Question about Frigidaire FEF336BC Electric Kitchen Range
GE PROFILE electric oven
Having used the oven to bake earlier in the morning, I switched it off and left the door open so the heat would warm the room. I can't remember if the door was open or closed when I turned off the heat, but I know it was some 30 minutes later that I closed the door. I remember seeing the words "door lock" or "door locked", flash very quickly on the screen.  No light appeared so I thought no more about it until I needed to use the oven again some 3 hours later. The door will not open, I can see through the slot behind the horizontal handle that the lock catch in the lock mode. There is no light on in the screen, nothing. I have tried pushing in the door and holding my finger on the OFF button, but nothing happens. I called the GE help and repair line, switched off the power for 20 minutes. and still no luck.
Hopefully you will have the answer.
Regards, Ann B.
  • babartok Nov 06, 2008
    All I had to do was press the clean pad then hold down the off button until the clicking stopped and walla! it opened.
    No need to take any panels off, but thanks for offering to help.
    I was without an oven for three days.
    That was an expensive lesson to learn.
    babartok.
  • Anonymous Nov 16, 2008
    I pressed the clean BUTTON then held down the off button until the clicking stopped and walla! It did not opened! Two days without an oven.
    Guru:
  • 93 Answers
You are going to have to remove the back panel and manually turn the lock motor to release the door lock catch.   To chat with me live and walk you through how to repair this visit www.applianceoutletservice.com  Thanks, Bill
Posted on Nov 05, 2008
Oven warms to desired temp then cools down
Check your bake element. Unually ovens use both bake and broil elements to preheat and just bake element to keep temperature. Your bake element is probably burned out.
Jan 30, 2011 | GE Profile JT912 Electric Single Oven
GE Profile JTP85 (installed 1998). The lower heat element in the lower oven will not heat. I can make the upper element heat up by using the BROIL function, but neither element gets warm on BAKE.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Dec 11, 2010 | GE JTP85 Electric Double Oven
I have a GE JTP18 Trutemp. It seems to be taking
sounds like a stuck relay on the control board ... can you tell if the bake or broil element is glowing during this time?
Jul 19, 2009 | GE Profile JTP18 Electric Single Oven
GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
GE Profile elec range JSP40 Locked door flashing can't use oven
Replace the oven temperature sensor to solve the F3 problem.
You may need to replace the oven lock micro switch to solve the locking problem.
Change the sensor first. Then try the oven.
Mar 04, 2009 | GE JSP46 Electric Kitchen Range
GE Profile JT952 Double Wall Oven doesn't heat up adequately
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 29, 2008 | GE Profile JT952 Electric Double Oven
GE Profile XL44 Spectra gas oven
try to hold down the light switch on the door set it up for another cleaning hit start when oven clean door lock showes hit cancel if that doesnt work try unplugging it for three min fyi the doors can take up to an hour to un lock after cleaning its so it dont burn your face off from the intense heat after cleaning some take 2
Feb 14, 2008 | GE Profile JGS968 Gas Kitchen Range
Oven fan keeps running even after off and door open
3 to 4 hours is a long time. Get to the fans (behind the control panel) and check the screens for dust. Chances are the screens are clogged with dust and need to be cleaned so the fans can move air for cooling better. I had this problem on my GE JTP14, and after cleaning just one fan it can keep up with cooling the electronic area while the oven is running. It runs much less often.
Safety first! cut the breaker before removing anything with a nice conductive screwdriver! Hope this helps!
Jan 01, 2008 | GE Profile JTP18 Electric Single Oven
Frigidaire FEF336BC Electric Kitchen Range Logo
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
