Question about Hitachi C12FDH 15 Amp 12Inch Dual Bevel Miter Saw with Laser
Hitachi compound miter saw makes a noise that sounds like the brake is on.
5 Suggested Answers
  • 33 Answers
SOURCE: I have a Hitachi C8FB2 compound miter saw that the
there is always going to be some sparking between the BRUSHES and the commutator. if it is excessive and loud or is really heating up the housing, there could be a crack in one of the brushes, the brush might be chipped or unevenly worn, or the brush holder itself may be burned cracked, or otherwise need to be replaced. they may LOOK okay but need to be pulled out to really know for sure sometimes. there is a small set screw in the housing that holds the brushholder in place.
while this could be the problem with the electric brake, it is more likely that there is a wiring connection loose, broken or burned inside the motor housing. it could be the switch but i dont believe the brake circuit runs through the switch on this model.
Posted on Dec 14, 2009
  • 1388 Answers
SOURCE: Electric Blade Brake is not
Brake is controlled by the switch. There are two switches that can be used on your saw. One switch has only on/off, the other switch is on/on. On motor when pressed and on brake when released. The switch with brake does not last very long because the braking action is really just shorting motor circuit (short circuit). All motors can produce electricity. The brake action occurs by shorting motor thru switch. Electricity that motor is producing while turning forces armature to stop. Other brands use a resister in breaking system to absorbe current help switch last longer. Parts are available at www.toolpartsdirect.com Good luck
Posted on Sep 07, 2010
SOURCE: C10FSB 10" Sliding Dual Compound Miter Saw: how to repair brake...
Replace the Stator!
Posted on Sep 14, 2010
woobie dog
  • 1273 Answers
SOURCE: How do you release the saw blade from the closed
Hello, W/D here.
At the back of the saw, where it hinges, is a pin that locks the pivot joint. Push down on the saw handle while pulling the pin, then allow the saw to rise to the ready position. Reverse the order to store the saw.
Best regards, --W/D--
Posted on Feb 23, 2011
Kobalt SM2505LW 10 sliding compound miter saw makes grinding noise and slow saw stop
a bearing ,brushes or brake broke more likely the brake mechanism if blade coasts
Jul 07, 2016 | Saws
Hitachi c12rsh brake
There are a few things that can cause this:
1) Check the brushes - make sure they are not severely worn and make sure they travel freely down the brush tube & contact the armature well.
2) If the brushes are OK the problem is most likely the switch. Tools with a brake have a 2 pole switch - one set will be normally open and one set will be normally closed (Most switches have a diagram printed on them) Disconnect the leads (keeping track of where you removed them) and using a continuity tester check the switch - you should get a reading between the normally closed contacts and lose it when you pull the trigger. Most likely you will find you are not getting a reading on the normally closed side and that would be your culprit. Hitachi C12RSH 12 Sliding Dual Compound Miter Saw Parts
Mar 16, 2015 | Hitachi C12RSH 12" Sliding Compound Miter...
Braking on miter saw not working
Try fitting a new set of brushes first otherwise it could be that it needs a new field coil.
Dec 27, 2013 | Hitachi C10FSH 10" Dual Bevel Slide...
How do you release the saw blade from the closed position on a Hitachi C10FCH 10" Compound Saw?
Hello, W/D here.
Feb 23, 2011 | Hitachi 10" Compound Miter Saw (with Laser...
Hi, my dewalt 12 inch double bevel, is making a
This sounds like a problem with the electric brake on the motor.
Aug 30, 2009 | Dewalt Heavy - Duty 12" Double - Bevel...
Saw runs continuously
The on off switch has a contact that has probably fused together from making and breaking causing an arc. You may try giving it a good 'wrap' with the back of a screw driver to free it, or replace the switch.
Jul 15, 2009 | Hitachi C10FCE2 10" Compound Miter Saw
Hitachi C12FDH 15 Amp 12Inch Dual Bevel Miter Saw with Laser Logo
129 people viewed this question
Top Hitachi Saws Experts
John Trevino
JOHN LAPIER
Are you a Hitachi Saw Expert? Answer questions, earn points and help others
