end of the cycle the separator is flushed out and the trapped dirt goes down the drain. If it doesn't get flushed out the dirt builds up till it starts showing up on the dishes. Some separators have a hole on top and one on bottom with a valve which stops up one hole or the other depending which cycle it's running. The valve can be stuck or broken causing the problem.
Jul 12, 2010 | Maytag Dishwashers
Not cleaning dishes.
check if some dirt got in the arms of the washer as sometime this will slow the flow of water and not allow the pressure to clean the dishes well
May 24, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
I am using the same quality products to wash the dishes as I have done in the past when I used this machine effectively but now--it doesn't seem to clean the dishes and leaves a film and food residue. My...
See part 1 on this parts list and diagram. http://www.partselect.com/MultiModels.aspx?ModelNum=kuds03ft&searchTerm=img_6G53WSWK&RefineSearch=0&imgMfg=Whirlpool
May 17, 2010 | KitchenAid Architect? II S SERIES KUDS03FT...
The dirt that comes off the dishes does not wash away
Is the filter screen over the drain at the bottom of the dishwasher clogged? Maybe the drain hose is kinked or clogged. If not, check the fitting where the hose connects to see if it maybe clogged. Please rate this advice. Thanks!
Aug 21, 2009 | Dishwashers
Mold growing on dishes
Recommend that you run another cycle with no DW soap aded, waiting until the dishwasher has filled with hot water and begins to do the first wash cycle. Then add 1/2 cup of bleach to the water and close the door. Allow the cycle to finish. Run it normally with a standard load of dirty dishes. Note: These high efficiency dishwashers count on the "dirt" of the dirty dishes to help wash/clean the dishes. Recommend you not rinse/wash the dishes before you put them in the dishwasher.
Watch for any occurrence of the black dots and repeat the bleach treatment.
Jul 22, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Your incoming water temp should be about 140 degrees. If not boost your water heater temp.
Check the dishwasher drain line. It should be tied up under the bottom of the sink to prevent sink water from backing down the drain into the DW.
Feb 27, 2009 | LG Dishwashers
Dishwasher not drying
Same problem here. I read the manual very carefully. "OptiDry", "ExtraDry", "EcoDry", "condensation drying" -- lots of fancy words to cover the simple fact -- they DO NOT DRY the dishes. There is no heating element. I wish they would just state this up-front. Air drying the dishes for 24 hours after each wash is not workable for most users...
Nov 12, 2007 | Bosch 24 in. SHX99A15UC Stainless Steel...
GE Nautilus 24" Built-in Dishwasher Logo
335 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
