Question about Campbell Hausfeld 5 Peak / 1.7 Running HP, 17 Gallon Husky Air Compressor
CAN YOU STAND THE Husky WL651004AJ UPRIGHT?
I have a Husky WL651004AJ horizontal model, can I stand it upright (vertical)?
  • Daniel Zahn Feb 22, 2012
    I have a Husky WL651004AJ model which is a horizontal model with wheels. I want to stand it upright (vertical) in my shed to save room. Can I do this?
  • Campbell Hau... Master
  • 885 Answers
Your compressor will work in the vertical position however you will not be able to properly drain the water from the tank in this position.
Posted on Feb 20, 2012
2 Suggested Answers
SOURCE: I have a husky air compressor model WL651004AJ
You can inspect the check valve by removing it and pulling on the small plastic pin sticking out of the middle of the tank side. It should spring back under fairly light tension. Also visually inspect and clean out with a dry q-tip the brass screen on the inlet site. Seal back with ribbon dope.
If this looks ok, remove the 4 bolts holding the head on. Keep all of the sandwiched plates together in order so they go back in easliy. The cylinder sleeve will come off with this stack. Look at the plastic surround on the piston and the inside of the cylinder. In my case, this was eaten up from too many hot summers and cold winters in the garage. The rubber/plastic had hardened and eaten part of itself away. To replace the entire piston assembly on the WL651004AJ, you'll need to get part number WL211000AJ, which in some books is superseded by WL211000SJ.
If the cylinder is scored (meaning that by scraping your fingernail against the lines in it, you catch the nail) then you're probably better off replacing the whole cylinder unit.
Posted on Oct 02, 2011
I have a husky model 947265. And it won't shut off when I turn it off manually I have to wait till all the air is out before it turns back on
Free Husky Air Compressor User Manuals ' ManualsOnline ...
powertool.manualsonline.com > ... > Husky > Power Tools Husky
Husky Air Compressor Operator's Manual ... Plumbing Quincy Single-Stage Air Compressor - 3.5 HP, 220 Volt, 60-Gallon Vertical Tank, Model Q13160VQ.
Sep 04, 2015 | Air Tools & Compressors
Does it matter which cage I'll buy, vertical or horizontal?
Like all things each type has its advantages and disadvantages. Horizontal bars are easier to climb and vertical cages provide better visibility. There are brand which combine the two of them together and you should check out if it's suitable for you.
Aug 05, 2012 | Birds
I have model Husky WL651004AJ it will not run at all. I want to remove the top cover to check the electrics. I can get the cover off. The snaps come loose, that's as far as I can get. How do you remov
I have a Husky WL651004AJ which has not been starting up for family members lately and noticed a 50 ft extension cord was being used because of the distance from the power outlet. I moved the air compressor to the power outlet and plugged in the power cord without any other extension cord and the air compressor works fine. The 50 ft cord was too light duty for the power required.
(12 ga) and min gage of 10 for the distance of 50 ft without disrupting the power breakers.
Dec 08, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Have mod.# wL651004aj put new piston and ring kit in still does not build air pressure nee help
I would suggest checking the valves . Make sure they are good,no trash ,seating properly. other items to look at include, head gasket,installed correctly? air filter plugged or inlet blocked with something
Aug 08, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
I have a husky air compressor model WL651004AJ will only build up to 50 psi and compressor keeps running any advise som one could give me to whats wrong.
Jan 18, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Window too small for a/c
Unfortunately you cannot mount this type of A/C vertically. The compressor must be in the upright position or it will be damaged and not function in a short period of time.
May 30, 2010 | Goldstar R5050 Air Conditioner
What is best position for console horizontal or vertical
I keep my xbox 360 horizontal because my disks get less scratched this way and no fans are blocked.but if you keep it this way, DO NOT put a graphic on the 360
Hope This Helped =)
Dec 27, 2009 | Microsoft Xbox 360 Console
I need a new belt for my Husky air compressor but I don't know
This is a simple way to replace your belt without the old one for comparison. Use a piece of rope thick enough to fit inside the pulley, (cloths line works well). Simple wind it around the pulleys marking where the two ends meet. Cut and measure it. Take the piece of rope and measurement to a auto parts store and ask them to match it up. An automotive belt will work fine.
If this is a flat belt they should still be able to help you.
Aug 07, 2009 | Air Tools & Compressors
Acer 2223W monitor stand
There are indeed generic stands which rotate between portrait and landscape orientation. This monitor, like most monitors sold today, has generic "VESA" mounting holes, in the 100mm x 100mm (MIS-D, 100, C) configuration shared with most other flat screen PC monitors, so they can easily be used with a variety of stands that attach to the 4 holes in the center of the back side of the monitor.
Apr 05, 2009 | Acer AL2223W 22" LCD Monitor
Campbell Hausfeld 5 Peak / 1.7 Running HP, 17 Gallon Husky Air Compressor Logo
327 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
