Question about Watches
Timex w-191-na watch band - Watches
SOURCE: Timex Watch With Flex Band; How Do I Adjust This!
It can be shortened by removing the bars from the back side. You can do it if your real handy but don't try it if your not, as you'll just ruin the band. If you look at the inside of the band you should get an idea on how they seperate. You will have to open them up much like opening an envelope. Good Luck.
Posted on May 29, 2008
slp11508
  • 43 Answers
SOURCE: adjust expandable watch bands- Timex watch
Most expandable watch bands aren't sizable. IF it is sizable you will be able to tell when you stretch the bracelet out. If it looks like you can unlatch the links when you stretch it out then you might be in luck, but like I said, most are not sizable.
Posted on Jan 05, 2009
escapement
  • 2334 Answers
SOURCE: Link removal on ladies indiglo timex
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Aug 10, 2009
SOURCE: How do I adjust my timex wr 30m watch stretch band?
It's very difficult. You have to take the decorative link covering off first, then continue with the actual stretch band by following these directions.
http://www.watchmaterial.com/How_to_size_a_watch_band.asp
Posted on Oct 18, 2009
escapement
  • 2334 Answers
SOURCE: Adjust Watch Band
Click on my profile, then click on TIPS AND TRICKS. There you will find explanation how to add or remove links. Rate me, plz.
Posted on Feb 25, 2010
Need the replacement strap for Timex watch M805
Timex Watchband - watchbands.com
www.watchbands.com/Departments/Timex-Watchbands.aspx
Original Timex® Replacement watchbands and straps designed to fit Casio, Seiko ... Currently the Timex bands we have are below. Leather Timex Watch Bands.
Jan 01, 2016 | Timex Watches
How do I set the time on a Timex 1400 mens sport watch
http://www.timex.com/info/Product_Instruction_Guides_Downloads
There are two ways to find the user manual for your Timex watch.
1. Find your watch on the list below and click on the language link for your manual.
2. Find the 3-digit module number located on the caseback of most Timex products and click on the corresponding language link for that number in the Module Table at the bottom of the page.
Feb 15, 2011 | Timex 1440 Sports Duration¿ 52991...
How do you set a timex 1440 sport watch
timex.com has a manual specifically for your watch
Nov 10, 2010 | Timex 1440 Sports Venom¿ 53141 Wrist...
Replacement watch band web site?
mcdevito75 here, Timex.com should help. Also look for a small watch repair shop in your area for a replacement strap, and they may even have faster accesss to Timex.
Jun 27, 2010 | Timex Sports Ironman Triathlon 100-Lap...
Need help setting interval timer on timex w-191-na 100 lap memory. need to set to 1 min and 2 min and repeat 10 times
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Jan 13, 2010 | Timex Popular T5E931 100 Lap Ironman...
I'm looking for a watch strap for a ladie's Timex expedition Adventure Tech watch. Where do I find one??
Timex stores are the only place I have been able to find their straps consistently. If you have a standard lug set up you might be able to get a similar after market strap at your local repair shop.
For Timex locations visit their web site...
Timex.Com
Sep 12, 2009 | Timex Expedition Adventure Tech Compass...
Where in Edmonton can I purchad a watch band formy Timex Expedition watch with compas
I suggest that it will be easier for you to buy over the internet.
Just type in your browser WATCH STRAPS or WATCH BANDS and you will find numerous sites.
Also try TIMEX WATCHES and TIMEX WATCH BANDS.
Dec 19, 2008 | Watches
Watches Logo
206 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
