Question about Canon PIXMA MP210 Photo All-In-One Printer
Canon Printer Pixma MX700
Paper jam in the front tray. I can not take dthe paper out
  • Canon Master
  • 1,879 Answers
If turning the printer off and on doesn't help, high probability it's bound for service because pulling the jammed paper out by force might damage the paper sensor.
Posted on Oct 26, 2008
    Genius:
  • 2,035 Answers
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Good luck...
  • Canon Master
  • 13,433 Answers
User a small object.. got pins? something small to Grab the paper. Il get you the paper jam clearing instructions for your model.
  • Ekse Oct 26, 2008
    Paper jammed in the paper output slot, the Rear Tray, or the Front Tray.
    Remove the paper following the procedure below.
    (1) Slowly pull the paper out, either from the paper source or from the paper output slot, whichever is easier.
    (A) When printing from the Rear Tray
    (B) When printing from the Front Tray
    If the paper tears and a piece remains inside the machine, open the Scanning Unit (Printer Cover) and remove it.
    After removing all paper, close the Scanning Unit (Printer Cover), turn the machine off, and turn it back on.
    * Be careful not to touch the components inside the machine.
    If you cannot pull the paper out, turn the machine off and turn it back on. The paper will be ejected automatically.
    (2) Reload the paper in the machine, and press the OK button on the machine.
    If you turned off the machine in step 1, all print jobs in queue are canceled. Reprint if necessary.
  • Ekse Oct 26, 2008
    Read and see more of the instructions, they are now stored at
    http://koti.mbnet.fi/exuli/paperjam.pdf
Message says no paper in front tray. Paper is where I've always put it in back. Won't print.
go print -> properties -> page setup -> print options -> tick Disable the paper source setting of the application software -> hit ok and go back to "main" -> select the paper source that you want and hit ok ok and print
Nov 20, 2010 | Canon PIXMA MX700 All-In-One InkJet...
PAPER JAM PROBLEM
remove power (turn off) machine, and open just to show the roller, and manually turn the roller just guide paper out.
Mar 24, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Ive got a pixma mx700 printer and im getting the 5c00 error how do i get rid of this
Error code 5C00 refers to possible paper jam or product needs reset or service.
It is possible that a previous paper jam has left a piece of paper inside the machine. If you cannot see any paper jammed at either input area, open the rear cover and look in there. Otherwise, you can try to reset the product:
Reset the printer:
1. Turn the printer off with the Power button
2. Disconnect the data cable from the printer
3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. Attach data cable.
4. Turn the printer back on
If all of these suggestions fail, your MX700 may require repair service.
Dec 28, 2009 | Canon PIXMA MX700 All-In-One InkJet...
How do I re-set error 6A80? on my Canon PIXMA MX700 lcd display?
6A80 is APP position error.First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output)
is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.Check the sheet feeder.If this not help your printer need service.
Nov 01, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Print jam with Canon MX700
Monica, on the back of the printer is a black panel that pulls out by grabbing the tab that sticks out on the one side and pulling. That will allow you to acces the jammed piece and reset the printer! Hope this solves it! Eric
Jun 11, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Printer jam error but cannot find any paper
the smalled piece of paper can cause it to stop.. if you are 100% sure that it is not a jam, then it can be that your ink is leaking, and drying up in the printer.. I had that problem once, and I had to buy a new printer.
May 20, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Will not print
go to this page: "http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15651#SupportDetailAct"
seems to be related to paper jams or wrong size of paper being placed in the front tray. if loading odd (e.g.: credit card sized), paper sizes, they need to be loaded into the rear tray.
good luck!
Jan 09, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Not reading paper
If you toggle the Feed Switch button (lower left side of control panel) to the Front Tray, does the printer print then? What type of paper is selected in your Printer Settings on the computer? I think that if you have selected anything but Plain Paper, the driver wants you to load the paper (photo paper, etc.) in the Rear Tray.
May 20, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Pulled out paper & broke the printer
There is a part of the printer that looks like a roller (sorry I can't remember the name now) but you may know it. It rolls over the papers to pick one at a time and forward that to the printing segment. If you can reach it, try (gently) to adjust it into place (or normal position). It probably rotated half cycle or so when you forced the paper out. It needs to complete the cycle in order to tell that there is paper. I am using experience from laser printers so bear with me. But that's what usually causes such problems after **** occassions.
May 09, 2008 | Canon MX700 Office All-In-One InkJet...
Canon mx700 printer
Using a q-tip clean the rollers with rubbing alcohol.
Try different paper. The fact that it grabs more than one page means the paper or rollers are dirty.
Mar 05, 2008 | Canon MX700 Office All-In-One InkJet...
Canon PIXMA MP210 Photo All-In-One Printer Logo
95 people viewed this question
old marine
old marine
Corne Viljoen
