Question about Toro Lawn Mower With Toro Power Tools
White smoke my lawnmower makes a rattling sound, it cuts off and lately white smoke has been coming out of the front. we changed the spark plugs and still can't figure out what the rattling is or why the white smoke is coming out. please help
  • 48 Answers
The white smoke is oil - did you overfill the oil ? if you tipped the machine your air filter could be full also - if this is an old machine it could be ready to throw a rod but not enough info from you to tell
Posted on Oct 27, 2008
My lawnmower started to flutter till it died while shooting white smoke. Any suggestions?
The white smoke points to the oil and fouled spark plugs.
Make sure the oil level is according to the gauge.
Oct 03, 2015 | Garden
White smoke from engine on Start up
Sounds like the turbo. Have you ever changed the turbo? If not, I would bet on that. If you've changed it but have more than 60-80k miles on it, same.
Apr 04, 2014 | Saab Cars & Trucks
Possible electrical problem?
Diagnosing something from a description is far from an exact science, but this is what it sounds like to me may have happened. If your battery was not tie down it could have gotten against something hot or moving (like a pulley), or what ever was rattling may have created a spark somehow and caused the battery to exploded, either way the battery fluid spashing onto hot metal could explain the cloud of white smoke, as you did not mention seeing any flames.
Nov 06, 2013 | 1999 Toyota Camry
Change spark plugs now smoke
I can't see the smoke you're talking about - but I suspect it is oil burning off. Did you see / apply any oil to either the threads of the block or plugs or drip or spill something on the exhaust manifold / pipe? Did you torque the spark plugs in properly? A loose plug can result in poor compression and ignition and allow some exhaust gasses / smoke to escape. The engine sounds to be running well, so I suspect that the small amount of oil burning will be burnt off completely very shortly.
Jun 04, 2013 | Vehicle Parts & Accessories
First there was occasional white smoke, loud engine rattle, cutting out on full throttle and poor starting. the injectors were serviced but the engine has refused to start.
White smoke is usually an indication of a blown head gasket. Check you oil (dipstick) for a milky looking color instead of normal oil. Pull a spark plug and look to see if there's moisture on it. All of the symptoms you've given point towards a bad head gasket
Jan 06, 2011 | 2004 BMW 5 Series
Blown head gasket or not?
check oil dip stick for water/antifreeze and radiator for oil in antifreeze but usually alot of white smoke-steam from tailpipe usually indicates head gasket blue smoke means oil black smoke carbon
Sep 29, 2009 | 1993 Acura Integra Hatchback
Lawn mower keeps cutting off
from the sound of what you are describing the piston/rings/cylinder are damaged in some way shape or form this causes compression loss in the engine, and allows oil to enter the combustion chamber, in this case a new lawnmower would be in the near future
Aug 11, 2009 | Garden
Toro Lawn Mower With Toro Power Tools Logo
1,287 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
