Question about Canon Pixma iP6600D InkJet Photo Printer
Canon Pixma iP6600D - ink problems
I've printed successfully on my Canon Pixma iP6600D for about 2 years, using Canon cartridges to start with then switching to non-original chip-swap cartridges. I had a problem printing last week. Colours were poor. I noticed more than one cartridge was either empty or almost empty so put new ones in for all 6 colours. Unfortunately, this did not solve the problem. A nozzle check showed streaks accross most colours so I splashed out on a new print head (fools rush in). This has not solved the problem. Nozzle checks are not consistent with some colour showing one time then not the next! Some show as faint and streaked. The Cyan never shows!
I am at the point where a quick cheap fix will make it worth keeping my old printer. I have had it suggested (by the print head supplier) that it may be the purge unit. He wants to charge £40 plus parts and carriage so it may not be worth it. The print cartridge supplier says my swapped chips may have 'worn out'.
Is there a simple check that I can do to eliminate the purge unit as a cause? I have tried cleaning, deep cleaning and print head alignment from the maintenance menu.
Is it just a case of cut my losses and get a new printer.
Any thoughts would be great.
  • lastchance2 Oct 26, 2008
    ....many thanks for your post. If I replaced the 5 non-original cartridges you think the problem might right itself? It's about £55 UK Sterling or $88 US for the five (I have one original already). No problem with the purge unit? Can I run any test to check the purge unit.
    President:
  • 2,712 Answers
Use original cartridges. Generic or refilled cartridges tend to cause these problems.
Posted on Oct 26, 2008
  • Swilin Sampson
    Swilin Sampson Oct 26, 2008
    Unfortunately, there is no simple way to do this. You should, however, be able to find cheaper original cartridges by looking for them on the internet. You couls also try reinstalling the printer driver. that also helps at times.
    If the original cartridges are still causing the same issue even after reinstalling the driver, then think about the purge unit..
Canon mx860 printer not using ink from PGBK 220
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Mar 07, 2013 | Canon PIXMA MX860 All-In-One InkJet...
Will only print in blue ink
most likely you are out of ink other than blue, try to refill the other colors or get new cartridges.
Mar 26, 2009 | Canon Office Equipment & Supplies
Printer wont continue printing if ONE cartridge is empty
Sorry to say this, I had a Canon Pixma and it wouldn't print unless you replaced empty cartridge, although I did have some success for a while longer by pressing OK button?
Feb 27, 2009 | Canon Pixma iP6600D InkJet Photo Printer
Won't print with just black ink cartridge
When you print, in the printing window, click properties, then click advanced. Most times you can select to print using black cartridge only. Unfortunately you will need to replace to get the printer working. If you need further assistance let me know.
Thank you,
Lee
Feb 26, 2009 | Canon Pixma iP6600D InkJet Photo Printer
Canon pixma ip6600d omitting black ink
Many printers use color to make black, you may have to FORCE it to use the black ink cartridge for black or turn off something that is telling the printer to use the color cartridges for the black.
That's my educated guess anyway...
I do know that some printers do this, so I'm assuming this is what is giving you trouble. I don't know why it would print any different on a memory card than from the computer though...
Jun 12, 2008 | Canon Pixma iP6600D InkJet Photo Printer
Canon IP90 portable . No ink printing.
Have you performed a nozzle test? If one or more of the colors is missing when you do the nozzle test, the printhead itself is likely in need of replacement.
Before considering replacment, perform a clean on the printer. Due to variations between mac and pc, please see your documentation / support files on how to perform the clean on your printer.
After performing the clean, again perform the nozzle check to see if the problem is resolved.
If still not resolved, remove and re-install any cartridges you recently replaced to make certain they are installed correctly.
May 01, 2008 | Canon PIXMA iP90 Mobile Printer
Error code 5100 on my Pixma iP6600D.
I had the exact problem described and it was the following:
one of the ink cartidges had popped out of place "inside" the printer housing on the right hand side, and was catching as the printer tried to start up.
By using a thin object such as a ruler, I could press the ink cartridge back into place to allow the ink cartidges to come out from the printer side area. Once out I properly reseated the ink and all seems fine.
Apr 08, 2008 | Canon Pixma iP6600D InkJet Photo Printer
Canon PIXMA iP6600D
Canon PIXMA:
Inkjet liquid has to dry up. Does not matter if you leave it in or out, or try to repackage it.
If it was laser jet which infact uses powder like material would stay intact for long.
Hope that helped.
Regards
Jan 08, 2008 | Canon Pixma iP6600D InkJet Photo Printer
Canon ink tank problems
I think I figured this B!tch out.
When you get the error:
"More than one ink tank of the following color is installed" or
"Ink cartridge not recognized"
Open up the lid where the cartridges are and hold done the "SEARCH" button. This has been working for me, and I bought my ip6600d in 2005, so my machine is old, and ready for this..........ORIGINAL INK!!! Never really used it beyond printing very few pics. So I was really pissed when I found these messages to almost 5 years after buying this printer. So to recap, open the lid where the ink cartridges are while holding the "SEARCH" button, hold it up for like 5 to 10 seconds, place lid down still holding the search button, then let go of the search button. I did notice the alarm was lit, but went away after I released the search button. Good Luck!!!
Until I held the search button down I had turned of the printer, reseeded the cartridges and open and closed the lid but it never worked.
Sep 19, 2007 | Canon Pixma iP6600D InkJet Photo Printer
Canon Pixma iP6600D InkJet Photo Printer Logo
293 people viewed this question
old marine
old marine
