Question about Sharp Office Equipment & Supplies
EL-M332 calculator setting and using tax rates
How dotax you set, clear, and use the yellow tax buttons?
SOURCE: Changing the % tax setting on my Casio calculator
step 1 pess the AC button step 2 press and hold for two seconds the % button step 3 press the tax+ button step 4 input 17­.5 step 5 press the % button that should be the tax set you can check it is set correctly by pressing the AC button and then the tax+ and 17.5 should be displayed
Posted on Apr 12, 2007
SOURCE: How do you set a tax rate?!?!?
Casio Calc SL-210TE
How to Set Exchange & Tax Rates
Select EX mode
Press AC
Press and Hold for 5 Sec %(Set) key
Press C1 or C2 or C3 or TAX+
Enter New Rate
Press %(Set) Key
New Rate is now Saved
Hope this Helps ..Mike
Posted on Oct 31, 2007
MY TAX- AND TAX+ ARNT WORKING ... ANY1 NO HOW 2 FIX IT ?? PLZ ???
Posted on Jan 31, 2008
SOURCE: Set Tax Rate
Type in the rate of tax you want to use, then press rate and then press tax+ :)
Posted on Jul 14, 2008
SOURCE: how to set the tax rate
Its easy just type in the tax rate that you want, then hit the rate button. Afterwards leave tax+ pressed and you should see the tax % sign appear above the number you punched in, and THATS IT!!! Easy!!!
Posted on Jul 23, 2008
How do you set the tax rate
Example: setting 5% tax rate
1. move mode switch to 'rate set '
2. press 5 (for tax rate ) followed by TAX+ button
3. Move mode switch to GT
to add tax to e.g 200 type:
200 TAX+, the result is 210
Feb 16, 2009 | Sharp EL-1197PII Calculator
TAX SET
Press +TAX
press the number you need to set it at
Press +TAX again then CA
worked for me!!
Hope this helps
Oct 21, 2008 | Sharp EL-1801P Calculator
Setting features on calculator
Yes, you are missing a step. You need to first fo to rate set then enter 7.75% then hit TAX+ key. You may now go back to GT and it will equate tax.
Aug 06, 2008 | Sharp EL-2196BL Calculator
NEED TO SET TAX RATE
Solution #1 has it backward..
(tax rate), STR, TAX+ (or TAX-)
Example- San Francisco sales tax = 9.5% you enter 9.5, STR, TAX+.
now it functions as (amount entered) plus tax. Example- find the total with tax for a purchase of $14.99 14.99, TAX+ Calculator will show 16.41
Jun 05, 2008 | Sharp EL-2192Rll Calculator
Set Tax Rate
First clear all w/ ON/AC.
Enter the tax rate desired eg. 7 for 7% (can you tell I'm in PA)
Press RATE then TAX+
Press C/CE.
The next time you use TAX+ it will calculate and add the value that you set.
Do the same for TAX-, you can use a different value for each as they are separate memories.
May 30, 2008 | Office Equipment & Supplies
Tax rate
Here are the steps to do it:
1. Enter the desired tax rate number. E.g. 6
2. Press blue "RATE" button and TAX% sign will start blinking.
3. Press "TAX-" button and the TAX% sign will stop blinking.
4. You have set the rate, now press C to clear the display and
start using with new rate.
May 23, 2008 | Canon LS-100TS Calculator
SETTING TAX RATE
On your Sharp press
CA
C.CE
C.CE
RATE SET(+TAX Key)
175(No decimals for they are not taken into consideration)
RATE SET(+TAX Key)
To check if all went well press
CA
C.CE
C.CE
RATE RECALL(-TAX Key)
It should read your tax rate.
May 01, 2008 | Sharp EL-330AB Calculator
Set tax rate for Sharp EL-1701C
I Finally figured it out after playing with it for almost 1/2 an hour!
Hit 2nd then Tax + (rate set) it will appear as 0.000 enter your tax rate... mine is 5% so I enter 5.0 then hit 2nd and Tax + (rate set again) And it will work!
It is glorious!!!
Answered By James Soltys from: Edmonton, Alberta Canada
Jan 20, 2008 | Sharp EL-1701C Calculator
Need to change tax function on Sharp EL-334A
I had the same problem and finally figured it out. Here's what you do:
Press C-CE twice
Press +TAX (Rate set)
Key in your new tax rate as an integer (e.g. 5)
Press +Tax (Rate set) again
Press C-CE
Then you're ready to calculate with the new rate!
Now what's the GT button for?
Nov 19, 2007 | Sharp EL-334AB Calculator
+/- Tax button has stopped working
press C.CE C.CE RATE SET (tax ie 17.5) then RATE SET
Sep 21, 2007 | Sharp EL-334FB Calculator
21 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
