Sony str-d911 receiver won't turn on - Audio Players & Recorders
Noggin
  • 944 Answers
SOURCE: sony receiver str-da2000
Here is the link for the user manual if you need it; http://esupport.sony.com/US/perl/model-documents.pl?mdl=STRDA2000ES®ion_id=1 Check page 54 for details of the error message - it should disappear if the speakers are connected properly and the unit is switched off and on. Check page 17 for speaker connection details, and ensure they are all correct. Check page 19 for details of the factory reset/memory clearing. Hopefully this will clear the error code and let you set the unit up. Hope this helps, please ask again if no luck :)
Posted on Jul 14, 2007
SOURCE: Sony STR DG 510 receiver manual
Hey there, found it on the sony site...
http://esupport.sony.com/CA/perl/model-documents.pl?mdl=STRDG510
Hope that helps.
Posted on Oct 19, 2007
  • 3 Answers
SOURCE: code for sony receiver model str d565 protect mode
If you need support you can log into:
http://esupport.sony.com/US/perl/support-contacts.pl?mdl=STRDG510
for free tech support on sony chat line
Posted on Jun 02, 2008
SOURCE: left channel is out sony STR-D511
Had the same problem but found simple solution. I just reconnected the speakers which were on "A" connections to the "B" set of connectors immediately below - problem solved!
Hope this works for you.
Stuart
Posted on Jan 22, 2009
  • 85 Answers
SOURCE: operating instructions for sony str-d565 receiver
this is a link just make sure to disable protected mode in internet explorer sometimes it has problems with links
http://www.docs.sony.com/release/STRD665.PDF
Posted on Feb 23, 2009
Poor sound when switching to both a&b speakers
Check your speaker polarity. Make sure the plus and minus of all 4 speakers are the same, otherwise they will cancel its other out.
Mar 28, 2014 | Sony Audio Players & Recorders
I've got a Sony STR-K880 Cinema surround system and the remote control won't work it anymore! The only thing it will do is turn the system off when I push the'AV I-O' button and the &#
I had the same problem. Found the fix in this document
STR-K880 service manual
On the amp, while powered off:
"While depressing the INPUT MODE button, press the POWER button to turn on the main power."
You may need to do this more than once.
This switches command mode between AV1 and AV2.
Jul 08, 2012 | Sony Audio Players & Recorders
Unit won't turn on. There's power to the outlet but the reciever just won't light up! Sony STR-DE 197 It's only a couple of years old and shows no damage.
Failure of the the power source. To see if it's fixable the receiver will have to be opened and the power board tested . This job requires at least a basic experience in electronics - if you don't posses it all you can do is to look for a burned fuse or damaged capacitors. For them follow this
http://www.youtube.com/watch?v=YCSNWi3UHf4
Sep 05, 2011 | Sony STR-DE197 Receiver
Helo ! I need to know why the subwoofer is silent when I connect it to my receiver-STR DE 475 . Plus , the sorround does not work . When I push the bottons , I either get the centre with the front...
Have you looked at the manual? There are procedures for adding a sub (which is NOT necessarily assumed to be there) and assigning bass to it.
http://www.retrevo.com/support/Sony-STR-DE475-Receivers-manual/id/387bh949/t/2/
Then there's the unidentified sub's manual and requirements to consider.
Sep 01, 2011 | Sony STR-DE475 Receiver
Sony str de 475 ?? is appear 'protect' on screenboard and can not listen anything
The message appears usually when the wiring is wrong (short circuit) or the speakers are defective or their impedance is too small for the amplifier's output (for instance 4 ohms speaker connected to an 16 ohms output). First, check your connections.
May 15, 2011 | Sony STR-DE475 Receiver
Can I connect a passive subwoofer Sony SS-W581T to a SONY receiver STR-DH510 ? Thank you
No. Like most AVR's it only provides a Line Level output for an externally powered subwoofer. Get a separate amp for the sub.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-STR-DH510-Receivers-manual/id/23637ci375/t/2/
Apr 17, 2011 | Sony STR-DH510 5.1 Channels Receiver
PROTECT shows every time I turn my reciever on. It's a SONY model #STR-DE335
Turn it OFF. Look for shorted speaker wires or shorted speakers.
None found? Disconnect all speaker wires and try to turn it on.
Turns on ok? One of the speakers/cable pairs is shorted. Check them again.
No good? It's dead. take it to a tech.
http://www.retrevo.com/support/Sony-STR-DE335-Receivers-manual/id/387bh942/t/2/
Jan 08, 2011 | Sony STR-DE335 Receiver
Sony STR-DE635 Receiver-no sound at all
Turn your volume down,press the tape monitor button.then turn up?
Mar 20, 2008 | Sony STR-DE635 Receiver
 Grubhead
Grubhead
